Problem using GPIO pins on legacy kernel
jimg
I'm trying to use a few of the GPIO pins as output pins on an Orange Pi PC+ running Armbian 5.26 and legacy kernel 3.4.113-sun8i.
When I look at the FEX file, it appears that the GPIO pins have all been disable
d by default:
    [gpio_para]
    gpio_used = 0
    gpio_num = 0
I don't recall them being disabled by default in previous versions of Armbian. I
s this a recent change?
Anyway, I edited the file and changed it to:
    [gpio_para]
    gpio_used = 1
    gpio_num = 3
    gpio_pin_1 = port:PA13<1><default><default><default>
    gpio_pin_2 = port:PA14<1><default><default><default>
    gpio_pin_3 = port:PD14<1><default><default><default>
then did the following:
    $ fex2bin /tmp/custom.fex /boot/bin/custom.bin
    $ ln -sf /boot/bin/custom.bin /boot/script.bin
    <reboot>
    $ modprobe gpio-sunxi
But I cannot seem to get the GPIO pins working:
     $ sudo echo 1 > /sys/class/gpio/export
     -bash: /sys/class/gpio/export: Permission denied
Any advice on what I'm doing wrong?
What is now the correct way to change the pin settings on kernel 3.4.113 if not modifying the FEX file? I didn't think it used Device Tree since it's below V 3.10. It still uses FEX files for other features (e.g., I got uart3 working on ttyS3 by simply editing the FEX file).
FWIW, I had also tried using the mainline pin numbers to turn them on and off but still had the same problem. The example Accessing the GPIO pins through sysfs on sunxi-3.4  on the sunxi wiki uses a sequential numbering system defined by the FEX file to access the pins, not the mainline pin numbering system. That's why I tried using the method I did.
You are correct: it's not necessary to modify the FEX file to use the GPIO pins, and you should use the mainline formula to calculate pin numbers.
I'll share what I learned attempting to solve this problem in case anyone else runs into it.
As the error states, it's a permissions problem. Using "sudo echo" won't work because the redirection occurs before sudo is started, which ends up you trying to write to a file you don't have permissions to.
To do a one-off manipulation of a GPIO pin, you have to start a separate shell as a superuser first, then use echo. For instance to turn pin A10 on:
$ sudo sh
# echo 10 > /sys/class/gpio/export
# echo out > /sys/class/gpio/gpio10/direction
# echo 1 > /sys/class/gpio/gpio10/value
Or you can use tee to avoid creating a subshell:
$ echo 10 | sudo tee /sys/class/gpio/export
$ echo out | sudo tee /sys/class/gpio/gpio10/direction
$ echo 1 | sudo tee /sys/class/gpio/gpio10/value
A better, more permanent solution is to create a separate GPIO group, add yourself as a user to that group, and then give the GPIO group permissions to modify the GPIO pin directories:
$ sudo groupadd gpio
$ sudo usermod -aG gpio <your_username>
$ su <your_username>
$ sudo chgrp gpio /sys/class/gpio/export
$ sudo chgrp gpio /sys/class/gpio/unexport
$ sudo chmod 775 /sys/class/gpio/export
$ sudo chmod 775 /sys/class/gpio/unexport
You'll also have to modify the permissions on the directory of each GPIO pin you add. Again using pin A10 as an example:
$ echo 10 > /sys/class/gpio/export
$ chgrp -HR /sys/class/gpio/gpio10
$ chmod -R 775 /sys/class/gpio/gpio10
Then you can change that pin as necessary without being a superuser:
$ echo out > /sys/class/gpio/gpio10/direction  # set as output pin
$ echo 1 > /sys/class/gpio/gpio10/value        # set high
$ echo 10 > /sys/class/gpio/gpio/unexport      # reset the pin
You can use "tee" command like this:
Or this can be solved with udev rules, but it needs to be tested on different kernels to be included in default Armbian installations
