Hi everyone, wanted to share what we found attempting Armbian support for Zero2. Zero2 utilises an Android-style partition layout from FriendlyElec, which I found to be fundamentally incompatible with Armbian's partition scheme. It seems to use an Android layout (boot at partition 4, rootfs at partition 8, etc.) vs Armbian's standard GPT layout. U-Boot is configured to look for partitions at specific Android-style locations Zero2 assigns SD=mmcblk0, eMMC=mmcblk2 (opposite of typical RK3528 boards) What I think is needed: Adapt hinlink_rk3528_defconfig for Android partition layout Modify partition table generation in the Armbian build system Update bootloader scripts to match partition locations Handle the inverted mmcblk device assignments LED mapping adjustments (Zero2 uses 2-LED system: sys_led, user_led vs typical 3-LED RK3528 boards) Network interface detection (single ethernet vs dual on R3S/hinlink) The device tree is already merged (rk3528-nanopi-zero2.dtb - thanks Jonas!), so that part is straightforward. It's specifically the bootloader/partition integration that's the blocker. Would love to hear thoughts. For now as a workaround, we've stayed with FriendlyElec's Ubuntu base to keep our project moving.
Helios64 download links all seem to lead nowhere
slymanjojo replied to BacchusIX's topic in Rockchip
Glad I fell on this post Igor, Thank you for the share.. (download was indeed really fast!) I managed to install without any issues. (been using buster for way too long) Cheers, Again thanks in advance! -
I already see what the issue is: I have configured things in such a way that strange/new machines get served differently then known/existing ones. In addition, the known/existing ones need an extra setting in case of systemd-resolved. This makes a quick test with some random VM like this appear doing things wrong, but is actually expected. If I purge --autoremove netplan.io and put a symlink ln -sf /usr/lib/systemd/network/89-ethernet.network.example /etc/systemd/network/89-ethernet.network, there is working network again after reboot or restart service.
Same trick as in but with N2+ image sha256sum: 5627794e883fc3b8b9ccf918efe4e5427621761402e8e2d10b05730495fc19ce Armbian_25.11.1_Odroidn2_trixie_current_6.12.58_minimal.i mg.xz and 1 reboot, then with armbian-config set my timezone to CET and reboot again: root@odroidn2:~# timedatectl Local time: Fri 2025-11-28 19:50:36 CET Universal time: Fri 2025-11-28 18:50:36 UTC RTC time: Fri 2025-11-28 18:59:21 Time zone: Europe/Amsterdam (CET, +0100) System clock synchronized: no NTP service: active RTC in local TZ: no root@odroidn2:~# timedatectl Local time: Fri 2025-11-28 20:00:31 CET Universal time: Fri 2025-11-28 19:00:31 UTC RTC time: Fri 2025-11-28 19:00:32 Time zone: Europe/Amsterdam (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no It seems it took several seconds for a sync, but nothing strange I think. However, important notice is that networking has picked the wrong DNS server; It seems to assume 'router IP = DNS IP' which is not the case in my case, so several things fail, especially in-house things, not what goes outside. This is not the case when network-manager+openresolv do the network config (and no netplan.io). I run 2 computers with systemd-networkd+systemd-resolved, but that took a lot of time and reading and some config tweaking before those do simply the same as before with network-manager+openresolv. And no benefit, only that they can run slightly easier as container with own MAC-address (real HW must be off then of course) and also a bit easier as container host.
Seems you are using redhat kernel. it means something wrong changed in armbian meson64 kernel config after 6.16.??
gpupoor replied to gpupoor's topic in Orange Pi 5 Plus
Thanks for confirming. That makes 6.18 look very compelling. I have some ideas for how I'd like to present this and I'm finding myself wanting to flesh out my overview... If anyone has preferences for a better place than my PR comment to publish please let me know. -
@zmxyz I added support for A7Z. But I haven't tested it yet. I don't own a A7Z. Compile an image and let me know if it works.
@ARx8 @rafaeldavid I was having this problem, and I just figured out that this is a cheat from the chip. I don't know the details but basically they mark the memory as 2GB but it actually just have 512MB. The Armbian sees 2GB but when you do a task that requires more that the actual 512MB it crashes. To solve that I manually set the memory on the Armbian to be 512MB. Edit the file: /boot/armbianEnv.txt Add the line (or change if already exists): extraargs=mem=512M On my case the device claimed 2GB of Ram. I reach the 512M testing. To get to this number I ran: free -h This gave me the amount of memory the system was already using (230M). After that I apt installed memtester and start testing the memory: memtester 200M I started at 200M and cancel the test (CTRL-C) on the firsts interaction after: Stuck Address : ok Random Value : ok Compare XOR : ok Compare SUB : ok Compare MUL : ok Compare DIV : ok Compare OR : ok Compare AND : ok The other tests took too long and if the problem is the memory that didnt exist just the firsts test would be enough. I ran memtester increading by 50M, so 200,250,300... And on 300 the system crashed, so I assumed the real memory of the chip was 512 (the 230 from the system + the 250 from the memtester before it crashed).
I saw a commit for the A7Z (not the A7A, the one that looks like the Raspberry Pi Zero). Is it available now?
FYI: I got the trunk.22 image booted, running, configured and rebooted in a CLI based QEMU KVM on my NanoPi-R6C running Trixie with edge 6.18.0-rc kernel. xzcat Armbian_community_26.2.0-trunk.22_Rock-3c_trixie_current_6.12.59_minimal.img.xz > armimg.img mkdir -p 1 ; losetup -fP --show armimg.img ; mount /dev/loop0p1 1 cat boot.cmd.qemu-rock3-ext4 load virtio 0:1 ${ramdisk_addr_r} /uInitrd load virtio 0:1 ${kernel_addr_r} /Image fdt addr ${fdt_addr} setenv verbosity "7" setenv rootfstype "ext4" setenv rootdev "LABEL=armbi_root" setenv bootargs "root=${rootdev} rootwait rootfstype=${rootfstype} loglevel=${verbosity}" booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr} mv ./1/boot.scr ./1/boot.scr.rock3c_bak mkimage -C none -A arm -T script -d ./boot.cmd.qemu-rock3-ext4 ./1/boot.scr sync umount 1 ; losetup -d loop0 ln -sf /usr/lib/u-boot/qemu_arm64/u-boot.bin . taskset --cpu-list 0-3 qemu-system-aarch64 -M virt -cpu host -enable-kvm -m 2048 -smp 4 \ -bios u-boot.bin \ -drive if=none,file=armimg.img,format=raw,id=hd0 \ -device virtio-blk-device,drive=hd0 \ -netdev bridge,id=hn1 -device virtio-net,netdev=hn1 \ -nographic It is a quick and dirty modification from something I did a year ago for ROCK3A to test single partition btrfs formatted rootfs (custom compiled U-Boot), so I am not 100% sure if all is correct, but it works. So the trunk.22 image seems to be fine, except that I needed own boot.cmd. I could not get the one in the image to work. At least it showed something like 'failed to load /armbianEnv.txt'; that might be a U-Boot version/variant issue, it is of course not the blob for the rock3c in the image between MBR and bootFAT but a generic Debian Trixie for qemu (U-Boot 2025.01-3 (Apr 08 2025 - 23:07:41 +0000)).
No. This fork uses the name Armbian without permission and they do not contribute to the core development process. Instead they trick you into thinking that you'd get any sort of support here at our place whatsoever.
I didn't know it wasn't the original. But even if it's a fork, maybe you can still help based on the original... amlogic-s9xxx-armbian
Hello fedes_gl, thx for testing. Regarding wifi I got the same error with connectet LAN cable because the default Gateway is pointed to LAN address. Remove the LAN cable and you should be able to connect over wifi. x88pro:~:# routel Dst Gateway Prefsrc Protocol Scope Dev Table default 192.168.178.1 192.168.178.71 dhcp wlan0 192.168.178.0/24 192.168.178.71 kernel link wlan0 127.0.0.0/8 127.0.0.1 kernel host lo local 127.0.0.1 127.0.0.1 kernel host lo local 127.255.255.255 127.0.0.1 kernel link lo local 192.168.178.71 192.168.178.71 kernel host wlan0 local 192.168.178.255 192.168.178.71 kernel link wlan0 local
Note that ROCK3A images are 2 partitions, so 1st is boot and FAT formatted, so you should change verbosity to 7 in armbianEnv.txt, then the log will also contain kernel logs, that might tell what the problem is.
I now realize there is no ROCK3C downloadable image on the Armbian homepage as I was going to suggest you to download a 25.8.x image or so. So '26.2.0-trunk.7' is alpha or beta release and that changes per day, now it is .22 I see. You need enough tools and skills and time to get such a community level support SBC running. The images are just generated, you are the tester/checker. I can't really help you as I don't have a ROCK3C and that is definitely needed for such a case. I like the ROCK3C because with a SATA breakout board added, it is a good and cheap replacement for an old x86 PC to drive a SATA HDD/SSD. But the SATA breakout board can only be bought in China and I am in EU. Checking earlier downloaded schematic: No higher input voltage than 5V. Amount of Watts consumed does not say anything about voltage level and or short dips, so it is certainly no 100% proof that power is not a or the problem, but up to yourself to judge. Also the Rx serial path (so ROCK3C signal reception) might fail. As you mention USB keyboard it reacts. I think standard ethernet will be online, so that is another way to control the board, but needs the image manually pre-configured. You can check in your router for hints. You can build image yourself or use Radxa image, it has KDE Bookworm. You then can merge upgrade that yourself, but as indicated, it is DIY. Also ARM SBC images use 1 kernel only traditionally and you cannot select at boot time. I first changed Armbian boot method to use extlinux instead of boot.scr, so now I can select at least another kernel. If hadn't done that the board would be gathering dust now for a year already. I only used maskROM once just to see if it worked, with CLI tool rkdeveloptool (is default available in Opensuse Tumbleweed, I do not use Windows).
Is see no significant differences: ******************************************************************************** ssd-006 Hardkernel ODROID-N2Plus CPU 0-1: performance 1000 MHz - 2016 MHz CPU 2-5: performance 1000 MHz - 2400 MHz GPU: performance 124 MHz - 799 MHz 6.16.0-0.rc1.17.fc43.aarch64 #1 SMP PREEMPT_DYNAMIC Sat Jun 14 11:19:02 CEST 2025 ******************************************************************************** 7z b 7-Zip 24.09 (arm64) : Copyright (c) 1999-2024 Igor Pavlov : 2024-11-29 64-bit arm_v:8-A locale=en_US.UTF-8 Threads:6 OPEN_MAX:1024 Compiler: ver:15.2.1 20250924 (Red Hat 15.2.1-2) GCC 15.2.1 : UNALIGNED Linux : 6.16.0-0.rc1.17.fc43.aarch64 : #1 SMP PREEMPT_DYNAMIC Sat Jun 14 11:19:02 CEST 2025 : aarch64 PageSize:4KB THP:madvise hwcap:8FF:CRC32:SHA1:SHA2:AES:ASIMD arm64 1T CPU Freq (MHz): 2092 2387 2384 2390 2361 2389 2388 3T CPU Freq (MHz): 282% 2239 296% 2352.. 6T CPU Freq (MHz): 538% 2040 497% 1893.. RAM size: 3740 MB, # CPU hardware threads: 6 RAM usage: 1334 MB, # Benchmark threads: 6 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 7107 508 1362 6914 | 141426 488 2473 12058 23: 6459 494 1332 6581 | 136949 489 2421 11847 24: 6268 508 1327 6740 | 132118 485 2390 11593 25: 5695 515 1264 6503 | 127085 483 2343 11310 ---------------------------------- | ------------------------------ Avr: 6382 506 1321 6684 | 134394 486 2407 11702 Tot: 496 1864 9193 ******************************************************************************** ssd-006 Hardkernel ODROID-N2Plus CPU 0-1: performance 1000 MHz - 2016 MHz CPU 2-5: performance 1000 MHz - 2400 MHz GPU: performance 124 MHz - 799 MHz 6.18.0-0.rc3.30.fc44.aarch64 #1 SMP PREEMPT_DYNAMIC Mon Oct 27 21:17:35 CET 2025 ******************************************************************************** 7z b 7-Zip 24.09 (arm64) : Copyright (c) 1999-2024 Igor Pavlov : 2024-11-29 64-bit arm_v:8-A locale=en_US.UTF-8 Threads:6 OPEN_MAX:1024 Compiler: ver:15.2.1 20250924 (Red Hat 15.2.1-2) GCC 15.2.1 : UNALIGNED Linux : 6.18.0-0.rc3.30.fc44.aarch64 : #1 SMP PREEMPT_DYNAMIC Mon Oct 27 21:17:35 CET 2025 : aarch64 PageSize:4KB THP:madvise hwcap:8FF:CRC32:SHA1:SHA2:AES:ASIMD arm64 1T CPU Freq (MHz): 2365 2380 2383 2390 2389 2391 2388 3T CPU Freq (MHz): 277% 2162 274% 2095.. 6T CPU Freq (MHz): 533% 2021 508% 1926.. RAM size: 3737 MB, # CPU hardware threads: 6 RAM usage: 1334 MB, # Benchmark threads: 6 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 6924 491 1373 6737 | 136783 473 2465 11662 23: 6586 495 1356 6711 | 141391 506 2418 12232 24: 6240 494 1359 6709 | 138310 510 2382 12137 25: 5912 507 1330 6750 | 127792 487 2337 11373 ---------------------------------- | ------------------------------ Avr: 6415 497 1355 6727 | 136069 494 2401 11851 Tot: 495 1878 9289
Right, I always use the same system with all my devices. Makes comparisons more meaningful. Only the loaded DT is the only difference. -
Making some assumptions... you're 6.18 + Mesa 25.3 + Teflon delegate for the TensorFlow Lite tests? -
You are not using Armbian but a fork. Ask where you got the image from. We don't support 3rd party OS.
I have nothing to complain about and the VPUs are also working. classification-3.11.log fluster-run-odroid-m2-summary -
Thanks @KhanhDTP, this is great. I tried to stick with approaches that have made their way into official channels, but I'm happy to include because it's very cool to have a full working path identified (B2). I think I understood your setup but please let me know if I missed anything. Again, not sure where/how the best place to keep track of this is so in the absence of anything better I'll use the PR, but happy to migrate to another location. -
Really thank you for this!!! Just tested it today, using the provided "ready to go" ISO image. At first, system boots up Ok, and it automatically detects LAN Network , as I have an auto assigned IP shown in screen 😁 So this is (for me) a step up with the device (I have this one) as in my previous attemps with Armbian I couldn't manage to connect any network. Using armbian-config, I understand that WiFi also works... but... I couldn't connect. I can "see" all available Networks, and when I choose mine and enter password, the query (armbian-config) shows an error about the yaml file (I understand this is the configuration file). I did a quick test, and as I had wired netwrok I moved on. A little note: check the pictures in my device and WiFi Chip is LGX8800D, for sure somthing from the AIC8800 family you mentioned... I could also manage to extract .DTB, but when I edited armbianEnv.txt and pointed to it, after rebooting I had black screen... the device showed nothing on screen , like completly dead. I noticed that when using the binwalk command I had many partition with the same (and biggest) size, so I used the first one. (image attached). I attach also DTB and DTS files; but probabbly I did sth wrong. Any tips are welcome I wanted to try sound through HDMI as it wasn't working in previous version, but struggled a little to install xfce4 and then run out of space in my 4gb sd card so I had no time to do so. Will try to do it soon, when I have the time. Edit: couldn't test the remaingng hardware (IR, LCD display, RTC?, also I would like to test HDMI-CEC). I think that would take much more time as I dont know how to make it work. rk3528-CHAD_TV.dtb rk3528-CHAD_TV.dts
KhanhDTP replied to gpupoor's topic in Orange Pi 5 Plus
@gpupoor Why can't I see this option? . Kernel: 6.1 vendor . Driver: libMali . Panthor Overlay: OFF . Desktop: GNOME . Display Server: Wayland . NPU (RKNN): not tested (I am not using NPU) . GPU Accel: Smoothest . Desktop Perf: Smoothest Noted: must install WSI package https://github.com/ginkage/vulkan-wsi-layer
