Boot Time
Nikolai Asparuhov
 systemd-analyze blame output:
          5.171s networking.service
          2.736s armhwinfo.service
          2.422s isc-dhcp-server.service
          1.782s systemd-logind.service
          1.482s alsa-restore.service
          1.193s rsyslog.service
          1.159s systemd-user-sessions.service
          1.156s rc-local.service
          1.046s systemd-journal-flush.service
           899ms loadcpufreq.service
           809ms keyboard-setup.service
           769ms motion.service
           749ms systemd-udev-trigger.service
           739ms fake-hwclock.service
           709ms kmod-static-nodes.service
           706ms ntp.service
           689ms systemd-setup-dgram-qlen.service
           602ms lirc.service
           579ms systemd-modules-load.service
           559ms sysstat.service
           529ms hddtemp.service
           505ms hostapd.service
           429ms console-setup.service
           394ms dev-mqueue.mount
           379ms netfilter-persistent.service
           359ms systemd-tmpfiles-setup.service
           343ms sys-kernel-debug.mount
           339ms keymap.service
           309ms cpufrequtils.service
           279ms kbd.service
           279ms systemd-sysctl.service
           249ms systemd-tmpfiles-setup-dev.service
           249ms systemd-rfkill@rfkill0.service
           239ms udev-finish.service
           159ms hdparm.service
           149ms sys-fs-fuse-connections.mount
           146ms user@0.service
           129ms systemd-random-seed.service
           128ms var-swap.swap
            99ms systemd-update-utmp.service
            89ms systemd-remount-fs.service
            79ms sysfsutils.service
            72ms tmp.mount
            18ms systemd-update-utmp-runlevel.service
            15ms systemd-udevd.service
here is mine on opi pc:
          6.009s shorewall.service
          4.820s armhwinfo.service
          2.048s rpimonitor.service
          2.016s alsa-restore.service
          1.988s sec.service
          1.729s networking.service
          1.727s ifplugd.service
          1.521s rc-local.service
          1.279s hostapd.service
          1.269s hddtemp.service
          1.260s lirc.service
          1.208s gpm.service
          1.149s systemd-udev-trigger.service
          1.147s rpimonitor-helper.service
          1.129s loadcpufreq.service
          1.048s ntp.service
          1.019s systemd-setup-dgram-qlen.service
          1.004s systemd-journal-flush.service
           939ms fake-hwclock.service
           879ms keyboard-setup.service
           720ms dev-mqueue.mount
           647ms rsyslog.service
           639ms kmod-static-nodes.service
           623ms sys-kernel-debug.mount
           619ms blacklists.service
           619ms systemd-modules-load.service
           609ms keymap.service
           549ms systemd-user-sessions.service
           509ms console-setup.service
           499ms systemd-sysctl.service
           410ms kbd.service
           359ms cpufrequtils.service
           359ms systemd-tmpfiles-setup-dev.service
           319ms systemd-tmpfiles-setup.service
           214ms sys-fs-fuse-connections.mount
           209ms hdparm.service
           199ms systemd-random-seed.service
           191ms var-swap.swap
           189ms udev-finish.service
           169ms shorewall6.service
           159ms systemd-update-utmp.service
           115ms user@0.service
           114ms systemd-logind.service
           113ms systemd-udevd.service
            89ms sysfsutils.service
            79ms systemd-remount-fs.service
            43ms systemd-update-utmp-runlevel.service
            42ms systemd-tmpfiles-clean.service
            11ms tmp.mount
is there a problem with network or name resolution?
dns timeouts?
gnasch
I have dongle rtl8192cu it is so big garbage, until now i have some drivers for it but it crushes some times and have unstable connection. Try these drivers from git hub:
https://github.com/pvaret/rtl8192cu-fixes
and no improvement. Any suggestions?
Those drivers should be fine / the best what's out there ... strange. Well, those dongles are shit in first place ...
Alternative is (testing) mainline kernel. We provide automated nightly builds ... but you are on your own.
The second problem is the usb camera. It require reboot to be ok, if i disconnect the power supply and plug it in, it doesn't recognize the usb camera properly (almost in 70-80% of the test cases)
dmesg output:
[    1.230073] usb 3-1: new high-speed USB device number 2 using sunxi-ehci
[    5.198897] usbcore: registered new interface driver rtl8192cu
[    5.211860] usbcore: registered new interface driver uvcvideo
lsusb output:
Bus 003 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 006 Device 002: ID 058f:3822 Alcor Micro Corp.
lsmod output:
uvcvideo               58868  1
ir_lirc_codec           3650  0
lirc_dev                7834  1 ir_lirc_codec
ir_mce_kbd_decoder      2885  0
ir_sanyo_decoder        1480  0
ir_sony_decoder         1422  0
8192cu                520861  0
But when i start mjpeg streamer:
 MJPG Streamer Version: svn rev: 3:172
 i: Using V4L2 device.: /dev/video0
 i: Desired Resolution: 1280 x 720
 i: Frames Per Second.: 15
 i: Format............: MJPEG
i: The format asked unavailable, so the width 640 height 480
 o: www-folder-path...: /usr/local/www/
 o: HTTP TCP port.....: 8080
 o: username:password.: disabled
 o: commands..........: disabled
and V4L output:
v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
        Index       : 0
        Type        : Video Capture
        Pixel Format: 'MJPG' (compressed)
                        Interval: Discrete 0.033s (30.000 fps)
So after a reboot wifi dongle may be work good may be not, the camera always is good after reboot.
v4l output after a reboot:
        Index       : 0
        Index       : 1
        Pixel Format: 'YUYV'
        Name        : YUV 4:2:2 (YUYV)
                        Interval: Discrete 0.100s (10.000 fps)
So what is going on here, wifi dongle is shit ok, can u provide me a link to 5.20 distro for OPI Lite so i can check it if the drivers will be fine for the dongle and the camera and why the boot time is so high, because of the network services that starts ( we have ap on wlan0 and dongle on wlan1 who is connect to the internet)?
Most likely the device does not get enough power check used cable and charger.
Hmmm i guess ill need other type of charger because this one is from Orange Pi factory and its without removable cable.... But some other news are on 5.25 clean distro with  8192cu-fixed driver from git hub the dongle work fine, may be the problem was during the upgrade from 5.23 to 5.25. But the problem with the camera is the same. Boot time is low because of hostap services (around 25 sec to load them all) and the camera just don't wanna
