Error in kernel compiling 4.9.9 and 4.9.10
matteobp
Hi.
I have a Banana PI M1+, and I'm building my custom kernel on a VirtualBOX VM with Ubuntu Server 16.04 because I want to enable other frequencies (until 1152000) and I want to modify the voltage according to the table found here
https://linux-sunxi.org/A20
I'm having this error compiling my own kernel
  ¦ dpkg-deb: building package 'linux-firmware-image-4.9.10-sunxi' in '../linux-firmware-image-4.9.10-sunxi_5.26_a ¦
  ¦ dpkg-deb: building package 'linux-headers-4.9.10-sunxi' in '../linux-headers-4.9.10-sunxi_5.26_armhf.deb'.     ¦
  ¦ dpkg-deb: building package 'linux-libc-dev' in '../linux-libc-dev_5.26_armhf.deb'.                             ¦
  ¦ dpkg-deb: building package 'linux-image-4.9.10-sunxi' in '../linux-image-4.9.10-sunxi_5.26_armhf.deb'.         ¦
  ¦ dpkg-genchanges: binary-only upload (no source code included)                                                  ¦
dpkg-deb: error: failed to read archive '/home/xxxxx/armbian/output/debs/linux-image-next-sunxi_5.26_armhf.deb': No such file or directory
[ o.k. ] Kernel build done [ @host ]
[ o.k. ] Target directory [ /home/xxxxx/armbian/output/debs/ ]
[ o.k. ] File name [ linux-image-next-sunxi_5.26_armhf.deb ]
[ o.k. ] Runtime [ 23 min ]
These are my changes to compile.sh file
KERNEL_ONLY="yes"                       # leave empty to select each time, set to "yes" or "no" to skip dialog prompt
KERNEL_CONFIGURE="yes"                  # change provided kernel configuration
FORCE_CHECKOUT="no"                     # take manual changes to source
BOARD="bananapipro"
BRANCH="next"
and I have modifed only the file
sources/linux-vanilla/v4.9.10/arch/arm/boot/dts/sun7i-a20.dtsi
I had the same error building the kernel v. 4.9.9
I successfully compiled kernel v. 4.9.8.
Thanks for support
P.S. Is it possible to include these frequencies as standard?
1152000 1550000
1104000 1500000
1056000 1500000
1008000 1450000
Every time I run an "apt upgrade" I lose my changes.
You probably need to revert FORCE_CHECKOUT to yes since it will interfere with kernel updates, and create a patch to apply your changes to the operating points.
1152000 1550000
1104000 1500000
1056000 1500000
1008000 1450000
Operating points in sun7i-a20.dtsi are the generic ones shared by all boards: https://git.kernel.org/cgit/linux/kernel/git/stable/linux-stable.git/commit/arch/arm/boot/dts/sun7i-a20.dtsi?id=d96b7161916f1b5c1a676fba2d54ef0106a88aff
Operating points higher than 960MHz were unstable on some boards, so they are not included by default, though some boards override this table to include other values, like the Banana Pi.
You can use "apt-mark hold <package_name>" to prevent upgrading certain packages like the kernel ones. You still will be able to install updated packages manually when you want to upgrade.
Yes, I'm editing only the operating points.
I found this post in the forum
https://forum.armbian.com/index.php/topic/3064-problem-enablig-tty5-and-tty6-on-cubieboard2-with-kernel-473-using-dtb/#entry21296
Based on it, my understand is to apply these steps:
- install Device Tree compiler
# sudo apt-get install device-tree-compiler
- navigate to /boot/dtb and execute this command
# dtc -I dtb -O dts sun7i-a20.dtb > sun7i-a20.dts (probably, it should be better to use "sun7i-a20-bananapi-m1-plus.dtb")
- modify the section "operating-points"
- recompile the dtb using this command
# dtc -O dtb -o sun7i-a20.dtb -b 0 sun7i-a20.dts
Is it correct?
By the way, with FORCE_CHECKOUT="yes" the compilation was successfull :-).
Thanks for help
Is it correct?
It doesn't work. This is my /boot/armbianEnv.txt
fdtfile=sun7i-a20-bananapi-m1-plus.dtb
I executed this command
dtc -I dtb -O dts sun7i-a20-bananapi-m1-plus.dtb > sun7i-a20-bananapi-m1-plus.dts
then I modifed the file sun7i-a20-bananapi-m1-plus.dts changing the line operating-points (the values are in hexadecimal form, I used the line of the previous sun7i-a20-bananapi-m1-plus.dts obtained from my custom kernel installation), and then this command
dtc -O dtb -o sun7i-a20-bananapi-m1-plus.dtb -b 0 sun7i-a20-bananapi-m1-plus.dts
and reboot.
I tried also to compile the /boob/boot.cmd file, but the output of the command
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
is this one
144000 312000 528000 720000 864000 912000 960000
If I install my custom kernel, compiled modifying only the file "sources/linux-vanilla/v4.9.10/arch/arm/boot/dts/sun7i-a20.dtsi", the output is this one
144000 312000 528000 720000 864000 912000 960000 1008000 1056000 1104000 1152000
Probably I'm missing something else.
