dk13 Posted April 11, 2017 Share Posted April 11, 2017 I have a windows 7 laptop and the A20 cubietruck board with Mainline 4.9.7 Debian Jessie and I need to achieve an ssh connection between them via a wireless router.On cubietruck I have installed opnssh-client and openssh-server and have checked that it listens to port 22. On windows I try with putty to connect to board via ssh. The connection is done , I give username and password but then it freezes and I cannot access any of the folders of the debian. I also tried the mobaxterm but the same result. Does anyone has an idea of what I have done wrong? Link to comment Share on other sites More sharing options...
martinayotte Posted April 11, 2017 Share Posted April 11, 2017 Quote On cubietruck I have installed opnssh-client and openssh-server I don't understand what you did ! Both SSH client and server is already installed in any Armbian, so why did you had installed ? Quote I give username and password but then it freezes and I cannot access any of the folders After proper login, this should bring you a shell, in this shell you can do commands like "ls" to see all the files and folders. Link to comment Share on other sites More sharing options...
