RK3328 Kernel
Peba
Hmmm, no idea, that doesn't actually look like a bluetooth keyboard, to be honest, it's just popping up as a standard generic HID device.
[    1.996363] usb 1-1.3: new low-speed USB device number 3 using dwc2
[    2.079542] usb 1-1.3: New USB device found, idVendor=046e, idProduct=5577
[    2.079556] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.079566] usb 1-1.3: Product: USB Multimedia Cordless Keyboard
[    2.079574] usb 1-1.3: Manufacturer: BTC
[    2.083962] input: BTC USB Multimedia Cordless Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046E:5577.0001/input/input0
[    2.135850] hid-generic 0003:046E:5577.0001: input,hidraw0: USB HID v1.11 Keyboard [BTC USB Multimedia Cordless Keyboard] on usb-ff540000.usb-1.3/input0
[    2.143143] input: BTC USB Multimedia Cordless Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:046E:5577.0002/input/input1
[    2.195087] hid-generic 0003:046E:5577.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [BTC USB Multimedia Cordless Keyboard] on usb-ff540000.usb-1.3/input1
perhaps if you could boot the other images that don't recognize it, with it plugged in, and do the same thing?  I'm kind of curious now...
I would if I could, but I've no way to log into the device on the standard images as this is my only keyboard! Maybe they'd let me borrow one from work.
I have to say thanks thanks for all your work and input in this thread. When I got this device I was unaware of armbian, and happened to discover it because you posted a link in the asus forum: https://tinkerboarding.co.uk/forum/thread-330.html
I found armbian and its users so interesting I must have read this entire thread two or three times! If you follow the link above you can see how I followed your example with GPIO power and an uprated heatsink and was able to hacksaw a hole into my case and attach a little fan! You can even see my dongle :o
On 7/25/2017 at 5:43 AM, RickyTerzis said:
external HDD's assuming they won't spin up on the USB alone.
I haven't had a problem powering a 2.5" hard drive from the USB port
It's much better than my Pine64 boards. They reboot when plugged in and the hard drive refuses to spin up.
Try to execute lsmod on the working kernel. Since most drivers are compiled modules, that should tell you what is the driver, I think. Then, from the module name, you can retrace the config option required and its dependencies.
It might also be possible to determine the driver used using /sys nodes. But I don't know how exactly. udevadm can also help you.
But yeah, try lsmod first.
But wait... you got Bluetooth working on 4.12 kernels ? Are you using an external Bluetooth dongle or did you just start your Bluetooth keyboard and it worked out the box ?
Edit : Ah, didn't read correctly, you're using an external dongle. Well given the bad feedback I got from the tinkering forum on the internal Bluetooth, I guess it's the best choice.
root@tinkerboard:/home/bedalus# lsmod
Module                  Size  Used by
snd_soc_hdmi_codec     16384  0
r8723bs               552960  0
dw_hdmi_i2s_audio      16384  0
mali_kbase            319488  0
Nothing to see with lsmod. However, udevadm gives me:
root@tinkerboard:/home/bedalus# udevadm info --query=all /dev/input/by-id/usb-BTC_USB_Multimedia_Cordless_Keyboard-event-kbd
P: /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046E:5577.0001/input/input0/event0
N: input/event0
S: input/by-id/usb-BTC_USB_Multimedia_Cordless_Keyboard-event-kbd
S: input/by-path/platform-ff540000.usb-usb-0:1.3:1.0-event-kbd
E: BACKSPACE=guess
E: DEVLINKS=/dev/input/by-path/platform-ff540000.usb-usb-0:1.3:1.0-event-kbd /dev/input/by-id/usb-BTC_USB_Multimedia_Cordless_Keyboard-event-kbd
E: DEVNAME=/dev/input/event0
E: DEVPATH=/devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046E:5577.0001/input/input0/event0
E: ID_BUS=usb
E: ID_INPUT=1
E: ID_INPUT_KEY=1
E: ID_INPUT_KEYBOARD=1
E: ID_MODEL=USB_Multimedia_Cordless_Keyboard
E: ID_MODEL_ENC=USB\x20Multimedia\x20Cordless\x20Keyboard
E: ID_MODEL_ID=5577
E: ID_PATH=platform-ff540000.usb-usb-0:1.3:1.0
E: ID_PATH_TAG=platform-ff540000_usb-usb-0_1_3_1_0
E: ID_REVISION=0310
E: ID_SERIAL=BTC_USB_Multimedia_Cordless_Keyboard
E: ID_TYPE=hid
E: ID_USB_DRIVER=usbhid
E: ID_USB_INTERFACES=:030101:030102:
E: ID_USB_INTERFACE_NUM=00
E: ID_VENDOR=BTC
E: ID_VENDOR_ENC=BTC
E: ID_VENDOR_ID=046e
E: MAJOR=13
E: MINOR=64
E: SUBSYSTEM=input
E: USEC_INITIALIZED=4130433
E: XKBLAYOUT=us
E: XKBMODEL=pc105
So usbhid. I think I'll borrow a keyboard from work then we can find out for sure. IKONFIG is set, so if I'm able to use a different keyboard and log in, I can diff the exact config used against the nightly.
My tinker board appears to have crashed again after 1.8 weeks of uptime.
Power supply is the micro-USB "official" RPi one, and it's rated at 2.5A , the SD card appears to be fine.
Symptoms:
  1. Only the red led was powered on, I had no green (I/O) or yellow led (heartbeat) activity.
  2. When removing the power cord and reinserting it, it would power-on for a couple of seconds and then it would power-off by itself.
  3. I left it powered-off for around 2 minutes and then powered it on and it's working ok so far.
  4. I checked my graphs and I see that over the course of the last 2 weeks, the CPU was sustaining temps between 61-65.5 °C.
  5. Right now I'm noticing a 74°C temperature spike, which is slowly coming down to the previously observed temperatures. (This graph displays the last 24h)
I'm not sure why the CPU raises it's temperature if the system has crashed. I've also reviewed the syslog and kernel logs, but I cannot find anything that would point me to the cause of the crash.
It also must've refused to start because it was overheated, but why does it always work fine for almost two weeks and then suddenly decides to die? I would appreciate any pointers to help me investigate.
Using mainline kernel.
root@Tuxbox:~# lsb_release -a && uname -r
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.2 LTS
Release:        16.04
Codename:       xenial
4.11.6-rockchip
... and its completely normal that it crashes when microUSB powering method is used. Its a fail by design and its a double fail when used with such a power hungry chip. Even your PSU gives you 100 A you will still face the same problem.
https://forum.armbian.com/index.php?/forum/31-sd-card-and-power-supply/
Power via GPIO.
Well, I was allowed to borrow a USB keyboard from work, and I flashed the standard version with the mainline kernel, and...
[    2.033927] usb 1-1.3: new low-speed USB device number 3 using dwc2
[    2.116818] usb 1-1.3: New USB device found, idVendor=046e, idProduct=5577
[    2.116831] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.116841] usb 1-1.3: Product: USB Multimedia Cordless Keyboard
[    2.116850] usb 1-1.3: Manufacturer: BTC
[    2.212636] usb 3-1: config 1 has an invalid interface number: 255 but max is 6
[    2.212648] usb 3-1: config 1 has no interface number 6
[    2.214117] usb 3-1: New USB device found, idVendor=0bda, idProduct=481a
[    2.214130] usb 3-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    2.214139] usb 3-1: Product: USB Audio
[    2.214148] usb 3-1: Manufacturer: Generic
[    2.214156] usb 3-1: SerialNumber: 201405280001
[    4.333263] input: Generic USB Audio as /devices/platform/ff500000.usb/usb3/3-1/3-1:1.255/0003:0BDA:481A.0003/input/input1
[    4.385590] hid-generic 0003:0BDA:481A.0003: input,hiddev0,hidraw0: USB HID v1.11 Device [Generic USB Audio] on usb-ff500000.usb-1/input255
USB 1-1.3 never gets allocated as an input device, even though it's detected (USB 3-1 later gets a device, which are the bottom two lines after I cut an irrelevant section). So perhaps something to do with some hid options? I took the diff between the configs:
> CONFIG_HID_ACCUTOUCH=m
> CONFIG_HID_CP2112=m
> CONFIG_HID_NTI=m
Not sure if these are relevant, it's difficult for me to guess whether it was a config option that helped, maybe it was just some mainline commit that fixed something between 4.11 and 4.12.
Anyway, if you want to pursue the reason, I've attached the output of armbianmonitor -u and the diff between the two kernel configs. I'm out of ideas, but happy and lucky to have a working cordless keyboard!
armhwinfo.log
config.diff
On 16/05/2017 at 7:31 AM, tkaiser said:
minerd --benchmark
[...] I would recommend testing with cpuminer (minerd --benchmark) since this tool provides a khash/sec output so you're able to detect throttling pretty easy. [...] If you Tinkerboard owners are able to improve heat dissipation that much that you get a constant +8 khash/sec value then you start to test for powering problems on this board.
EDIT: I deleted a lot of the results I just posted after re-reading the thread... It's all been done before! I got similar resuls as others who've done the test, around 6.6khash/s followed five minutes later by a decline to around 6.1, caused by thermal throttling to ~1.7GHz.
At least I seem to have a stable setup. Any other tests I can run on armbian's behalf? Anything I can do to help, I'm happy to give it a go.
Thanks for your hard work getting the Tinkerboard running Armbian guys!
On 17/07/2017 at 1:57 PM, lafalken said:
Sounds great! Would like to see an clean version without desktop too.
I would like to use this card as webb server, but is it stable enough for such use? For that I would use a usb-hdd, network cable and power. All other things like wireless is of no use for me. But a reboot that does not work is not very good ;(
I'd like to use it headless as well running Debian instead of Ubuntu, transcoding would be a bonus, but not required!
I'm currently not using the board, waiting for things to stabilise a bit more..  I've set it up (with a 3amp PSU) & it's ready to go. I'm more than happy to test some images on it though if needed.
I've been waiting for my Sentio Superbook to turn up (I think it will arrive in a month or two) so I haven't had much use for my tiny portable desktop, which has gathered some dust over the last few weeks. I've sneezed it off, and flashed the lastest nightly Armbian_5.32.170916_Tinkerboard_Ubuntu_xenial_dev_4.13.0_desktop.7z (2017-09-15 08:10 589.2 MB)
I'm happy to report that my bluetooth keyboard continues to work with the nightlies, and since the last version I tested, I'm extremely pleased to now find that there is a login screen. Also, Chromium now works again. Another thing that had bugged me, being prompted for admin password for wifi reconnect, has now been fixed. I'm well chuffed.
I would recommend using the last 4.12 image for now, there is a bug messing up the thermals so I'm not sure if it's wholly safe.  There is a pointer error occurring while initializing the tsadc, and I've not been able to track it down yet.
@Igor it would be best to pull the 4.13 images if possible, they don't actually provide any additional functionality, I was hoping to have this cleaned up yesterday, but it wasn't as simple as I thought.  With broken thermal zones and this board's garbage heatsink...
@Myy can you confirm that the tsadc is working on your 4.13 kernel?  I'm working my way through the patches/drivers/etc, but confirmation it is/isn't a 4.13 problem would be great.
True. I removed old nightly builds and their creating until this is not solved.
On 9/16/2017 at 9:25 AM, tkaiser said:
Can you please post the output of 'psd p' please (should look like https://wiki.archlinux.org/index.php/profile-sync-daemon#Preview_.28parse.29_mode and I'm interested in activation mode and overlayfs size)
bedalus@tinkerboard:~$ psd p
Profile-sync-daemon v6.31 on Ubuntu 16.04.3 LTS
 Systemd service is currently inactive.
 Systemd resync-timer is currently inactive.
 Overlayfs v23 is currently active.
Psd will manage the following per /home/bedalus/.config/psd/psd.conf:
 browser/psname:  chromium/chromium
 owner/group id:  bedalus/1000
 sync target:     /home/bedalus/.config/chromium
 tmpfs dir:       /run/user/1000/bedalus-chromium
 profile size:    42M
 overlayfs size:
 recovery dirs:   none
Thank you, then it's not just me. And there is something wrong: https://github.com/armbian/build/blob/8d211eec2c15feb1e77d8dee7bf45ee7ef645eab/packages/bsp/common/etc/profile.d/check_first_login.sh#L13-L32
With psd active your Chromium performance will increase by magnitudes.
Hello. I installed armbian on my tinkerboard but when I install packets python with PIP I have problems of access right. I also have problems with the Network Manager where I can not change connection. Everything is grayed out.
how to remedy these 2 problems of right of access that I think are related.
What image did you use, and what did you use to flash it to the SD card?  I have not encountered any issues with network manager in my testing/use.  For Python I'm afraid I'm not the expert resource.
