  2. Does regular image with same version/kernel work?
  3. I burned the image to microsd via BalenaEtcher, popped it into the sbc and applied power. I have tried this two different days with two downloads of the HA image, and having burned the images to two different microsd cards with different results. Day One attempt booted but did not permit home assistant to start. Attempt two yielded the screencap and error previously mentioned.
  4. all those things are wow give kodi a try? https://kodi.tv/
  5. It is documented there: So when booted from SD you need to copy over the u-boot image to SD card and do from there: dd if=cubie_a5e_spi_nor_raw_050624.img of=/dev/mtdblock0 But that won't you get NVMe support on Armbian as Cubie A5E NVMe support just isn't in the kernel, not even the dev version.
  6. I assume you didn't change your power supply or add more things to USB? This could trigger crash. It would help if you could catch the crash. Enable more verbosity (loglevel) might give some clues, otherwise this can represent more serious debug / not easy to catch and resolve.
  7. you burned to microsd, then burned to microsd. What?
  8. How long did you wait for this? if you for example use a quite large microsd card that however has a slow pace this may take a few minutes.
  9. I've downloaded the Armbian 25.5.1 (Kernel 6.12) Home Assistant image (https://dl.armbian.com/orangepi5-plus/Bookworm_current_minimal-homeassistant), burned to microsd and rebooted the orange pi 5 plus. I burned the image to a microsd cards, inserted the microsd and did a hard reboot of the SBC. The error message is "Gave up waiting for root filesystem device."
  10. I don't have time to work on this right away, so to make sure this does not fall off the radar, I opened a ticket in the tracker.
  11. OK That would be called regression and should be analysed for a fix moving forward. Specifically looking for an older release as a "solution" still seems misguided and should only be done to bisect not as a kind of permanent solution.
  12. Successful playing of H264 1080p mp4 Orange pi zero 3, 1GB Self-built Bookworm, with XFCE desktop Linux edge 6.15.4 No changed linux configurations Using ffmpeg+libraries provided in the first post of https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/ (you can even install all the bookworm ffmpeg, mpv, then when you add the new repository, update and upgrade, apt will replace the packages with their ffmpeg-v4l2request equivalents) Testing 1080P H264 (warning, some mp4's will actually be AV1 codec), checked with VLC Compositor on or off, doesn't make a difference. Video plays at full 30 fps To avoid video glitches during window resizing: add "extraargs=cma=256M" in /boot/armbianEnv.txt With hwdec=drm-prime, CPU is 50% in all 4 cores With hwdec=drm, CPU is 10% or less in all 4 cores Without HW acceleration, CPU is 100% in all 4 cores with many skipped frames mpv.conf and mpv log: Reveal hidden contents THANK YOU to all who gave me updated information! Edited just now by robertoj
  13. Yesterday
  14. I actually dont remember the exact order of install, but from what i can recall first i compiled and installed libva-v4l2-request-HACK_HEVC.zip and followed that tutorial then i downloaded h618_hwdec.tar.gz from https://www.elektroda.pl/rtvforum/topic4018092.html#20840047, those are the libs i replaced in /lib/aarch64-linux-gnu/ install latest edge kernel from armbian-config (or enable rolling updates), download kernel hearders and enable gpu in device tree overlays to compile mesa first install deps than creat a python venv in mesa src directory to download latest meson in it sudo apt-get install bison build-essential ccache clang cmake flex git glslang-tools libclang-dev libdrm-dev libelf-dev libexpat1-dev libgl1-mesa-dev libgles2-mesa-dev libgoogle-perftools-dev libgtk-3-dev libllvm-18-dev libomxil-bellagio-dev libpciaccess-dev libsensors-dev libspirv-tools-dev libunwind-dev libva-dev libvdpau-dev libvulkan-dev libwayland-dev libx11-dev libx11-xcb-dev libxatracker-dev libxcb-dri2-0-dev libxcb-dri3-dev libxcb-glx0-dev libxcb-present-dev libxcb-randr0-dev libxcb-shm0-dev libxcb-sync-dev libxcb-xfixes0-dev libxdamage-dev libxext-dev libxfixes-dev libxrandr-dev libxshmfence-dev libxxf86vm-dev libzstd-dev llvm-18-dev meson ninja-build pkg-config python3-mako python3-pil wayland-protocols python3-venv python3 -m venv mesa_venv source mesa_venv/bin/activate pip3 install meson but if i tried to compile from inside the venv i was gettin a mako version error so i exited the venv (just open another terminal window) used this exact command to be able to build from outside the python3 venv PYTHON=~/src/mesa/mesa_venv/bin/python3 ~/src/mesa/mesa_venv/bin/meson setup build -Dbuildtype=release -Dprefix=/usr -Dgallium-drivers=panfrost -Dvulkan-drivers=panfrost -Dplatforms=x11 -Dvideo-codecs=all you need to add wayland to platforms if you're using it, i'm not (replace '~/src/mesa/mesa_venv/bin/python3' and '~/src/mesa/mesa_venv/bin/meson' with the path where you cloned the source...) install any other dependencies it complains about then install with sudo ninja -C build install you can confirm with glxinfo -B gabriel@orangepizero3:~/$ glxinfo -B name of display: :0.0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: Mesa (0xffffffff) Device: Mali-G31 (Panfrost) (0xffffffff) Version: 25.2.0 Accelerated: yes Video memory: 3922MB ... i don't know if that libva hack is working but vainfo recognize gabriel@orangepizero3:~$ LIBVA_DRIVER_NAME=v4l2_request vainfo libva info: VA-API version 1.20.0 libva info: User environment variable requested driver 'v4l2_request' libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/v4l2_request_drv_video.so libva info: Found init function __vaDriverInit_1_20 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.20 (libva 2.12.0) vainfo: Driver version: v4l2-request vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointVLD VAProfileH264High : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointVLD and finally mpv (with yt-dlp installed) gabriel@orangepizero3:~/$ mpv --hwdec=drm --profile=fast https://www.youtube.com/watch?v=Dyzf2evNjwc (+) Video --vid=1 (*) (h264 1920x1080 29.970fps) (+) Audio --aid=1 --alang=eng (*) (opus 2ch 48000Hz) File tags: Uploader: Zen Mechanics Channel_URL: https://www.youtube.com/channel/UCC8n8afKsdaYuI7Pr0J4pgA Using hardware decoding (drm). AO: [pulse] 48000Hz stereo 2ch float VO: [gpu] 1920x1080 drm_prime[nv12] it is a bit confusing but i hope it helps... i also recommend this moded mpv handler with youtube playlist and mpv prefetch queueing support: https://github.com/gabreek/mpv-handler-queue
  15. Using Jun 26's Sid_vendor_server-kali, my Zero 3W is stuck in a loop. I can't "Create a loop password" as it'll instantly jump to the "armbian-security login:" prompt. If I login with the default root:1234, I'll briefly see the welcome screen, followed by a very brief "waiting for the system to finish booting", then it's back to 1. This occurs regardless of internet access (provided by a USB-C ethernet adapter, for which Armbian reports a valid LAN IP address).
  16. I've recently upgraded my NanoPi M4 V2 to Armbian_25.2.1_Nanopim4v2_bookworm_current_6.12.13_minimal.img.xz and since that, I have been getting random crashing of it, to the point that I have to manually power it down and up again to get it back running again. The only thing I've noticed is that this normally happens when there is intensive disk usage (like downloading a bunch of docker images, or when downloading large files from the internet). Here's the output from armbianmonitor -u pedro@nanopim4v2:~/docker$ armbianmonitor -u Collecting info and sending to paste.armbian.com, wait... dmesg: read kernel buffer failed: Operation not permitted dmesg: read kernel buffer failed: Operation not permitted https://paste.armbian.com/jefilizufo Please post the URL in the forum where you've been asked for.
  17. In the past we had dedicated image for rpi5 ... It could be added here: https://github.com/armbian/build/blob/main/packages/bsp/common/usr/lib/armbian/armbian-firstrun#L112-L122
  18. The Gnome desktop Power off menu selection and `sudo shutdown now` both reboot rather than powering down.
  19. yeah, frustration is quite clear, but probably it is manufacturer who should be most/only interested in that. that also cost quite a lot, so it is probably better to demand where money were paid to, i guess.
  20. That is the expected behavior. You always need to "install" u-boot after a new version from apt. The apt package just provides the binaries that you can install.
  21. Tried rk3318 debian 12 with linux kernel 6.1.63 or up to 6.12.39 and no hdmi output, I installed on SD card. Though debian 11 with kernel 5.15.35 works Interesting thing that debian 12 with linux kernel 6.16.0-rc3 worked Is there anything I can do to provide useful information to debug?
  22. At the same time as mmcblk1 disappeared someone had changed the ethernet port over to the secondary port as I could not get into the machine and tried the second port which had been configured to the same static IP address as the primary port was on.
  23. You are right. I just downloaded something from youtube and assumed it was H264. When I checked it in VLC in my PC, the codec is: AOMedia's AV1 video (av01) I picked another mp4, which I verified in VLC as H264-MPEG4, 720p, and it played with 10% CPU This test below is with Bookworm XFCE, compositor ON, Linux 6.15.4 with default configuration Then I repeat the test with a 1080p H264 mp4. mpv tries to use hardware acceleration, but the mpv is black and there's continuous DRM_IOCTL errors: Then I tried this inside /etc/mpv/mpv.conf hwdec=drm-prime drm-drmprime-video-plane=primary drm-draw-plane=overlay and the 1080p H264 starts playing fluidly with just 40% CPU (compositor off) With compositor on, I get same 40% CPU Same video glitches, with or without compositor, but I am getting hardware acceleration (although there's the hwdec unsupported message) Update: Thank you to all who helped me. I have hardware acceleration again with my opiz3 hwdec=drm is more efficient extraargs=cma=256 is needed to avoid memory allocation problems and video glitches. https://forum.armbian.com/topic/29202-orange-pi-zero-3/page/26/#findComment-222596
  24. >PLEASE STOP! This is both a time and money nightmare for me. I am giving as much information as I can in order to give feedback in order to get support. What I am posting is not all nonsense ! Okay the Gnome downgrade was incorrect and was based on what ifnformation I could get at the time. Why the issue system put up the postgres tag I really don't know I removed it. It is now repeatedly demostratably kernel dependant. On 6.12.32-current-rockchip64 and 6.12.39-current-rockchip64 the display is failing, 6.12.22-current-rockchip64, and 6.12.17-current-rockchip64 the display is working fine. 6.15.1-edge-rockchip64 is also working fine. No sure about 6.15.7 6.16.0-rc3-edge and 6.16.1-edge are not even booting, with BananaPi-M7. I am going to get kernel output using USB UART for all these boots.
  25. Problem solved... My ignorance... For inexplicable reasons, u-boot was updated without an error message, but actually NOT written to the SD card. The ancient version apparently cannot start without uImage. Now I have manually written the SD card - more precisely an image of it - with the new u-boot and then wrote a new SD card from that image, uImage can be deleted and it runs...
  26. And it turns out that nothing can be done? For some reason, it works for everyone, but something happened to me and it doesn't work anymore.
  27. moved to tvboxes
