  2. I have now built the module with the armbian build framework and then it works.
  3. xNiux
    Odroid M2 16G
    I tried the lastest version "Armbian_community_25.11.0-trunk.472_Odroidm2_trixie_edge_6.18.0-rc5_minimal.img". But NPU is not mentioned in dmesg. Also, I have this red line. what could be the effect on the system ?
  4. Hi, just to give a maybe final feedback on this topic: Although it is not a really satisfying solution, I decided to switch off the sysrq functionality by setting kernel.sysrq=0 in /etc/sysctl.conf. This was 1 month ago and there were no sysrq events in my logs since then. So for now this is a "good enough" solution for me. Thank you all for your support, I learned again a lot ...
  5. You should check uboot logs if the dtbo is loaded correctly. You can get those using a debug serial console. If you don't know what that is or how to connect: https://debug.armbian.de
  6. @blackc Exact the original U-boot DRAM settings from your boot.bin or an update. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/23/#findComment-218660 If you are still having issues ask the sunxi guys on IRC. https://oftc.catirclogs.org/linux-sunxi/2025-11-14
  7. Hello, I've been using https://joshua-riek.github.io/ubuntu-rockchip-download/boards/orangepi-5-plus.html with a custom kernel that I built to activate my TPM2.0 device and it works. Now I'm asked to use an UEFI compatible image with my Orange Pi 5 Plus. So what I did is more or less the same thing that in here But instead of the legacy kernel I used the 6.1.115-rockchip-vendor-rk35xx kernel and my device booted, I got an HDMI output, etc. And then I updated it to my custom kernel (6.1.0-1027-rockchip) that has the necessary configurations to allow TPM over SPI. Now I'm trying to activate my TPM2.0 as I did before. To do that I added my compiled *.dtbo (rk3588-spi0-tpm-cs1.dtbo) to /boot/dtb/rockchip/overlay and activated it with armbian-config. After reboot this is my /boot/armbianEnv.txt orangepi@uefi-arm64:~$ cat /boot/armbianEnv.txt verbosity=1 bootlogo=true console=both extraargs=cma=256M overlay_prefix=rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdev=UUID=3e555b58-fdf4-4e2f-a3af-a8ecfd8034b6 rootfstype=ext4 overlays=spi0-tpm-cs1 param_spidev_spi_bus=0 However I still can't see my tpm under /dev/. I don't know what I'm missing, I'm quite new to this sorry Thank you for your time
  8. Could you please tell me in detail how to use these files? My knowledge of Linux is very limited. Do I need to recompile a custom image suitable for myself, or how should I use these files to carry out specific operations to solve my problem? Thank you.
  9. I am an Linux Beginner and I only can use Terminal for copy/paste issues. For many months my Raspberry Pi 5 runs perfectly with Armbian. But when I try to update the system in the Discover App, I get the following error message: The following packages have unmet dependencies: kpim6-akonadi: Kollidiert mit: knotes but 4:24.05.2+p24.04+vstable+git20240705.1500-0 is to be installed Kollidiert mit: kpim6-akonadi-notes but 4:24.08.3+p24.04+vstable+git20241129.1417-0 is to be installed Can someone please help me to get my system up-to-date? Thanks in advance!
  10. Yes, i know, but i think this is mostly UBoot DRAM controller parameters problem. May be someone have any suggestions about it...
  11. Armbian Bookworm 25.8.1. (minimal) Odroid XU4 with 32GB eMMc After lots of searching and trying 2017 Hardkernel solutions and github etc - And this forum suggestions - I could never get get it to boot. I think this is partly because things have changed since 2016/17. I did not have my eMMc on an usb adapter. Just installed, brand new (untouched from China) eMMc and a imaage install on MicroSD of Armbian. The method I believed should work was "armbian-install". But, it had errors while using mkpartimage. I put debug statements in the script and found the particular instance of invoking mkpartimage. Actually the issue is; 2 files are missing from /boot folder. Current SD installation image of Armbian minimal only creates one fdisk (MBR) partition on which /boot is a folder. I tried for ages to create a separate /boot partition. Maybe, since I have now succeeded with an eMMc install, I might try doing a separate root and boot. The 2 missing files are armbianEnv.txt and boot.cmd If one "touch"es armbianEnv.txt then - if it doesn't exist it will be created - if it does then no harm done. If one copies boot.ini to boot.cmd then these two things will satisfy armbian-install. Amrbian-install correctly changes the R/O of mmcblkXboot1 (where X is emmc device number) write the boot stuff and markit back R/O. It also ensures that armbianEnv.txt has got correct entries in it. In summary Install eMMc and Micro SD in XU4 Ensure SD/eMMc switch set to SD and boot armbian from SD Login as root or use sudo touch /boot/armbianEnv.txt cp /boot/boot.ini /boot/boot.cmd armbian-install choose the install and boot from eMMc option shutdown change switch to boot armbian from eMMc boot
  12. Hi @djurny Just to inform you that, after cleaning out some mess I made, your overlay and armbianEnv.txt update to make the external RTC ds3231 to work, did the job. For my SBC's I use the Banana Pi M2 Zero and v25.5 rolling for Banana Pi M2 Zero running Armbian Linux 6.6.75-current-sunxi My application needs to work in the field as an Access Point with an RTC, the right date and time is important info in the diagnostics of my applications. A remark on the mentioned Armbian release: For using the GPIO pins of the SBC, python3-libgpiod works great. I use USB camera's (V4L2 camera). After any update or upgrade, my USB camera's won't work anymore. Not really a problem for me, because I'm happy as it works right now, no updates or upgrades needed. Thanks again for your great help. Met vriendelijke groet, Ed
  13. https://github.com/armbian/build/blob/main/config/boards/retroidpocket-rp5.csc https://github.com/armbian/build/blob/main/config/boards/retroidpocket-rpmini.csc You can build images on your own. https://docs.armbian.com/User-Guide_Board-Support-Rules/#community-maintained
  14. You need to seek support from his repo. We only can support builds from: https://github.com/armbian/build/
  15. This post from February 2025 claims that RP5 and RPMini are supported: https://www.armbian.com/newsflash/armbian-v25-2/ however, I can't find them on the downloads page. I also don't currently own an RPMini, I am tempted to buy one but I wanted to make sure it was supported first. What's the state of support right now?
  16. Using odroidxu4. flashed Armbian_25.8.1_Odroidxu4_noble_current_6.6.102 to eMMC After odroidxu4 started, followed instruction to create accounts etc. Installed xfce4 package reboot. odroidxu4 booted to console prompt Installed xfce4-goodies package reboot. odroidxu4 booted to console prompt Installed lightdm reboot. The system becomes stuck at plymouth-quit-wait.service/start Not much I could do after this as I could not look at log messages or use $ sudo systemctl status lightdm.service Any insight greatly appreciated Thanks
  17. Yesterday
  18. Choose install/update bootloader on spi flash option on armbian-install. Some uart logs could be useful if you have usb-ttl converter stuff
  19. Hello! I have a T95MAX ver 3 board with H616 / AXP313 / 4Gb RAM. I've compiled an Armbian from Nick repo (https://github.com/NickAlilovic/build), branch v20251014 for Transpeed-8k618 with a little defconfig patch for TOC0 and DCDC3 voltage = 1.5V (extracted from Android native image DTB). CONFIG_AXP_DCDC3_VOLT=1500 CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y Image booting ok, but first UBoot stage found 4Gb and second stage found only 2Gb. Someone have any ideas for make 2nd stage and kernel detect full memory? U-Boot SPL 2025.04-armbian-2025.04-S3482-Pfbbd-H8869-V9b5f-Bb703-R448a-dirty (Nov 13 2025 - 13:20:15 +0000) DRAM:testing 32-bit width, rank = 2 read calibration failed! testing 32-bit width, rank = 1 Store cfg 1st writing pattern detected 11 columns restore cfg reconfigure for all active rows store cfg 2nd writing pattern detecting row address bits detected 16 rows restoring cfg end of auto detect dram size MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 => md.l 0x047FA000 047fa000: 80000000 000009f4 0e40ff00 0000018f 047fa010: 00000010 00103040 00000000 00000000 047fa020: ffffffff 000007ff 0000ffff 00000000 ... 04800b40: 00000000 00000000 00000000 00000000 04800b50: 00000000 00000000 00000000 00000000 04800b60: 00000000 00000000 00000000 00000000 04800b70: 00000000 00000000 00000000 00000000 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.13.0(debug):armbian NOTICE: BL31: Built : 10:39:26, Nov 13 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0a4218, model: Transpeed 8K618-T INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: Probing for PMIC on I2C: INFO: PMIC: found AXP313 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.04-armbian-2025.04-S3482-Pfbbd-H8869-V9b5f-Bb703-R448a-dirty (Nov 13 2025 - 13:20:15 +0000) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: Transpeed 8K618-T DRAM: 2 GiB Core: 68 devices, 22 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: Could not get PHY for ethernet@5030000: addr 16 No ethernet found. starting USB... Bus usb@5101000: sun4i_usb_phy phy@5100400: External vbus detected, not enabling our own vbus USB EHCI 1.00 Bus usb@5101400: USB OHCI 1.0 Bus usb@5200000: USB EHCI 1.00 Bus usb@5200400: USB OHCI 1.0 scanning bus usb@5101000 for devices... 1 USB Device(s) found scanning bus usb@5101400 for devices... 1 USB Device(s) found ...
  20. Hello all, I have a/m model with 2GiB RAM / 16GiB eMMC- Wifi: XR819 (XRadio XR819). I've download and install a .img file Armbian_community_25.11.0-trunk.437_Tanix-tx6_trixie_current_6.12.47_minimal.img.xz I want to have a server version CLI, but I don't know where to find that. My problem is that the WIFI is not availible after the boot in ARMbian. Is there any solutions for make it availible? Thank you in advance.
  21. in the meantime I tried moving OS to SSD and kept bootloader in the SD using armbian install option 1 and it works fine…
  22. Hi @Efe Çetin, how do I write SPI image manually? as for the content inside SSD, this is what it shows: cat /mnt/boot/armbianEnv.txt verbosity=1 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=98220746-d581-4d83-9e96-0f31702ef529 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Thanks in advance!
  23. moved
  24. Hi....I have an Allwinner H616 H96 Max Android Box Last Week, I found this box on a shelf and wanted to boot it but it was in a bootloop So I flashed the stock firmware H616Alwinner.img and it flashed but again wifi issue...Then I made a dumb decision and asked chatgpt and it said "T95 , TX6s all share the same SoC so flash One of their .img's" So I did It flashed but now no LED but stuck on T95 logo so I tried to flash the original H616Allwinner.img again..but now it says "Error - Download Boot 1 Failed" (Honestly I Don't know how it got Hard-Bricked But I think because of the T95 flash) Now I tried Sunxi-fel but Time out....Now it's totally Super-Bricked Then I tried flashing the T95 image again it successfully flashes but the same thing but stock image "Download boot 1 failed" Can Someone Help Me to unbrick this thing and maybe install Armbian on this? 🥺 [P.S:- Even Phoenixcard wouldn't help...(When inserting SD card and normal boot or toothpick boot it does nothing ) No LED and normal boot just boots me into the failed T95] Here Is My TV Box below
  25. The manufacturer changed the BOM list of materials to lower the product's cost, and now you have a different version with different Wi-Fi and LAN controllers. @WINEDS have some fixes: Files Link Link Link DIffWifiLanCards.zip maxio.c my_rk3566-h96-tvbox3.dtb my_rk3566-h96-tvbox3.dts my_v1_patch.patch README Release Note.txt v1_patch.patch
  26. I did not detect the fancontrol issue sooner as I had not tested the trixie image. Indeed PrivateDevices=no should be set because helios64 and helios4 points fancontrol tu /dev symlinks prepared via udevs rules to sysfs files. I don't know if I can get rid of these udev rules, ie if I have persistend access to the proper sysfs directories for thermal and hwmon required by fancontrol on helios64. I also question why only 3 boards uses fancontrol in armbian. I had a thermal policy patch for the dts, it has the added bonus that it works when the kernel start and until it stops thus no uneeded high fan speed before fancontrol start and after it stops. But I am still wondering why kobol team chossed fancontrol and thus what are the pros and cons of fancontrol vs dts thermal policy. https://github.com/armbian/build/pull/8928 PR to set PrivateDevices=no when one upgrades armbian-bsp-cli-helios64-current or edge is in the pipe.
