Orange Pi Plus 2E Won't boot Armbian
pluton
Hello everyone,
First of all, sorry for my bad English.
Quick description of my problem: I recently buy three Orange Pi Plus 2E with official case and official AC adapter.
On this three cards I want to use Armbian, I use the last version of Armbianfound here: https://www.armbian.com/orange-pi-plus-2e/
Write on SD card with Win32DiskImager.
For information, I use a Samsung EVO 16G SD Card, same HDMI cable, same screen and official A/C adapter.
For two cards, no problem, boot on  Armbian on SD card and install on emmc in 10 minutes, but the last one have some problem...
The last card won't boot on SD card with Armbian: black screen, no keyboard reaction and green led on the card.
I test some other image I found on internet (forum orangepi) and the result is very strange: desktop image work perfectly (Ethernet controller,usb, screen, writeemmcworks) but server image not! Only one Debian server image works but not the ethernet controller...
I have some knowledge in Linux (I'm a Java Dev) but here I don't understand what happens with this card...
If anyone has an idea I'm interrested!
Thanks in advance.
Hi,
Thanks for your response!!
I think this is the problem, i move the switch and armbian boot one time but freeze after :(
There is a another solution to install to emmc armbian from a another linux system (with img file or usb stick flashed)?
This: https://github.com/zador-blood-stained/fel-mass-storage (discussion and details here).
Alternatively you can load the u-boot via FEL mode, boot Armbian from USB and then install/write to eMMC.
Thanks, I tested like this:
  • Flash SD Card with image on Github
  • Plug usb to card and PC
  • Windows detect card as Unknow Device 1
  • Install WinUSB with Zadig
Then, nothing I Can see SD or EMMC from "My PC", did i miss anything?
Ok i miss this page: https://linux-sunxi.org/FEL/USBBoot
work on it
EDIT; So i use the sunxi-fel.exe and command "sunxi-fel.exe version" give me that:
AWUSBFEX soc=00001680(H3) 00000001 ver=0001 44 08 scratchpad=00007e00 00000000 00000000
Next, I use "sunxi-fel.exe uboot u-boot-sunxi-with-spl.bin" with u-boot-sunxi-with-spl.bin from your repo, after somes try i got in console: starting -boot...
but nothing append.
I miss anything?
Ok, i execute start.bat (i use Win10  x64), this is the result (after some tries, I hava a lot of timeout):
\fel-mass-storage-master>start.bat
"Connect device in FEL mode and press <Enter>"
Appuyez sur une touche pour continuer...
Stack pointers: sp_irq=0x00002000, sp=0x00005E08
MMU is not enabled by BROM
Generating the new MMU translation table at 0x00008000
=> Executing the SPL... done.
Setting write-combine mapping for DRAM.
Setting cached mapping for BROM.
Writing back the MMU translation table.
Enabling I-cache, MMU and branch prediction... done.
Writing image "U-Boot 2016.09-armbian-fel-mass-", 247509 bytes @ 0x4A000000.
100% [================================================]  4575 kB,  940.7 kB/s
100% [================================================]    21 kB,  984.9 kB/s
100% [================================================]  2230 kB,  935.3 kB/s
100% [================================================]     0 kB,   82.6 kB/s
Passing boot info via sunxi SPL: script address = 0x43100000
Starting U-Boot (0x4A000000).
After that i see emmc in partition manager.
i flash it with win32 and etcher but nothing boot after flash. :'(
I did something wrong ?
@zador.blood.stained I test again today, this is how i do it:
- Plug SD card and micro sd cable in Orange Pi
- Card is detected by sunxi-fel.exe.
- Use script start.bat (I must do a lot of tries, i have a lot of timeout)
- Card disconnect and reconnect as a windows storage
- Remove all partitions and formate it (i can acess from explorer)
- Flash the last Armbian with win32diskimage or etcher
- Disconnect and boot without sd
- Same result with a sd card: black screen...
Do you know what i did wrong in this steps?
Do you have uboot file to boot with usb with a orange pi plus 2e?
Thanks for all your help with my problem...
Not a good sign. Possibly powering issues or bad USB cable
Serial log please
You can extract it (u-boot-sunxi-with-spl.bin) from here (assuming you are using a legacy kernel based image): http://beta.armbian.com/pool/main/l/linux-u-boot-orangepiplus2e-default/
Serial log please
Thanks for your help really @zador.blood.stained.
For information, I open a mediation with aliexpress, this card have some problems i think...
In fact, I need to push the upgrade key on the board for writing with sunxi-fel and it's work 2 on 3 times.
How can give you serial log?
I extract it, I nee to use only this file to write on board or bin + other file in your repo?
I search for give you serial console @zador.blood.stained but I don't have any cable for that... :(
Do you think I can write to emmc the .img file from a other OS?
Or do you have any solution to use the old u-boot with Armbian?
Now, I'm totally lost and Aliexpress won't refund me...
Armbian does not support the legacy u-boot, and u-boot is only a part of the problem, script.bin (for the kernel) has to be changed too.
You also may try booting other non-Armbian images and if they expose eMMC node (/dev/mmcblk1 or /dev/mmcblk2) it may be possible to flash Armbian image to eMMC from a running OS (i.e. using dd).
HI @zador.blood.stained ty for your attention of my problem.
I already test this solution with a version of ubuntu, I tested again tonight
According to this: https://bananapi.gitbooks.io/bpi-m3/zh/howtoburnlinuximagetoemmc.html
I use the same command, but with img name of Armbian Debian OrangePi + 2E, result of copy seem to be ok.
After unplug SD and reboot, same result: black screen, no keyboard reaction.
I think i will buy a ttl cable because I can't understant why this **** card won't working with armbian... :unsure:
I'm baaaack with a TTL Cable! :D
So this is how I process:
  • 1: test with a flash sd card with armbian.
    • TTL information in sdBoot.txt
    • @zador.blood.stained I think it's a sd card switch broken like you said..
  • 2: Boot in FEL mode, flash EMMC with Disk32Imager.
    • FEL Boot information in felBoot.txt.
  • 3: Boot with only TTL cable + A/C
    • Log in bootxMMC.txt.
    • Sometimes, boot stuck from at "Trying to boot from MMC2", I ned to plug and unplug A/C (cf boot3EMMC.txt).
I don't understand what happens on this card...
@zador.blood.stained these logs help you to understand? :unsure:
boot1MMC.txt
boot2MMC.txt
boot3MMC.txt
felBoot.txt
sdBoot.txt
Well, sdBoot.txt looks like abroken card detect switch.
Other logs, however, looks like eMMC issue or powering issue, but if you got errors writing image from FEL mode it can be related to bad eMMC contents.
So your best option is trying to bend/fix the SD switch first, if you can't make it work - then may be solder a piece of wire between SD card detect pin and ground to bypass the switch and boot from SD or prepare to recompile u-boot to skip the SD detection check.
I try again tonight to fix the SD switch, then I got this log with a sd card in sd card reader:
U-Boot 2017.01-armbian (Feb 02 2017 - 03:03:34 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Plus 2E
I2C:   ready
DRAM:  2 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   phy interface7
eth0: ethernet@1c30000
6944 bytes read in 155 ms (43 KiB/s)
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2652 bytes read in 191 ms (12.7 KiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
123 bytes read in 132 ms (0 Bytes/s)
 ** ext4fs_devread read error - block
The last line show a mmc error, no?
If it's possible to recompile uboot to bypass this SDCard verification, do you think it's a better alternative for all Orange Pi's images?
I'm not the first with this problem, as I can see in this forum...
Can you tell me where I can found some documentations about that?
Ok I test with 2 others sd card and a second A/C adapter.
Same result for the first SD card, tested with the two alimentations.
The second, after som tries (because I get block at : Trying to boot from MMC1), give me that:
I2C:   ready
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Net:   phy interface7
6944 bytes read in 158 ms (42 KiB/s)
Scanning mmc 0:1...
2652 bytes read in 194 ms (12.7 KiB/s)
123 bytes read in 134 ms (0 Bytes/s)
Unknown command '▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒data abort
pc : [<bdf714d4>]          lr : [<bdf67930>]
reloc pc : [<4a0184d4>]    lr : [<4a00e930>]
sp : b9f33c50  ip : bdfb0250     fp : 00000018
r10: b9f641a8  r9 : b9f38ee0     r8 : 00000000
r7 : 00000000  r6 : b9f643d8     r5 : b9f67426  r4 : 00000001
r3 : b9f67428  r2 : 00000000     r1 : fffffffe  r0 : b9f67430
Flags: nZCv  IRQs off  FIQs off  Mode SVC_32
Resetting CPU ...
resetting ...
U-Boot SPL 2017.01-armbian (Feb 02 2017 - 03:03:34)
DRAM: 2048 MiB
:huh:
11 hours ago, pluton said:
I think the last option is to recompile uboot...
No. The SD detection issue, as I said, is fixed.
Now:
- All recent Armbian images come with SHA256 checksum. Please use it to verify your downloaded image
- Please make sure that you used Etcher for writing the image to the SD card and that it was verified successfully.
- If after these steps you still have similar errors I can only assume hardware issues that cannot be diagnosed or fixed without replacing the board (assuming SD and power supply are of good enough quality.
Hi @zador.blood.stained
Ok I download again the Armbian_5.25_Orangepiplus2e_Debian_jessie_default_3.4.113.img and verify checksum, it's ok.
I use Etcher with my Samsung Evo 16Go it's ok too.
I use power supply from Orange Pi's seller (work with my two other boards).
And it's not work again... I plug and unplug a lot of times, and boot stuck everytimes.
I can't understand why other image boot correctly (on SD and EMMC) but not armbian.
There is nothing to do to patch armbian for this problem?
EDIT: I found a trick: push the upgrade bouton a armbian boot corectly 2 on 3 times from SD.
But when i release the button, Armbian crash...
I give you a log, when Armbian start and last line of this log it when the button is release.
Maybe a issue ?
upgradeButton.txt
No since it is an unknown hardware related issue. Well, there are different things to try like lima-memtester with different DRAM frequencies, measuring voltages on the test points, changing DVFS operating points, ... but it is a lot of work and requires some time even to explain this.
Well, i will use a other image on this board I think... :/
Last info, I can boot Armbian with Upgrade button pushed.
On the board, green led stick and red led flash.
I can interact in console, log in root but when I want to change the password, got:
Authentication token manipulation error
And when i release the upgrade key, Armbian crashe and print this:
1212[   80.401270] Unable to handle kernel paging request at virtual address 00100104
[   80.410019] pgd = c0004000
[   80.410019] [00100104] *pgd=00000000
[   80.410019] sunxi oops: enable sdcard JTAG interface
[   80.410019] sunxi oops: cpu frequency: 480 MHz
[   80.410019] sunxi oops: ddr frequency: 624 MHz
[   80.410019] sunxi oops: gpu frequency: 105 MHz
[   80.410019] sunxi oops: cpu temperature: 10
[   80.410019] Internal error: Oops: 805 [#1] PREEMPT SMP ARM
[   80.410019] Modules linked in: ir_lirc_codec lirc_dev ir_mce_kbd_decoder ir_sanyo_decoder ir_sony_decoder ir_jvc_decoder ir_rc6_decoder ir_rc5_decoder ir_nec_decoder
If this change anything, tell me I you want test an other solution.
Or else, stop waste your time with tis, I will use a other image.
Finally, thanks for all your help with this problem!
I will be back on Armbian on other card one day :D
