[Mini M8S] Realtek RTL8723BS Module Driver
sukanime
Hi... Thanks for making Armbian... ^_^
I Have Mini M8S Android TV Box with Wifi RTL8723BS, i have using Armbian from here http://forum.armbian.com/index.php/topic/1143-armbian-for-amlogic-s905/
I can boot to Armbian, but Wifi not working.
But In LibreELEC 7.0.2 the wifi is working, so i cross check, and i found this:
#                 LibreELEC                  #
#            http://libreelec.tv             #
LibreELEC (community) Version: 7.0.2.007
LibreELEC:~ # lsmod
Module                  Size  Used by
hci_uart               21997  1
bluetooth             243164  2 hci_uart
6lowpan_iphc            5895  1 bluetooth
8723bs               1675347  0
cfg80211              359903  1 8723bs
8021q                  18309  0
wifi_dummy               806  0
aml_nftl_dev           82924  0
fbcon                  37385  0
bitblit                 4508  1 fbcon
softcursor              1200  1 bitblit
font                    7295  1 fbcon
LibreELEC:~ # uname -a
Linux LibreELEC 3.14.29 #1 SMP Fri Sep 9 11:17:50 MSK 2016 aarch64 GNU/Linux
LibreELEC:~ # cd /lib/modules/
LibreELEC:/lib/modules #
LibreELEC:/lib/modules # ls
3.14.29
LibreELEC:/lib/modules # find . | grep 8723
./3.14.29/kernel/drivers/amlogic/wifi/rtl8723AU
./3.14.29/kernel/drivers/amlogic/wifi/rtl8723AU/8723au.ko
./3.14.29/kernel/drivers/amlogic/wifi/rtl8723BS
./3.14.29/kernel/drivers/amlogic/wifi/rtl8723BS/8723bs.ko
So the problem is the driver not compiled when building the kernel.
is anyone have wifi module driver in /kernel/drivers/amlogic/wifi/ ?
can i have it?
Thanks...
In the Assembly LE , in the options specified.
https://github.com/150balbes/LibreELEC.tv/blob/Amlogic-S905-kszaq/projects/S905/options
  # additional Firmware to use (dvb-firmware, misc-firmware, wlan-firmware)
  # Space separated list is supported,
  # e.g. FIRMWARE="dvb-firmware misc-firmware wlan-firmware"
    FIRMWARE="misc-firmware wlan-firmware dvb-firmware brcmfmac_sdio-firmware-aml rtl8723bs_bt"
The description of the Assembly
https://github.com/150balbes/LibreELEC.tv/tree/Amlogic-S905-kszaq/projects/S905/packages/linux-firmware
Thanks a lot balbes150 :)
I will try it....
Edit 01-10-2016:
The driver option not the one posted by balbes150 above.
But in here https://github.com/kszaq/LibreELEC.tv/blob/libreelec-7.0/projects/S905/linux/linux.aarch64.conf
Here the quote:
# Amlogic Wifi Driver
CONFIG_AM_WIFI=y
# CONFIG_BCMDHD_USE_STATIC_BUF is not set
CONFIG_AM_WIFI_DUMMY=m
CONFIG_RTL8189ES=m
CONFIG_RTL8189FS=m
CONFIG_RTL8192EU=m
CONFIG_RTL8723AU=m
CONFIG_RTL8723BS=m
CONFIG_RTL8821AU=m
CONFIG_RTL8812AU=m
But i cannot find the driver in the linux-amlogic source code - http://sources.libreelec.tv/devel/linux-amlogic-3.14-9c0ad98.tar.xz
Right now, i will try building LibreELEC....
Edit again: i found it, in here https://github.com/kszaq/linux/tree/amlogic-3.14.y
Edit - 7 October 2016:
It's solved, i have post it in here
https://forum.armbian.com/index.php?/topic/2419-armbian-for-amlogic-s905-and-s905x/&do=findComment&comment=17181
sukanime,
I have an M8S S812 with the WiFi and Bluetooth chip RTL8723BS and I am trying to find a full SD flash package to run OpenElec or LibreElec. Right now I am able to flash an android 5.1 ROM and everything but WiFi and Bluetooth work...and I could really use help!
I have been trying to follow what you mentioned about compiling drivers with the kernel header but I am totally lost. I have Ubuntu and Windows and all of the equipment except for an OTG.
Can you help please @sukanime?
On 24/12/2016 at 2:14 AM, siruok said:
sukanime,
I'am sory for late reply, i never go to this topic.
so if you not quote me, i will not get the notifications.
for what purpose? do you want to compile LibreELEC for your Mini M8S ?
i thinks, Kzaq already have LibreELEC for your Mini M8S.
