Banana Pi M1+ - not seeing OpenGL / unable to run Kodi
copytco
Hi, I am totally new to Linux, but already managed to run OMV on my Banana Pi M1+ with Plex and other services I wanted on Armbian.
Now I tried to run Kodi, so it could serve me both as NAS and HTPC. Firstly, I have installed xorg, then lightdm and set it up for autologin, which is working correctly. Then, I have installed Kodi 16 from git, but only gray box appears and then vanishes and screen stays black.
My first impression was it is lacking GL drivers, so I have followed this tutorial: https://forum.armbian.com/index. ... pi-orangepi-pc-etc/, tested and everything seemed to be ok. I installed Emilia Pinball to check additionally - it renders correctly.
Still, when I try to run Kodi it is gray screen, then black. I have opened Kodi log and I have found that, indeed, it does not see driver/device?
21:38:26 T:2967420928 ERROR: Failed to determine egl config for visual info
21:38:26 T:2967420928 ERROR: Previous line repeats 60 times.
21:38:26 T:2967420928 ERROR: EGL/GLX Error: vInfo is NULL!
21:38:26 T:2967420928 NOTICE: GL_VENDOR = NULL
21:38:26 T:2967420928 NOTICE: GL_RENDERER = NULL
21:38:26 T:2967420928 NOTICE: GL_VERSION = NULL
21:38:26 T:2967420928 NOTICE: GL_SHADING_LANGUAGE_VERSION = NULL
21:38:26 T:2967420928 NOTICE: GL_EXTENSIONS = NULL
21:38:26 T:2967420928 ERROR: GL: Error compiling vertex shader
After this message, it is constantly repeating those, untill I close SSH connection.
21:38:30 T:2967420928 ERROR: Invalid GUI Shader selected - [guishader_frag_texture.glsl]
21:38:30 T:2967420928 ERROR: Invalid GUI Shader selected - [guishader_frag_fonts.glsl]
21:38:30 T:2967420928 ERROR: Previous line repeats 1 times.
The full log is available here: http://pasted.co/dc406eb6
I have installed drivers using normal user with sudo and I run Kodi as root using:
xinit kodi
What might be the issue here?
