Banana Pi M2+ with system on emmc, data on sd card
seeing350
Hi guys,
  I installed last armbian on Banana Pi M2+, and execute nand-sata-install.sh to boot armbian from emmc, it works fine.
I want system boot from emmc, and storage some data to sd card, so I prepare one sd card with ntfs partition, insert to Banana Pi M2+, and boot. It cannot boot, and message are:
U-Boot SPL 2016.05-armbian (Jun 23 2016 - 09:59:04)
DRAM: 1024 MiB
Trying to boot from MMC1
U-Boot 2016.05-armbian (Jun 23 2016 - 09:59:04 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0 (SD), SUNXI SD/MMC: 1
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
No controllers found
switch to partitions #0, OK
mmc0 is current device
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
mmc1(part 0) is current device
Scanning mmc 1:1...
2465 bytes read in 161 ms (14.6 KiB/s)
## Executing script at 43100000
gpio: pin PL10 (gpio 298) value is 1
   Warning: value of pin is still 0
gpio: pin PG11 (gpio 203) value is 1
Kernel image @ 0x48000000 [ 0x000000 - 0x4c7960 ]
## Loading init Ramdisk from Legacy Image at 42000000 ...
   Image Name:   uInitrd 3.4.112-sun8i
   Image Type:   ARM Linux RAMDisk Image (uncompressed)
   Data Size:    3138889 Bytes = 3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... Bad Data CRC
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
starting USB...
USB is stopped. Please issue 'usb start' first.
starting USB...
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB...
No ethernet found.
If I inssert sd card after starting kernel(about 5 seconds), armbian can boot successfully. Here is my config:
/boot/boot.cmd:
setenv bootargs "console=ttyS0,115200 console=tty1 root=/dev/mmcblk1p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 panic=10 consoleblank=0 enforcing=0 loglevel=${verbosity}"
/etc/fstab:
/dev/mmcblk1p1 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
/dev/mmcblk0p1 /mnt ntfs rw,auto,user,exec,nls=utf8,umask=003,gid=46,uid=1000 0 0
lsblk cmd:
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk1boot0 179:32   0    4M  1 disk
mmcblk1boot1 179:48   0    4M  1 disk
mmcblk0      179:0    0  7.4G  0 disk
└─mmcblk0p1  179:1    0  7.4G  0 part /mnt
mmcblk1      179:16   0  7.3G  0 disk
└─mmcblk1p1  179:17   0  7.2G  0 part /
How can i fix the boot problem?
thanks for anyone help.
