minusdelta Posted June 1, 2016 Share Posted June 1, 2016 On one machine I forgot to "pin" (apt-mark hold) custom kernel pkgs ... and updated :-/ but no reboot yet. This leads to these 3 questions: Q1 How to recover ? Pull from back-up of sd-card image ? What ? Any hints are greatly appreciated as you can imagine. Q2 More generally: which pkgs to pin ? Usually I set linux-image-* and linux-headers-* on hold but this particular update additionally installed newer versions of linux-dtb-next-sunxi:armhf linux-firmware-image-next-sunxi:armhf linux-jessie-root-next-bananapipro:armhf linux-u-boot-bananapipro-next:armhf Does installing these newer versions break a custom kernel? Q3 How to update w/ custom kernel ? Building newer version with Igors wonderful toolchain ? But I dont want to re-flash sd-card. Building on the board ? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted June 1, 2016 Share Posted June 1, 2016 Q1 How to recover ? Pull from back-up of sd-card image ? What ? Any hints are greatly appreciated as you can imagine. linux-image installs files in /boot and /lib/modules/$(uname -r) You can check contents of newly installed kernel with "dpkg -L linux-image-next-sunxi" to compare. linux-dtb should also match kernel version, it installs files in /boot/dtb Q2 More generally: which pkgs to pin ? Usually I set linux-image-* and linux-headers-* on hold but this particular update additionally installed newer versions of linux-dtb-next-sunxi:armhf linux-firmware-image-next-sunxi:armhf linux-jessie-root-next-bananapipro:armhf linux-u-boot-bananapipro-next:armhf Does installing these newer versions break a custom kernel? If you don't compile custom modules on board, you can remove linux-headers package and forget about it. If you don't have any devices which use firmware, you can remove linux-firmware package too. board support package (linux-*-root) and u-boot don't depend on kernel version and can be safely updated. So if you want to pin mainline kernel packages, you need to mark linux-image and linux-dtb in any case, linux-headers and linux-firmware if you are using them. Q3 How to update w/ custom kernel ? Building newer version with Igors wonderful toolchain ? But I dont want to re-flash sd-card. Building on the board ? You can build packages with Armbian toolchain, transfer them to your board and install with "dpkg -i *.deb", you don't need to reflash your image in this case. Building on board itself is possible but is not supported in Armbian build script. Link to comment Share on other sites More sharing options...
wildcat_paris Posted June 1, 2016 Share Posted June 1, 2016 @minusdelta You can build packages with Armbian toolchain, transfer them to your board and install with "dpkg -i *.deb", you don't need to reflash your image in this case. Building on board itself is possible but is not supported in Armbian build script. I am doing sftp from my virtual machine to my Lamobo-R1 board as I need all the *.deb mput *.deb mput trusty/*.deb I store my past builds on the root of the card gr@bpi:~$ ls /armbian_kernel/ dpsysquery.sh kern_4.3.3_5 kern_4.4.2_2 kern_4.5.2_1 kern_4.5.5_2 mod_noreboot.sh~ frandom-dkms_1.1-0centrych4_armhf.deb kern_4.4.1_2 kern_4.4.4_1 kern_4.5.3_1 kern_4.5.5_3 mod_noreboot.sh.keep kern_4.3.0_4 kern_4.4.2_1 kern_4.4.6_1 kern_4.5.5_1 mod_noreboot.sh dpsysquery.sh to find the related kernel packages for my board sudo dpkg-query -W "*lamobo*" "*sunxi*" the other script reinstall frandom-dkms before I reboot the board sudo dpkg -i frandom-dkms_1.1-0centrych4_armhf.deb in case I mess with a custom kernel, I have old good packages on the rootfs, so from another computer I can extract the files with "dpkg -x *.deb" and put a working kernel back on the card. note: in the current revision of the tool, I am (mis-)using $SUBREVISON variable to add a name to the deb packages => 5.12-golfromeo SUBREVISON="-golfromeo" gr@bpi:/armbian_kernel$ dpkg-query -W "*lamobo*" "*sunxi*" linux-dtb-next-sunxi 5.12-golfromeo linux-firmware-image-next-sunxi 5.12-golfromeo linux-headers-next-sunxi 5.12-golfromeo linux-image-next-sunxi 5.12-golfromeo linux-modules-4.5.5-sunxi linux-trusty-root-next-lamobo-r1 5.12-golfromeo linux-u-boot-lamobo-r1-next 5.12-golfromeo Link to comment Share on other sites More sharing options...
minusdelta Posted June 1, 2016 Author Share Posted June 1, 2016 @zador.* thank you very much for your answer, very appreciated! Q3 You can build packages with Armbian toolchain, transfer them to your board and install with "dpkg -i *.deb" ... I was under this impression, too. I searched my build VM and found ... no .deps. Do these show up when changing build options to "KERNEL_ONLY yes" ? Q1 w/ the insights I got from your answer to Q2 it looks like in my case I need to replace the files provided by "linux-image" and "linux-dtb" only, keeping the other updates. So pulling from my old image contents of "/lib/modules/" and "/boot" and replacing will do the job ? @wildcat_paris Many thanks for describing your workflow! Adopted "dpkg-query -W "*banana*" "*sunxi*" and will look for more postings like this. Many thx to both of You! Link to comment Share on other sites More sharing options...
zador.blood.stained Posted June 1, 2016 Share Posted June 1, 2016 I was under this impression, too. I searched my build VM and found ... no .deps. Do these show up when changing build options to They should be located in output/debs/ You can set KERNEL_ONLY=yes or just select appropriate option in dialog window if KERNEL_ONLY="" w/ the insights I got from your answer to Q2 it looks like in my case I need to replace the files provided by "linux-image" and "linux-dtb" only, keeping the other updates. So pulling from my old image contents of "/lib/modules/" and "/boot" and replacing will do the job ? It would be better to compile, install and pin custom kernel. Replacing files controlled by package manager manually is not a good idea and should be used only as a last resort. Link to comment Share on other sites More sharing options...
minusdelta Posted June 3, 2016 Author Share Posted June 3, 2016 They should be located in output/debs/ This is empty ATM. Will check my "clean cache" settings and start over. It would be better to compile, install and pin custom kernel. Replacing files controlled by package manager manually is not a good idea and should be used only as a last resort. Yes, you are absolutely right. This is much better than my "shoot first, think later" approach. Thanks for appealing to my conscience and your help! Link to comment Share on other sites More sharing options...
