gnasch Posted April 22, 2017 Share Posted April 22, 2017 Hello, today I want to connect the OpiPcPlus to a Flexscan S1921 Monitor. I select h3disp -m 33 -d to use my *tested* hdmi-to-dvi cable and reboot. Now the monitor complains: fV: 59.9 Hz fH: 63.9 kHz fD: 161.7 MHz ****red*** this seems too high because VESA mode should use a pixel frequency of 108MHz which is also the spec of the monitor. 1280x1024 @ 60Hz (VESA) hsync: 64.0kHz 1280x1024 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync The pixel frequency seems too high for the 60 Hz image refresh, it corresponds to 85 Hz. I am using legacy kernel: Linux JagOpi 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l GNU/Linux Any ideas? Thanks, gnasch Link to comment Share on other sites More sharing options...
gnasch Posted April 24, 2017 Author Share Posted April 24, 2017 bump - where could I find the relevant kernel sources? Did the armbian project patch this legacy kernel? Thanks gnasch Link to comment Share on other sites More sharing options...
tkaiser Posted April 24, 2017 Share Posted April 24, 2017 The HDMI relevant patches can be found here: https://github.com/igorpecovnik/lib/tree/master/patch/kernel/sun8i-default, kernel is pulled from there: https://github.com/igorpecovnik/lib/blob/master/config/sources/sun8i.conf#L10-L11 and there is an open bug report regarding h3disp: https://github.com/igorpecovnik/lib/issues/624 1 Link to comment Share on other sites More sharing options...
gnasch Posted May 6, 2017 Author Share Posted May 6, 2017 @tkaiser: thank you very much for your help. I was able to track down the bug. Contrary to first belief, the kernel is not concerned, but in h3disp on line 196 the pll_video is initialized to 646 MHz. With kernels divisor of 4 this results in pixel frequency of 161.5 MHz, which is too high for Vesa 1280*1024. So I replaced this initialization with 432 MHz, which results in correct fD of 108 MHz. Now the monitor synchronizes. Unfortunately I found a bugfix by @igor on 24.Oct.2016 which inserted the 646 MHz value. I could not read the reasoning behind this (facebook srsly?), so I would kindly ask to revert this change if no important reasons for it exist. best wishes and thanks to armbian team for your great work! gnasch 1 Link to comment Share on other sites More sharing options...
tkaiser Posted May 7, 2017 Share Posted May 7, 2017 https://github.com/armbian/build/commit/906528a03fa361447def71757d0c0ce746e55177#commitcomment-22046840 Please use Github if you want something to change. Information/requests in random forum posts might get lost. Link to comment Share on other sites More sharing options...
gnasch Posted May 7, 2017 Author Share Posted May 7, 2017 Thank you, will try to do so next time! gnasch Link to comment Share on other sites More sharing options...
ludwich Posted May 9, 2017 Share Posted May 9, 2017 I changed the value in h3disp manually to 432MHz (-m 33 -d). Now my Display DELL108FP (1280x1024 @60Hz) works well too. ludwich Link to comment Share on other sites More sharing options...
