Wrong memory detection T95MAX H616
Michael Robinson replied to blackc's topic in Allwinner CPU Boxes
You need to seek support from his repo. We only can support builds from: https://github.com/armbian/build/ -
This post from February 2025 claims that RP5 and RPMini are supported: https://www.armbian.com/newsflash/armbian-v25-2/ however, I can't find them on the downloads page. I also don't currently own an RPMini, I am tempted to buy one but I wanted to make sure it was supported first. What's the state of support right now?
dev001 posted a topic in Software, Applications, Userspace
Using odroidxu4. flashed Armbian_25.8.1_Odroidxu4_noble_current_6.6.102 to eMMC After odroidxu4 started, followed instruction to create accounts etc. Installed xfce4 package reboot. odroidxu4 booted to console prompt Installed xfce4-goodies package reboot. odroidxu4 booted to console prompt Installed lightdm reboot. The system becomes stuck at plymouth-quit-wait.service/start Not much I could do after this as I could not look at log messages or use $ sudo systemctl status lightdm.service Any insight greatly appreciated Thanks - Yesterday
Efe Çetin replied to Renoria's topic in Orange Pi 5
Choose install/update bootloader on spi flash option on armbian-install. Some uart logs could be useful if you have usb-ttl converter stuff -
Hello! I have a T95MAX ver 3 board with H616 / AXP313 / 4Gb RAM. I've compiled an Armbian from Nick repo (https://github.com/NickAlilovic/build), branch v20251014 for Transpeed-8k618 with a little defconfig patch for TOC0 and DCDC3 voltage = 1.5V (extracted from Android native image DTB). CONFIG_AXP_DCDC3_VOLT=1500 CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y Image booting ok, but first UBoot stage found 4Gb and second stage found only 2Gb. Someone have any ideas for make 2nd stage and kernel detect full memory? U-Boot SPL 2025.04-armbian-2025.04-S3482-Pfbbd-H8869-V9b5f-Bb703-R448a-dirty (Nov 13 2025 - 13:20:15 +0000) DRAM:testing 32-bit width, rank = 2 read calibration failed! testing 32-bit width, rank = 1 Store cfg 1st writing pattern detected 11 columns restore cfg reconfigure for all active rows store cfg 2nd writing pattern detecting row address bits detected 16 rows restoring cfg end of auto detect dram size MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 => md.l 0x047FA000 047fa000: 80000000 000009f4 0e40ff00 0000018f 047fa010: 00000010 00103040 00000000 00000000 047fa020: ffffffff 000007ff 0000ffff 00000000 ... 04800b40: 00000000 00000000 00000000 00000000 04800b50: 00000000 00000000 00000000 00000000 04800b60: 00000000 00000000 00000000 00000000 04800b70: 00000000 00000000 00000000 00000000 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.13.0(debug):armbian NOTICE: BL31: Built : 10:39:26, Nov 13 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0a4218, model: Transpeed 8K618-T INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: Probing for PMIC on I2C: INFO: PMIC: found AXP313 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.04-armbian-2025.04-S3482-Pfbbd-H8869-V9b5f-Bb703-R448a-dirty (Nov 13 2025 - 13:20:15 +0000) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: Transpeed 8K618-T DRAM: 2 GiB Core: 68 devices, 22 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: Could not get PHY for ethernet@5030000: addr 16 No ethernet found. starting USB... Bus usb@5101000: sun4i_usb_phy phy@5100400: External vbus detected, not enabling our own vbus USB EHCI 1.00 Bus usb@5101400: USB OHCI 1.0 Bus usb@5200000: USB EHCI 1.00 Bus usb@5200400: USB OHCI 1.0 scanning bus usb@5101000 for devices... 1 USB Device(s) found scanning bus usb@5101400 for devices... 1 USB Device(s) found ...
Hello all, I have a/m model with 2GiB RAM / 16GiB eMMC- Wifi: XR819 (XRadio XR819). I've download and install a .img file Armbian_community_25.11.0-trunk.437_Tanix-tx6_trixie_current_6.12.47_minimal.img.xz I want to have a server version CLI, but I don't know where to find that. My problem is that the WIFI is not availible after the boot in ARMbian. Is there any solutions for make it availible? Thank you in advance.
Renoria replied to Renoria's topic in Orange Pi 5
in the meantime I tried moving OS to SSD and kept bootloader in the SD using armbian install option 1 and it works fine… -
Hi @Efe Çetin, how do I write SPI image manually? as for the content inside SSD, this is what it shows: cat /mnt/boot/armbianEnv.txt verbosity=1 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=98220746-d581-4d83-9e96-0f31702ef529 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Thanks in advance! -
moved
- 1 reply
1
Hi....I have an Allwinner H616 H96 Max Android Box Last Week, I found this box on a shelf and wanted to boot it but it was in a bootloop So I flashed the stock firmware H616Alwinner.img and it flashed but again wifi issue...Then I made a dumb decision and asked chatgpt and it said "T95 , TX6s all share the same SoC so flash One of their .img's" So I did It flashed but now no LED but stuck on T95 logo so I tried to flash the original H616Allwinner.img again..but now it says "Error - Download Boot 1 Failed" (Honestly I Don't know how it got Hard-Bricked But I think because of the T95 flash) Now I tried Sunxi-fel but Time out....Now it's totally Super-Bricked Then I tried flashing the T95 image again it successfully flashes but the same thing but stock image "Download boot 1 failed" Can Someone Help Me to unbrick this thing and maybe install Armbian on this? 🥺 [P.S:- Even Phoenixcard wouldn't help...(When inserting SD card and normal boot or toothpick boot it does nothing ) No LED and normal boot just boots me into the failed T95] Here Is My TV Box below
The manufacturer changed the BOM list of materials to lower the product's cost, and now you have a different version with different Wi-Fi and LAN controllers. @WINEDS have some fixes: Files Link Link Link DIffWifiLanCards.zip maxio.c my_rk3566-h96-tvbox3.dtb my_rk3566-h96-tvbox3.dts my_v1_patch.patch README Release Note.txt v1_patch.patch -
@Sergey Lepeshkinok -
I did not detect the fancontrol issue sooner as I had not tested the trixie image. Indeed PrivateDevices=no should be set because helios64 and helios4 points fancontrol tu /dev symlinks prepared via udevs rules to sysfs files. I don't know if I can get rid of these udev rules, ie if I have persistend access to the proper sysfs directories for thermal and hwmon required by fancontrol on helios64. I also question why only 3 boards uses fancontrol in armbian. I had a thermal policy patch for the dts, it has the added bonus that it works when the kernel start and until it stops thus no uneeded high fan speed before fancontrol start and after it stops. But I am still wondering why kobol team chossed fancontrol and thus what are the pros and cons of fancontrol vs dts thermal policy. https://github.com/armbian/build/pull/8928 PR to set PrivateDevices=no when one upgrades armbian-bsp-cli-helios64-current or edge is in the pipe.
Jose Cardoso replied to Jose Cardoso's topic in Off-topic
Hello everyone, As I said, previous post, I’ve been trying to enable I²S audio output on my Orange Pi Zero 2W (Allwinner H618) using an external PCM5102 DAC, but so far the kernel does not recognize any sound device. I read that the driver sound/soc/sunxi/sun4i-i2s.c supports the H6, and “going” (posted March 4) suggested trying: compatible = "allwinner,sun50i-h6-i2s" to trigger that driver, since the H618 I²S block might be similar. Overlay compiles successfully using armbian-add-overlay and loads on boot. However, after reboot: dmesg | grep -i i2s dmesg | grep -i pcm aplay -l → aplay: no soundcards found... Could anyone confirm whether this driver can handle the H618 I²S, or if kernel patching is required to make it work? Any advice or example DTS overlay for H618 + I²S would be very helpful. Thanks in advance for your time and for the excellent work on Armbian Jose Cardoso -
Ah! was that simple huh. Thanks vidplace7! Got it to work once i removed the image on the flash. But I have to put it in maskrom mode if i want to use the SPI in the future which is a pain. Ah well it is fine Also lsusb now works root@luckfox-lyra-zero-w:~# lsusb Bus 001 Device 004: ID 0bda:8152 Realtek Semiconductor Corp. RTL8152 Fast Ethernet Adapter Bus 001 Device 002: ID 1a86:8091 QinHeng Electronics USB HUB Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Hello, I have a problem after update on strong leap s1, it is stuck at the android tv loading screen, I found this method (1) Mecool KD3 Stick recovery reset | XDA Forums . Basically because this box doesn't have reset button, this method is can be used to get into recovery mode from where you can factory reset the box. Problem is that it's not working for me, is there anyone with same problem ? How did you solved it, please ? Thanks
If wired correctly, dmesg reveals the following: [ 5.967316] [drm] Initialized rocket 0.0.0 for rknn on minor 0 [ 5.975499] rocket fdab0000.npu: Rockchip NPU core 0 version: 1179210309 [ 5.978652] rocket fdac0000.npu: Rockchip NPU core 1 version: 1179210309 [ 5.985602] rocket fdad0000.npu: Rockchip NPU core 2 version: 1179210309 And when mesa is built with the rocket driver enabled, it can be used via teflon.
Could you try to write SPI image to spi flash manually? (not the sata one) Also, can you send the content of /boot/armbianEnv.txt which is located in the ssd. -
# TV Box X88PRO13 My TV box is the X88PRO13. It is equipped with the RK3528 chip. I successfully running Armbian on the box. Find How To build and create Image for this BOX on http://github.com/joilg/x88pro A ready to go iso image is on https://github.com/joilg/x88pro/releases/tag/0.3 ------------------------------------------------------------------------------------------------- ## For those who have a different TV Box with RK3528 CPU, try the following procedure: The USB 2.0 and HDMI interfaces are the same for most boxes, so the console output should also be posible over HDMI here. 1. Flash MMC with the x88pro image and insert it into the box's MMC slot. 2. Connect a monitor via the HDMI interface. 3. Connect a USB keyboard to a USB port. 4. Power on the box. 5. In most cases, boot messages appear on the monitor, ending in a login prompt. 6. Follow the instructions on the monitor. ## 7. Extracting the correct DTB file binwalk /dev/mmcblk1 | grep -i "Flattened device tree" This should give output something like this: 67451654 0x4053B06 Flattened device tree, size: 99077 bytes, version: 17 67550731 0x406BE0B Flattened device tree, size: 99112 bytes, version: 17 138280448 0x83DFE00 Flattened device tree, size: 99112 bytes, version: 17 143958080 0x894A040 Flattened device tree, size: 379 bytes, version: 17 143960064 0x894A800 Flattened device tree, size: 99078 bytes, version: 17 Select the row with the largest size value. Replace the placeholders in the following commands: - `<TV_BOX_NAME>` with your box's name - `<START_ADDR>` with the first number from the selected row - `<SIZE>` with the size value from the selected row Extract the DTB file with: dd if=/dev/mmcblk1p2 of=rk3528-<TV_BOX_NAME>.dtb skip=<START_ADDR> count=<SIZE> bs=1 Copy it to boot directory: ```bash cp rk3528-<TV_BOX_NAME>.dtb /boot/dtb-6.1.115-vendor-rk35xx/rockchip/ # or cp rk3528-<TV_BOX_NAME>-android.dtb /boot/dtb-$(uname -r)/rockchip/ ``` Edit the `armbianEnv.txt` file: sed -i '/fdtfile=/c\fdtfile=rockchip/rk3528-<TV_BOX_NAME>.dtb' /boot/armbianEnv.txt sync and reboot your box. Now test if LAN, Audio, IR Remote Control, RTC ... is OK. Wifi is only implemented for the AIC8800 Chip. ### optional convert dtb file to readable DTS source file:: dtc -@ -I dtb -O dts -o rk3528-<TV_BOX_NAME>-android.dts rk3528-<TV_BOX_NAME>-android.dtb ## Additional notes I only have a X88PRO13 box, so I 'm not be able to test whether this works for your device. But it might be worth a try. ### all in one Script #! /bin/sh ## Note:** Replace all placeholders (`<TV_BOX_NAME>`, `<START_ADDR>`, `<SIZE>`) with your actual values. dd if=/dev/mmcblk1 of=rk3528-<TV_BOX_NAME>-android.dtb skip=<START_ADDR> count=<SIZE> bs=1 cp rk3528-<TV_BOX_NAME>-android.dtb /boot/dtb-$(uname -r)/rockchip/ sed -i '/fdtfile=/c\fdtfile=rockchip/rk3528-<TV_BOX_NAME>-android.dtb' /boot/armbianEnv.txt dtc -@ -I dtb -O dts -o rk3528-<TV_BOX_NAME>-android.dts rk3528-<TV_BOX_NAME>-android.dtb ``` ## contribute please report if you have success or anny problens. please contribute also Info to your box, embedded chips (wifi,RTC) and publish your DTB or DTS file.
Do you know if the access to Rockchip NPU is OK ?
odroid cloudshell2 hktft9340 kernel module missing
ELIAST replied to ELIAST's topic in Advanced users - Development
All. After some more research I could dig further, but still no picture on the tft screen. It seemes, the same probelm already popped up elsewhere: https://github.com/notro/fbtft/issues/577 by using some ideas there, I could achieve the follwoing: [ 11.299717] fbtft: module is from the staging directory, the quality is unknown, you have been warned. [ 11.305551] fb_hktft32 spi1.0: fbtft_property_value: bpp = 16 [ 11.305563] fb_hktft32 spi1.0: fbtft_property_value: debug = 0 [ 11.305574] fb_hktft32 spi1.0: fbtft_property_value: rotate = 270 [ 11.305584] fb_hktft32 spi1.0: fbtft_property_value: fps = 20 [ 4.988032] /soc/spi@12d30000/hktft_cs_ogst@0: Fixed dependency cycle(s) with /soc/spi@12d30000/hktft_cs_ogst@0/hktft_cs_ogst_pins [ 11.305404] SPI driver fb_hktft32 has no spi_device_id for odroid,hktft32 [ 11.855462] graphics fb0: fb_hktft32 frame buffer, 320x240, 150 KiB video memory, 4 KiB buffer memory, fps=20, spi1.0 at 40 MHz Which seemes the display is visible by the system now. fbset mode "320x240" geometry 320 240 320 240 16 timings 0 0 0 0 0 0 0 nonstd 1 rgba 5/11,6/5,5/0,0/0 endmode following this route: https://unix.stackexchange.com/questions/20458/how-to-use-dev-fb0-as-a-console-from-userspace-or-output-text-to-it To use the framebuffer as console you need the fbdev module. Ok, let's see this. config-6.6.113-current-odroidxu4 has reference saying ONFIG_FRAMEBUFFER_CONSOLE=y so the above referenced fbdev should already be here. The lcd scripts coming with cloudhell al trying to send text to /dev/tty1 as the output console. So I assume, I should have something similar: dmesg|grep tty [ 0.000000] Kernel command line: splash=verbose console=ttySAC2,115200n8 console=tty1 consoleblank=0 loglevel=1 root=UUID=4cac61c9-e109-4524-9fd2-c9859f87842c rootfstype=ext4 rootwait rw drm_kms_helper.edid_firmware=edid/1024x768.bin smsc95xx.macaddr=00:1e:06:61:7a:55 governor=ondemand hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=false vout=dvi usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u [ 0.002547] printk: console [tty1] enabled [ 2.122547] 12c00000.serial: ttySAC0 at MMIO 0x12c00000 (irq = 124, base_baud = 0) is a S3C6400/10 [ 2.123447] 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 125, base_baud = 0) is a S3C6400/10 [ 2.123502] printk: console [ttySAC2] enabled [ 9.707531] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ 9.716917] systemd[1]: Expecting device dev-ttySAC2.device - /dev/ttySAC2... ttySAC is the UART what I'm using at the moment. tty1 however is my main "screen", on the HDMI. So the question is, how should I able to tell the system to open an other tty console with fbdev for the LCD screen? -
Good that it can be updated quite easily, although I am not sure about longer-term. In order to see what it is, I took a quick-and-dirty approach, so not running an install script but taking NextcloudPi_RaspberryPi4_v1.55.3.zip and make that run as/via UEFI. Reason is that Raspberry's must have 2 partitions, 1st must be FAT, so this I know can co-exist with EFI booting. Most other SBC images use 1 ext4 partition, so there is no FAT boot partition where EFI/boot/bootaa64.efi can be placed. I symlink between folders 'firmware' and 'efi' in /boot/, so no change in fstab needed to get it running. It turns out the image is a bit older Armbian Bookworm, not Raspberry Pi OS, so I had to delete some script in /etc/kernel/postinst.d/ and /etc/kernel/postrm.d/ Current Armbian RPI images use a script from RPL (Raspberry Pi OS). For this case I did just direct-boot a Debian13 kernel, copied from other Debian13 Arm64 VM. Once booted, I had to do some DNS fixes (standard fixed 1.0.0.1) and install grub-efi and install it and set boot partition to type 0xEF. As indicated, this also works on a real SD-card taken from an RPI (at least the 4 and 5). The 3 needs a hybrid partition table as the bootROM does not boot from MBR type 0xEF and TianoCore UEFI won't boot from a type 0x0C or other FAT type tag. I see https://www.armbian.com/qemu-uboot-arm64/ list 2 variants, I guess first is UEFI, but have not downloaded it. I use flat/raw images, not QCOW2, so same as SD-card, USB-sticks etc. The second states U-Boot, so I think this needs direct QEMU with -bios option and rather extensive set of options. It is fine for CLI only and fast way to get a single partition image running. Both are Ubuntu and looking at x86-VMs from Nextcloud, I see Ubuntu is needed, so maybe a good starting point. Else use Armbian build.
eselarm replied to Peter Quiring's topic in Libre Sweet Potato
Make sure you can see and follow kernel messaging when initiating reboot. So another computer that taps serial serial console while you have loglevel=7 for the Potato. -
root@h96-tvbox-3566:~# dmesg [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 6.12.57-current-rockchip64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Sun Nov 2 13:15:23 UTC 2025 [ 0.000000] KASLR enabled [ 0.000000] Machine model: h96 TVbox 3566 [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: Reserved memory: No reserved-memory node in the DT [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000001ffffffff] [ 0.000000] NODE_DATA(0) allocated [mem 0x1ff7650c0-0x1ff76783f] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 0.000000] node 0: [mem 0x00000001f0000000-0x00000001ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 128 MiB at 0x00000000e3a00000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 34 pages/cpu s99416 r8192 d31656 u139264 [ 0.000000] pcpu-alloc: s99416 r8192 d31656 u139264 alloc=34*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=02d6f139-439e-4f03-b522-ea8c640bdf2c rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=981ba9e7-9a6c-4e13-8b12-c3374087ba24 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u dwmac-rk.phy_addr=1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory [ 0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=981ba9e7-9a6c-4e13-8b12-c3374087ba24 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1048064 [ 0.000000] Policy zone: Normal [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000dfa00000-0x00000000e3a00000] (64MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 320 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: MBI range [296:319] [ 0.000000] GICv3: Using MBI frame 0x00000000fd410000 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [ 0.000000] ITS: No ITS available, not enabling LPIs [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001281] Console: colour dummy device 80x25 [ 0.001303] printk: legacy console [tty1] enabled [ 0.001519] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.001546] pid_max: default: 32768 minimum: 301 [ 0.001667] LSM: initializing lsm=capability,yama,apparmor [ 0.001762] Yama: becoming mindful. [ 0.002092] AppArmor: AppArmor initialized [ 0.002255] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.002291] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.006553] rcu: Hierarchical SRCU implementation. [ 0.006578] rcu: Max phase no-delay instances is 1000. [ 0.007050] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.008342] EFI services will not be available. [ 0.008880] smp: Bringing up secondary CPUs ... [ 0.009999] Detected VIPT I-cache on CPU1 [ 0.010105] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [ 0.010168] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.011420] Detected VIPT I-cache on CPU2 [ 0.011515] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [ 0.011570] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.012992] Detected VIPT I-cache on CPU3 [ 0.013094] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [ 0.013149] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.013348] smp: Brought up 1 node, 4 CPUs [ 0.013378] SMP: Total of 4 processors activated. [ 0.013387] CPU: All CPU(s) started at EL2 [ 0.013396] CPU features: detected: 32-bit EL0 Support [ 0.013403] CPU features: detected: 32-bit EL1 Support [ 0.013414] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.013423] CPU features: detected: Common not Private translations [ 0.013431] CPU features: detected: CRC32 instructions [ 0.013447] CPU features: detected: RCpc load-acquire (LDAPR) [ 0.013454] CPU features: detected: LSE atomic instructions [ 0.013462] CPU features: detected: Privileged Access Never [ 0.013468] CPU features: detected: RAS Extension Support [ 0.013479] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.013568] alternatives: applying system-wide alternatives [ 0.018533] Memory: 3851236K/4192256K available (16832K kernel code, 2934K rwdata, 11432K rodata, 5248K init, 790K bss, 205556K reserved, 131072K cma-reserved) [ 0.020380] devtmpfs: initialized [ 0.045281] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.045339] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.049748] 23408 pages in range for non-PLT usage [ 0.049777] 514928 pages in range for PLT usage [ 0.050149] pinctrl core: initialized pinctrl subsystem [ 0.051202] DMI not present or invalid. [ 0.055961] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.058258] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.059446] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.060691] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.060779] audit: initializing netlink subsys (disabled) [ 0.061164] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1 [ 0.062444] thermal_sys: Registered thermal governor 'fair_share' [ 0.062457] thermal_sys: Registered thermal governor 'bang_bang' [ 0.062467] thermal_sys: Registered thermal governor 'step_wise' [ 0.062474] thermal_sys: Registered thermal governor 'user_space' [ 0.062575] cpuidle: using governor menu [ 0.063005] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.063244] ASID allocator initialised with 32768 entries [ 0.063588] Serial: AMBA PL011 UART driver [ 0.079115] /vop@fe040000: Fixed dependency cycle(s) with /hdmi@fe0a0000 [ 0.079248] /hdmi@fe0a0000: Fixed dependency cycle(s) with /vop@fe040000 [ 0.104599] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.105237] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000 [ 0.105729] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.106137] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000 [ 0.106815] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.107233] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000 [ 0.107690] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.108077] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000 [ 0.108521] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.108914] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000 [ 0.111037] /hdmi@fe0a0000: Fixed dependency cycle(s) with /hdmi-con [ 0.111179] /hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000 [ 0.118988] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.119013] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.119024] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.119032] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.119042] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.119049] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.119060] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.119067] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.121318] cryptd: max_cpu_qlen set to 1000 [ 0.187082] raid6: neonx8 gen() 1406 MB/s [ 0.255225] raid6: neonx4 gen() 1436 MB/s [ 0.323369] raid6: neonx2 gen() 1319 MB/s [ 0.391507] raid6: neonx1 gen() 1073 MB/s [ 0.459650] raid6: int64x8 gen() 912 MB/s [ 0.527787] raid6: int64x4 gen() 1045 MB/s [ 0.595931] raid6: int64x2 gen() 936 MB/s [ 0.664082] raid6: int64x1 gen() 691 MB/s [ 0.664097] raid6: using algorithm neonx4 gen() 1436 MB/s [ 0.732214] raid6: .... xor() 1100 MB/s, rmw enabled [ 0.732228] raid6: using neon recovery algorithm [ 0.733556] iommu: Default domain type: Translated [ 0.733576] iommu: DMA domain TLB invalidation policy: strict mode [ 0.734901] SCSI subsystem initialized [ 0.735254] libata version 3.00 loaded. [ 0.735625] usbcore: registered new interface driver usbfs [ 0.735699] usbcore: registered new interface driver hub [ 0.735755] usbcore: registered new device driver usb [ 0.736511] pps_core: LinuxPPS API ver. 1 registered [ 0.736525] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.736551] PTP clock support registered [ 0.736611] EDAC MC: Ver: 3.0.0 [ 0.737162] scmi_core: SCMI protocol bus registered [ 0.738840] NetLabel: Initializing [ 0.738854] NetLabel: domain hash size = 128 [ 0.738864] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.738962] NetLabel: unlabeled traffic allowed by default [ 0.739240] vgaarb: loaded [ 0.740044] clocksource: Switched to clocksource arch_sys_counter [ 0.745226] VFS: Disk quotas dquot_6.6.0 [ 0.745299] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.746518] AppArmor: AppArmor Filesystem Enabled [ 0.762179] NET: Registered PF_INET protocol family [ 0.762589] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.836463] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.836699] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.836818] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.837411] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear) [ 0.838375] TCP: Hash tables configured (established 32768 bind 32768) [ 0.838600] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.838728] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.839096] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.839150] NET: Registered PF_XDP protocol family [ 0.839175] PCI: CLS 0 bytes, default 64 [ 0.839616] Trying to unpack rootfs image as initramfs... [ 0.849450] kvm [1]: nv: 554 coarse grained trap handlers [ 0.850093] kvm [1]: IPA Size Limit: 40 bits [ 0.850147] kvm [1]: GICv3: no GICV resource entry [ 0.850160] kvm [1]: disabling GICv2 emulation [ 0.850210] kvm [1]: GIC system register CPU interface enabled [ 0.850255] kvm [1]: vgic interrupt IRQ9 [ 0.850315] kvm [1]: VHE mode initialized successfully [ 0.853418] Initialise system trusted keyrings [ 0.853509] Key type blacklist registered [ 0.853934] workingset: timestamp_bits=44 max_order=20 bucket_order=0 [ 0.854016] zbud: loaded [ 0.854816] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.855484] fuse: init (API version 7.41) [ 0.858338] integrity: Platform Keyring initialized [ 0.932593] xor: measuring software checksum speed [ 0.934529] 8regs : 1719 MB/sec [ 0.936661] 32regs : 1553 MB/sec [ 0.938577] arm64_neon : 1726 MB/sec [ 0.938588] xor: using function: arm64_neon (1726 MB/sec) [ 0.938609] Key type asymmetric registered [ 0.938621] Asymmetric key parser 'x509' registered [ 0.938818] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.939252] io scheduler mq-deadline registered [ 0.939271] io scheduler kyber registered [ 0.939348] io scheduler bfq registered [ 2.140739] Freeing initrd memory: 20564K [ 2.152225] ledtrig-cpu: registered to indicate activity on CPUs [ 2.162563] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.162593] dma-pl330 fe530000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.165930] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.165958] dma-pl330 fe550000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.169241] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 2.175501] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 25, base_baud = 1500000) is a 16550A [ 2.176112] serial serial0: tty port ttyS1 registered [ 2.177966] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 26, base_baud = 1500000) is a 16550A [ 2.178226] printk: legacy console [ttyS2] enabled [ 2.179993] Serial: AMBA driver [ 2.193516] loop: module loaded [ 2.195458] Key type psk registered [ 2.201340] thunder_xcv, ver 1.0 [ 2.201425] thunder_bgx, ver 1.0 [ 2.201493] nicpf, ver 1.0 [ 2.212937] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 2.212991] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 2.213204] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports [ 2.213222] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010 [ 2.213303] xhci-hcd xhci-hcd.0.auto: irq 30, io mem 0xfcc00000 [ 2.213819] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.213843] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.213858] usb usb1: Product: xHCI Host Controller [ 2.213870] usb usb1: Manufacturer: Linux 6.12.57-current-rockchip64 xhci-hcd [ 2.213882] usb usb1: SerialNumber: xhci-hcd.0.auto [ 2.214743] hub 1-0:1.0: USB hub found [ 2.214812] hub 1-0:1.0: 1 port detected [ 2.215548] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.215587] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 2.215779] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010 [ 2.215851] xhci-hcd xhci-hcd.1.auto: irq 31, io mem 0xfd000000 [ 2.216153] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.216182] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3 [ 2.216206] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 2.216505] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.216528] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.216543] usb usb2: Product: xHCI Host Controller [ 2.216555] usb usb2: Manufacturer: Linux 6.12.57-current-rockchip64 xhci-hcd [ 2.216567] usb usb2: SerialNumber: xhci-hcd.1.auto [ 2.217325] hub 2-0:1.0: USB hub found [ 2.217394] hub 2-0:1.0: 1 port detected [ 2.218015] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM. [ 2.218264] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12 [ 2.218287] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.218302] usb usb3: Product: xHCI Host Controller [ 2.218314] usb usb3: Manufacturer: Linux 6.12.57-current-rockchip64 xhci-hcd [ 2.218326] usb usb3: SerialNumber: xhci-hcd.1.auto [ 2.219048] hub 3-0:1.0: USB hub found [ 2.219130] hub 3-0:1.0: 1 port detected [ 2.219836] usbcore: registered new interface driver usb-storage [ 2.222714] mousedev: PS/2 mouse device common for all mice [ 2.223443] i2c_dev: i2c /dev entries driver [ 2.229358] rockchip-thermal fe710000.tsadc: Missing tshut mode property, using default (gpio) [ 2.229390] rockchip-thermal fe710000.tsadc: Missing tshut-polarity property, using default (low) [ 2.233395] sdhci: Secure Digital Host Controller Interface driver [ 2.233419] sdhci: Copyright(c) Pierre Ossman [ 2.233468] Synopsys Designware Multimedia Card Interface Driver [ 2.234545] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.237311] arm-scmi arm-scmi.2.auto: Using scmi_smc_transport [ 2.237337] arm-scmi arm-scmi.2.auto: SCMI max-rx-timeout: 30ms [ 2.237556] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16 [ 2.237954] arm-scmi arm-scmi.2.auto: SCMI Notifications - Core Enabled. [ 2.238043] arm-scmi arm-scmi.2.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 2.239622] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 2.239958] hid: raw HID events driver (C) Jiri Kosina [ 2.240590] usbcore: registered new interface driver usbhid [ 2.240605] usbhid: USB HID core driver [ 2.242290] rockchip-dfi fe230000.dfi: dfi initialized, dram type: 0x8, channels: 1 [ 2.244433] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available [ 2.246189] NET: Registered PF_INET6 protocol family [ 2.307474] Segment Routing with IPv6 [ 2.307622] In-situ OAM (IOAM) with IPv6 [ 2.307751] NET: Registered PF_PACKET protocol family [ 2.307832] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 2.308191] Key type dns_resolver registered [ 2.322627] registered taskstats version 1 [ 2.323107] Loading compiled-in X.509 certificates [ 2.342427] zswap: loaded using pool zstd/zbud [ 2.342962] Demotion targets for Node 0: null [ 2.343508] Key type .fscrypt registered [ 2.343523] Key type fscrypt-provisioning registered [ 2.348171] Btrfs loaded, zoned=yes, fsverity=yes [ 2.348460] Key type encrypted registered [ 2.348484] AppArmor: AppArmor sha256 policy hashing enabled [ 2.391112] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [ 2.505752] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [ 2.505841] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [ 2.505859] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [ 2.505923] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo [ 2.506096] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 2.506167] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 2.506186] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 2.506263] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo [ 2.508493] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO [ 2.509670] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq [ 2.509699] mmc_host mmc2: card is non-removable. [ 2.520556] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 2.524818] WCN: marlin_init entry! [ 2.525509] of_cfs_init [ 2.525576] of_cfs_init: OK [ 2.544299] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA [ 2.576559] clk: Disabling unused clocks [ 2.577449] PM: genpd: Disabling unused power domains [ 2.626663] mmc1: new HS200 MMC card at address 0001 [ 2.627719] mmcblk1: mmc1:0001 032G74 29.1 GiB [ 2.632265] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 2.633175] mmcblk1: p1 [ 2.634102] mmcblk1boot0: mmc1:0001 032G74 4.00 MiB [ 2.636494] mmcblk1boot1: mmc1:0001 032G74 4.00 MiB [ 2.638579] mmcblk1rpmb: mmc1:0001 032G74 4.00 MiB, chardev (243:0) [ 2.647995] Freeing unused kernel memory: 5248K [ 2.648340] Run /init as init process [ 2.648354] with arguments: [ 2.648364] /init [ 2.648374] with environment: [ 2.648382] HOME=/ [ 2.648391] TERM=linux [ 2.648399] splash=verbose [ 2.648407] ubootpart=981ba9e7-9a6c-4e13-8b12-c3374087ba24 [ 2.648417] cgroup_enable=memory [ 2.648426] cgroup_memory=1 [ 2.665863] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 100000000Hz, actual 50000000HZ div = 0) [ 2.840151] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 173 [ 2.843621] mmc2: new ultra high speed SDR50 SDIO card at address 390b [ 3.208313] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd [ 3.225766] usb 3-1: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=31.04 [ 3.225806] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [ 3.225821] usb 3-1: Product: USB 10/100/1G/2.5G LAN [ 3.225833] usb 3-1: Manufacturer: Realtek [ 3.225844] usb 3-1: SerialNumber: 4013000001 [ 3.386799] usbcore: registered new device driver r8152-cfgselector [ 3.592883] r8152-cfgselector 3-1: reset SuperSpeed USB device number 2 using xhci-hcd [ 3.720274] r8152 3-1:1.0 eth0: v1.12.13 [ 3.720479] usbcore: registered new interface driver r8152 [ 3.724881] usbcore: registered new interface driver cdc_ether [ 3.727119] usbcore: registered new interface driver cdc_ncm [ 3.814188] rockchip-vop2 fe040000.vop: Adding to iommu group 0 [ 3.830334] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) [ 3.837545] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 3.845616] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 3.846347] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) [ 3.847804] rk808-rtc rk808-rtc.6.auto: registered as rtc0 [ 3.849294] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 [ 3.849556] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 3.849713] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 3.851651] rk808-rtc rk808-rtc.6.auto: setting system clock to 2025-11-11T14:23:04 UTC (1762870984) [ 3.914828] dwmac_rk: unknown parameter 'phy_addr' ignored [ 3.916833] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 3.916867] rk_gmac-dwmac fe010000.ethernet: IRQ sfty not found [ 3.926725] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 3.926762] rk_gmac-dwmac fe010000.ethernet: TX delay(0x41). [ 3.926780] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2e). [ 3.926807] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 3.926882] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 3.932126] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 3.932639] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 3.932676] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 3.932692] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 3.932704] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 3.932715] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 3.932724] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 3.932884] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 3.932903] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.932918] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 3.932931] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 3.932943] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 4.004256] i2c i2c-7: Not I2C compliant: can't read SDA [ 4.004288] i2c i2c-7: Not I2C compliant: can't read SCL [ 4.004299] i2c i2c-7: Bus may be unreliable [ 4.004314] i2c-gpio i2c-aux-display: using lines 12 (SDA) and 11 (SCL, no clock stretching) [ 4.044582] r8152 3-1:1.0 enx00e04c1800a5: renamed from eth0 [ 4.258180] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 [ 4.424695] r8152-cfgselector 3-1: reset SuperSpeed USB device number 2 using xhci-hcd [ 4.540302] r8152 3-1:1.0 eth0: v1.12.13 [ 4.634763] r8152 3-1:1.0 enx00e04c1800a5: renamed from eth0 [ 4.790481] EXT4-fs (mmcblk1p1): mounted filesystem 02d6f139-439e-4f03-b522-ea8c640bdf2c ro with writeback data mode. Quota mode: none. [ 5.297007] systemd[1]: Inserted module 'autofs4' [ 5.355293] systemd[1]: systemd 257.8-1~deb13u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE) [ 5.355403] systemd[1]: Detected architecture arm64. [ 5.364981] systemd[1]: Hostname set to <h96-tvbox-3566>. [ 5.876905] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported. [ 5.991722] dw-apb-uart fe660000.serial: forbid DMA for kernel console [ 6.773136] systemd[1]: Queued start job for default target graphical.target. [ 6.826887] systemd[1]: Created slice system-getty.slice - Slice /system/getty. [ 6.831223] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [ 6.835310] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ 6.838382] systemd[1]: Created slice user.slice - User and Session Slice. [ 6.839385] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch. [ 6.840277] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [ 6.841981] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point. [ 6.842539] systemd[1]: Expecting device dev-ttyS2.device - /dev/ttyS2... [ 6.843079] systemd[1]: Reached target paths.target - Path Units. [ 6.843532] systemd[1]: Reached target remote-fs.target - Remote File Systems. [ 6.843941] systemd[1]: Reached target slices.target - Slice Units. [ 6.844476] systemd[1]: Reached target swap.target - Swaps. [ 6.845734] systemd[1]: Listening on syslog.socket - Syslog Socket. [ 6.853290] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption. [ 6.854452] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [ 6.855496] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [ 6.856831] systemd[1]: Listening on systemd-journald.socket - Journal Sockets. [ 6.858261] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket. [ 6.858829] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 6.858989] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 6.859788] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [ 6.860809] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [ 6.868820] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System... [ 6.875789] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System... [ 6.883809] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock... [ 6.891566] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System... [ 6.909632] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System... [ 6.925815] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... [ 6.970432] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout... [ 6.989909] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes... [ 6.999439] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs... [ 7.016730] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 7.037942] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 7.059514] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse... [ 7.060409] systemd[1]: netplan-ovs-cleanup.service - OpenVSwitch configuration for cleanup was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/ovs-vsctl). [ 7.060997] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 7.113475] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 7.129285] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line... [ 7.132663] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.133330] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.153188] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials... [ 7.164339] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 7.208461] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [ 7.209936] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 7.211358] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock. [ 7.221176] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 7.222703] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [ 7.228820] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 7.246829] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 7.250903] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 7.253861] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.255423] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 7.270398] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.272244] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 7.275573] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.277399] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 7.280512] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.282574] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ 7.293411] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 7.320774] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 7.321188] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 7.345629] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... [ 7.361655] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully... [ 7.373739] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ 7.388633] systemd[1]: Finished systemd-network-generator.service - Generate network units from Kernel command line. [ 7.412625] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials. [ 7.425447] systemd[1]: Reached target network-pre.target - Preparation for Network. [ 7.455126] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 7.477400] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 7.523185] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 7.563259] EXT4-fs (mmcblk1p1): re-mounted 02d6f139-439e-4f03-b522-ea8c640bdf2c r/w. [ 7.572446] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ 7.575034] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 7.575497] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 7.586713] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed... [ 7.587098] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.619384] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully. [ 7.621241] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 7.638610] systemd[1]: Starting systemd-timesyncd.service - Network Time Synchronization... [ 7.646668] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev... [ 7.651899] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout. [ 7.688863] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [ 7.716572] systemd[1]: Starting systemd-resolved.service - Network Name Resolution... [ 7.791053] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev. [ 7.794063] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems. [ 7.845106] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files... [ 8.169507] systemd[1]: Started systemd-timesyncd.service - Network Time Synchronization. [ 8.170957] systemd[1]: Reached target time-set.target - System Time Set. [ 8.225270] systemd[1]: Mounting tmp.mount - /tmp... [ 8.387879] systemd[1]: Mounted tmp.mount - /tmp. [ 8.389334] systemd[1]: Reached target local-fs.target - Local File Systems. [ 8.398427] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management. [ 8.406047] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config... [ 8.421472] systemd[1]: Starting console-setup.service - Set console font and keymap... [ 8.454177] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats... [ 8.529036] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files. [ 8.597230] systemd[1]: Starting systemd-networkd.service - Network Configuration... [ 8.673984] systemd[1]: Finished console-setup.service - Set console font and keymap. [ 8.677763] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ 8.718705] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 263 (systemd-binfmt) [ 8.728692] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System... [ 8.871880] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System. [ 8.894538] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats. [ 9.541067] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 9.590243] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 9.591405] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 9.628819] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2. [ 9.946399] systemd[1]: Started systemd-networkd.service - Network Configuration. [ 9.972186] systemd[1]: Starting systemd-networkd-persistent-storage.service - Enable Persistent Storage in systemd-networkd... [ 9.983471] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 10.008535] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL) [ 10.030686] zram: Added device: zram0 [ 10.033372] zram: Added device: zram1 [ 10.155162] zram: Added device: zram2 [ 10.158668] r8152 3-1:1.0 enx00e04c1800a5: carrier on [ 10.292232] r8152 3-1:1.0 enx00e04c1800a5: Stop submitting intr, status -108 [ 10.331582] zram0: detected capacity change from 0 to 4012512 [ 10.393579] mc: Linux media interface: v0.10 [ 10.470481] panfrost fde60000.gpu: clock rate = 594000000 [ 10.470515] panfrost fde60000.gpu: bus_clock rate = 500000000 [ 10.489544] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0 [ 10.489565] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400 [ 10.489574] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7 [ 10.489582] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1 [ 10.490260] videodev: Linux video capture interface: v2.00 [ 10.577203] [drm] Initialized panfrost 1.2.0 for fde60000.gpu on minor 1 [ 10.591955] rockchip-rga fdeb0000.rga: HW Version: 0x03.02 [ 10.596084] random: crng init done [ 10.601538] rockchip-rga fdeb0000.rga: Registered rockchip-rga as /dev/video0 [ 10.618482] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed. [ 10.619483] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes). [ 10.619710] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 10.640697] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey.5.auto/input/input0 [ 10.652485] rockchip_vdec2: module is from the staging directory, the quality is unknown, you have been warned. [ 10.694123] hantro-vpu fdea0000.video-codec: Adding to iommu group 1 [ 10.696776] hantro-vpu fdea0000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2 [ 10.714076] rk2-crypto fe380000.crypto: will run requests pump with realtime priority [ 10.714157] rk2-crypto fe380000.crypto: Registers crypto algos [ 10.714166] rk2-crypto fe380000.crypto: Register ecb(aes) as ecb-aes-rk2 [ 10.714231] rk2-crypto fe380000.crypto: Register cbc(aes) as cbc-aes-rk2 [ 10.714252] rk2-crypto fe380000.crypto: Register xts(aes) as xts-aes-rk2 [ 10.714267] rk2-crypto fe380000.crypto: Register md5 as rk2-md5 3 [ 10.714284] rk2-crypto fe380000.crypto: Register sha1 as rk2-sha1 4 [ 10.714302] rk2-crypto fe380000.crypto: Register sha256 as rk2-sha256 5 [ 10.714318] rk2-crypto fe380000.crypto: Register sha384 as rk2-sha384 6 [ 10.714333] rk2-crypto fe380000.crypto: Register sha512 as rk2-sha512 7 [ 10.714535] rk2-crypto fe380000.crypto: Register sm3 as rk2-sm3 8 [ 10.751177] Adding 2006252k swap on /dev/zram0. Priority:5 extents:1 across:2006252k SS [ 10.808239] hantro-vpu fdee0000.video-codec: Adding to iommu group 2 [ 10.810297] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video3 [ 10.810421] zram1: detected capacity change from 0 to 102400 [ 10.820225] tm16xx 7-0024: Failed to count 'tm16xx,digits' property: -22 [ 10.820248] tm16xx 7-0024: Failed to parse device tree: -22 [ 10.820259] tm16xx 7-0024: probe with driver tm16xx failed with error -22 [ 10.846289] rc_core: IR keymap rc-h96-max-v56 not found [ 10.846313] Registered IR keymap rc-empty [ 10.851168] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0 [ 10.851434] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter [ 10.855121] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input1 [ 10.926103] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config. [ 10.936262] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging... [ 10.954672] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 10.968325] Bluetooth: Core ver 2.22 [ 10.968448] NET: Registered PF_BLUETOOTH protocol family [ 10.968456] Bluetooth: HCI device and connection manager initialized [ 10.968474] Bluetooth: HCI socket layer initialized [ 10.968484] Bluetooth: L2CAP socket layer initialized [ 10.968503] Bluetooth: SCO socket layer initialized [ 11.012098] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma [ 11.012123] rk_gmac-dwmac fe010000.ethernet end0: stmmac_hw_setup: DMA engine initialization failed [ 11.012131] rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Hw setup failed [ 11.044607] Bluetooth: HCI UART driver ver 2.3 [ 11.044633] Bluetooth: HCI UART protocol H4 registered [ 11.044639] Bluetooth: HCI UART protocol BCSP registered [ 11.044779] Bluetooth: HCI UART protocol LL registered [ 11.044790] Bluetooth: HCI UART protocol ATH3K registered [ 11.044838] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 11.045063] Bluetooth: HCI UART protocol Intel registered [ 11.045309] Bluetooth: HCI UART protocol Broadcom registered [ 11.045367] Bluetooth: HCI UART protocol QCA registered [ 11.045374] Bluetooth: HCI UART protocol AG6XX registered [ 11.045522] Bluetooth: HCI UART protocol Marvell registered [ 11.095556] systemd[1]: Finished systemd-networkd-persistent-storage.service - Enable Persistent Storage in systemd-networkd. [ 11.100938] systemd[1]: Started systemd-resolved.service - Network Name Resolution. [ 11.101642] systemd[1]: Reached target nss-lookup.target - Host and Network Name Lookups. [ 11.105767] EXT4-fs (zram1): mounted filesystem d6c591d9-9d4c-4557-8ea0-5f3d92af56b4 r/w without journal. Quota mode: none. [ 11.171923] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... [ 11.180756] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 11.181195] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 11.181653] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 11.182018] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 11.182142] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 11.182577] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 11.182735] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 11.182793] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 11.244673] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 11.245782] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 11.247146] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 11.251701] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 11.252756] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 11.290376] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status... [ 11.305084] systemd[1]: Reached target bluetooth.target - Bluetooth Support. [ 11.336641] r8152-cfgselector 3-1: reset SuperSpeed USB device number 2 using xhci-hcd [ 11.375270] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status. [ 11.409769] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging. [ 11.419266] systemd[1]: Starting systemd-journald.service - Journal Service... [ 11.450982] r8152 3-1:1.0 eth0: v1.12.13 [ 11.548954] systemd-journald[421]: Collecting audit messages is disabled. [ 11.554558] r8152 3-1:1.0 enx00e04c1800a5: renamed from eth0 [ 11.704869] systemd[1]: Started systemd-journald.service - Journal Service. [ 11.801857] systemd-journald[421]: Received client request to flush runtime journal. [ 11.811394] systemd-journald[421]: /var/log/journal/0e22646d717c4ecf971d5dab53ffb0a6/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating. [ 11.811453] systemd-journald[421]: Rotating system journal. [ 12.560089] systemd-journald[421]: Received client request to relinquish /var/log/journal/0e22646d717c4ecf971d5dab53ffb0a6 access. [ 13.316103] Bluetooth: hci0: command 0xfc18 tx timeout [ 13.316164] Bluetooth: hci0: BCM: failed to write update baudrate (-110) [ 13.316174] Bluetooth: hci0: Failed to set baudrate [ 14.381288] r8152 3-1:1.0 enx00e04c1800a5: carrier on [ 15.332133] Bluetooth: hci0: command 0xfc18 tx timeout [ 15.332199] Bluetooth: hci0: BCM: Reset failed (-110) [ 21.222972] platform spdif-sound: deferred probe pending: asoc-simple-card: parse error [ 21.223026] platform rk809-sound: deferred probe pending: asoc-simple-card: parse error [ 1238.828322] systemd-journald[421]: Received client request to flush runtime journal. [ 1238.872397] systemd-journald[421]: Received client request to relinquish /var/log/journal/0e22646d717c4ecf971d5dab53ffb0a6 access. [36038.097713] systemd-journald[421]: Received client request to flush runtime journal. [36038.152376] systemd-journald[421]: Received client request to relinquish /var/log/journal/0e22646d717c4ecf971d5dab53ffb0a6 access. Could you please tell me what's wrong with my device? It has no network adapter and no Bluetooth functionality.Thank you!
