tutorial Configuring Orange PI PC to receive IR/InfraRed
6 6
17 posts in this topic
Note: Guide Updated May 2017, as I realise that /dev/input/event3 may not always be the IR receiver device on your armbian installation.
Hi All,
I recently bought an Orange PI PC and the best thing I ever did was install Armbian straight away (and donate). Now that I have a bit of spare time, I wanted to configure my Orange PI PC to do something ridiculous like play Rick Ashley 'Never going to give you up' upon pressing the 'red button' on some generic Chinese IR remote for an LED light strip I have in my living room.
Thanks to Armbian, most of the pieces are in place (such as the SunXI IR package) with the distribution, you just need to glue it all together.
However there are few configuration issues with the default Armbian install on the Orange PI PC that need to be adjusted, otherwise you'll encounter infuriating issues such as:
  • No IR device existing or being detected (root cause: sunxi-cir module not loaded)
  • No LIRC 'irw' output even after successfully using irrecord (root cause: DRIVER=devinput doesn't work, though it could be my remote), like this poor sod was experiencing.
I should also note that this guide on the terrible Orange PI forums, helped me with my issues.
Step 1) Adjust /etc/lirc/hardware.conf
By default Armbian doesn't have the suxi-cir module enabled at boot-up, but it is available, so you will need to edit hardware.conf to enable this, as well as correct the DRIVER= line and the DEVICE= line, as the defaults in there are WRONG. Also I suggest commenting out Igor's code in the top five lines. A hardware.conf that works:
# Cubietruck automatic lirc device detection by Igor Pecovnik
#str=$(cat /proc/bus/input/devices | grep "H: Handlers=sysrq rfkill kbd event" | awk '{print $(NF)}')
#sed -i 's/DEVICE="\/dev\/input.*/DEVICE="\/dev\/input\/'$str'"/g' /etc/lirc/hardware.conf
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS=""
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
# 'devinput' driver on Orange PI PC causes NO EVENTS TO OCCUR
# via irw for some reason.
DRIVER="default"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/lirc0"
MODULES="sunxi-cir"
# Default configuration files for your hardware if any
LIRCD_CONF=""
LIRCMD_CONF=""
Step 2) Restart lircd service
As lirc is actually already running and installed in Armbian, do the following:
root@orangepipc:/etc# /etc/init.d/lirc stop
root@orangepipc:/etc# /etc/init.d/lirc start
To reboot the service.
Then perform an 'lsmod' to see if it loaded the sunxi_cir module (because otherwise nothing will work):
user@orangepipc:~$ lsmod
Module                  Size  Used by
mali_drm                2732  1
drm                   178255  2 mali_drm
mali                  123208  0
ump                    29379  3 mali
sunxi_cir               1601  0
8189es               1076034  0
Step 3) Find out what '/dev/input/eventX' device is your IR receiver
If you do a:
ls /dev/input/event*
You will most likely get a bunch of possible event devices to choose from, for example:
anonymouspi@orangepipc:~$ ls /dev/input/event*
/dev/input/event0  /dev/input/event2  /dev/input/event4
/dev/input/event1  /dev/input/event3  /dev/input/event5
For my installation, /dev/input/event3 is the IR receiver, but if you have other devices installed (i.e. USB cameras, keyboards etc.) then the number could be different. For example, executing 'evtest /dev/input/event3' reveals:
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
Input device name: "sunxi-ir"
A device name of 'sunxi-ir' means that we are using the right device for the purposes of evtest
Step 4) Do a quick test with with 'evtest' (OrangePI PC armbian seems to use /dev/input/event3 for IR input )
Armbian has the 'evtest' program installed, point the IR remote (in my case a  LED colour remote) at your Orange PI PC and as root 'evtest /dev/input/event3'.
root@orangepipc:/etc# evtest /dev/input/event3
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 152 (KEY_SCREENLOCK)
  Event type 4 (EV_MSC)
    Event code 4 (MSC_SCAN)
Key repeat handling:
  Repeat type 20 (EV_REP)
    Repeat code 0 (REP_DELAY)
      Value    500
    Repeat code 1 (REP_PERIOD)
      Value    125
Properties:
Testing ... (interrupt to exit)
Pressing the remote reveals events like:
Event: time 1472917554.113967, type 4 (EV_MSC), code 4 (MSC_SCAN), value 58
Event: time 1472917554.113981, -------------- EV_SYN ------------
Event: time 1472917554.464390, type 4 (EV_MSC), code 4 (MSC_SCAN), value 59
Event: time 1472917554.464398, -------------- EV_SYN ------------
Event: time 1472917554.842832, type 4 (EV_MSC), code 4 (MSC_SCAN), value 45
Event: time 1472917554.842839, -------------- EV_SYN ------------
Event: time 1472917555.345584, type 4 (EV_MSC), code 4 (MSC_SCAN), value 58
That was the red, green, blue and white buttons being pressed. This is a good news.
Step 5) Configure lirc to map IR input to key presses or events.
Again, Armbian has irrecord installed (great work Igor), but given I'm re-using this remote to configure the output of a LED strip I have, I'll need to map the IR data sent, to something more meaningful. In other use-cases this isn't generally required as lircs provides a database of media remotes which is pre-mapped to Linux commands/keyboard keys.
There's plenty of information on how to use irrecord, command I used was:
...to first stop the service, then:
irrecord -H default -d /dev/lirc0 /etc/lirc/lircd.conf
... to record my remote and bind to 'keys'.
Step 6) Test with irw
Now that I recorded my configuration file with irrecord:
.. to start lird service again
then type 'irw' and check that the key mapping works when I point the remote at the Orange PI PC and press a button:
root@orangepipc:/etc# irw
0000000000ff1ae5 00 KEY_R /etc/lirc/lircd.conf
0000000000ff1ae5 01 KEY_R /etc/lirc/lircd.conf
0000000000ff9a65 00 KEY_G /etc/lirc/lircd.conf
0000000000ff9a65 01 KEY_G /etc/lirc/lircd.conf
0000000000ffa25d 00 KEY_B /etc/lirc/lircd.conf
0000000000ffa25d 01 KEY_B /etc/lirc/lircd.conf
0000000000ff22dd 00 KEY_W /etc/lirc/lircd.conf
0000000000ff22dd 01 KEY_W /etc/lirc/lircd.conf
Hoo Ray!
Step 7) Create a /root/.lircrc file to run commands
I'd actually call mpv here and call the player:
# http://www.lirc.org/html/configure.html
begin
   button = KEY_R
   prog = irexec
   config = mpv  /home/root/Rick\\ Astley\\ -\\ Never\\ Gonna\\ Give\\ You\\ Up.m4a & echo "COMMENT RICK ROLLING" &
end
begin
   button = KEY_W
   prog = irexec
   config = killall mpv & echo "SADFACE!" &
end
begin
   button = KEY_B
   prog = irexec
   config = mpv http://sj256.hnux.com &
end
So there you go, Rickrolling with a simple press of the red (KEY_R) button :-)
Additional References:
[Guide] Android + InfraRed (IR) + Kodi
How to setup Remote Control for Linux
gnasch, slinde, RagnerBG and 3 others like this
Share this post
Link to post
Is it possible to bind this lirc to some python script or something? Or how someone could intercept these button press events and then pipe them somewhere else where they could be used to trigger stuff?
Share this post
Link to post
I wanted to configure my Orange PI PC to do something ridiculous like play Rick Ashley 'Never going to give you up' upon pressing the 'red button' on some generic crap Chinese IR remote for an LED light strip I have in my living room.
I like your style kid.  :lol:
Share this post
Link to post
Hi all,
According to:
I have a completely different contents of this file,
where I make a mistake? :)
the contents of my file /etc/lirc/hardware.conf  below :
count 1
range '0 - 7'
control.2 {
iface MIXER
name 'MIC2_G boost stage output mixer control'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.3 {
iface MIXER
name 'LINEIN_G boost stage output mixer control'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.4 {
iface MIXER
name 'MIC1 boost AMP gain control'
value 4
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.5 {
iface MIXER
name 'MIC2 boost AMP gain control'
value 4
comment {
access 'read write'
type INTEGER
count 1
range state.audiocodec {
control.1 {
iface MIXER
name 'MIC1_G boost stage output mixer control'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.2 {
iface MIXER
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.3 {
iface MIXER
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.4 {
iface MIXER
value 4
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
control.5 {
iface MIXER
value 4
comment {
access 'read write'
type INTEGER
count 1
range
Share this post
Link to post
btw. I changed the contents of this file and everything works, :)
 but why after the Armbian installation this file  was so different  from the target?
Share this post
Link to post
Certainty is never, but this file seemed ok, only content was strange.
I did not created this file.
Armbian was compiled from sources some four months ago, is working fine
(webmin, apache,ssl,mqtt server and many other things working 24/7)
now IR remote control (Samsung) also work  :)
Maybe an error at compile time? file system error is not indicated
Share this post
Link to post
OK, if it's not a prebuilt image from download section then we'll never know why this happened.
Share this post
Link to post
Thaks for this  :)
Btw.
Did Yoy try play stream from playlist ? (works for me:  mpv --playlist = playlist.pls) but..
Do You know how to easy change to next stream from play list using IR ?
(just kill and restart with new stream only metod?)
Last news:    :)  :)
I am fine now,
I solved the problem and I use mpd, mpc for bacground playing music from playlist
eg.
begin
  prog = irexec
  button = KEY_CHANNELDOWN
  config = mpc prev & echo "prev music" >/dev/ttyS0
end
Hi All,
I recently bought an Orange PI PC and the best thing I ever did was install Armbian straight away (and donate). Now that I have a bit of spare time, I wanted to configure my Orange PI PC to do something ridiculous like play Rick Ashley 'Never going to give you up' upon pressing the 'red button' on some generic crap Chinese IR remote for an LED light strip I have in my living room.
Step 5) Create a /root/.lircrc file to run commands
begin
   button = KEY_R
   prog = irexec
end
begin
   button = KEY_W
   prog = irexec
end
begin
   button = KEY_B
   prog = irexec
end
Share this post
Link to post
Hi, I'm having problems with the evtest. Everything works just fine until I reach that point. The evtest shows nothing.
I tried using the command "sudo mode2 -d /dev/lirc0" and it works, so my IR receiver is functioning, but the evtest doesn't detec anything.
I also tried with both the default and the Igor's hardware.conf file. Same result.
I don't know if it is usefull, but the command "irw" also doesn't work for me, it says "connection refused".
I'm using Armbian on an Orange PI PC Plus.
Share this post
Link to post
Thanks !
for me, this tutorial was very helpful.
However, the configuration file created :
but the remote control to work properly.
Already done ...
It is difficult for proper entries: .....and shows that are very important!
  name        mceusb
  bits                 16
  flags  RC6|CONST_LENGTH
  eps                  30
  aeps                100
  header       2667   889
  one           444   444
  zero          444   444
  pre_data_bits        21
  pre_data        0x37FF0
  gap              105000
  toggle_bit           22
  rc6_mask    0x100000000
after the change of all is OK ...I use the remote control OrigenAE RC153 which uses standard codes RC6 (mce)
original config (lircd.conf) under the remote control mce ..... and created:
mce https://dl.dropboxusercontent.com/u/68191728/LINUX/lircd-mce.conf
OrigenAE https://dl.dropboxusercontent.com/u/68191728/LINUX/lircd-OrigenAE.conf
a list of possible names in the irrecord : https://dl.dropboxusercontent.com/u/68191728/LINUX/key
Useful links (internet radio) http://www.orangepi.org/orangepibbsen/forum.php?mod=viewthread&tid=1389
another sensor and remote control : https://forum.armbian.com/index.php/topic/3288-orangepi-lite-armbian-remote-x10/
Regards !
Share this post
Link to post
Thanks for the write up AnonymousPi!
I am running an OrangePi PC as well with Armbian on top of an Ubuntu Kernel. The default LIRC config, however, is different. I tried making changes, but whatever I do sunxi_cir just does not show with lsmod. Is anyone else having issues?
Share this post
Link to post
I have Orange Pi lite / ARMBIAN 5.25 stable Ubuntu 16.04.2 LTS 3.4.113-sun8i
And after the lsmod command:
Module                  Size  Used by
mali_drm                2732  1
pcf8591                 3363  0
bmp085                  3487  0
mali                  123146  0
ump                    29379  3 mali
ir_lirc_codec           3650  3
lirc_dev                7834  1 ir_lirc_codec
ir_mce_kbd_decoder      2885  0
snd_usb_audio          80352  2
ir_sanyo_decoder        1480  0
snd_hwdep               5562  1 snd_usb_audio
ir_sony_decoder         1422  0
snd_usbmidi_lib        17545  1 snd_usb_audio
snd_seq_midi            4215  0
snd_seq_midi_event      5340  1 snd_seq_midi
ir_jvc_decoder          1452  0
ir_rc6_decoder          1941  0
snd_rawmidi            17134  2 snd_usbmidi_lib,snd_seq_midi
ir_rc5_decoder          1412  0
ir_nec_decoder          1556  0
g_serial               27617  2
sunxi_cir               1601  0
Share this post
Link to post
6 6
  • Support the project
    We need your help to stay focused on the project.
    Choose the amount and currency you would like to donate in below.
