[OrangePi Plus 2] Question with external DD in usb more than 2to
paul75
According to https://linux-sunxi.org/Xunlong_Orange_Pi_Plus#SATA this should work,
if you provide sufficient power of good quality.
There seems to be no 2TB limit mentioned in the gl830 sata bridge datasheet
here: http://pdf1.alldatasheet.com/datasheet-pdf/view/207044/GENESYS/GL830.html
best, gnasch
Hello,
Thanks but i mean not in sata but in usb device.
I test with HGST 3To it works with GPT mode and ntfs but when restart with HHD conect allthe system failed. nothing appear in screen.
Alqso if i debranch HDD not start.
I must reinstall all the system ....
Hello
I use a hdd and a box separatly.....
Hdd infernal and case with USB
That problem is nuit when i plug in the system when it works but when after want to reboot the system failed to restart and kill the kernel....
