Tinkerboard DVB drivers
tom-c2
Hello Forum,
i just got my new tinker board running with armbian, thanks for the good work !
I want to set up a vdr vnsi server on this to replace the existing Raspberry 2.
To get the DVB USB Skystar Tuners running several modules out of kernel/drivers/media like dvb-core and usb are needed.
Are this kernel drivers already compiled available or what to do to get them ?
Thanks
  Thomas
If those drivers are part of a kernel, tell me which should be enabled in kernel configuration:
4.4.x: https://github.com/armbian/build/blob/master/config/kernel/linux-rockchip-default.config
4.11.x: https://github.com/armbian/build/blob/master/config/kernel/linux-rockchip-next.config
or provide a patch / submit PR to our repository.
If they are not part of the kernel source, then you need to obtain source (and possible firmware) and proceed this way: https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver
Hello,
i think this are the first ones but then several DVB Tuner devices for USB and PCI will follow:
CONFIG_MEDIA_DIGITAL_TV_SUPPORT
CONFIG_V4L_PLATFORM_DRIVERS
My personal interest is in USB DVB Sky Star Module first, but there may be the other modules needed by others:
kernel/drivers/media/dvb/dvb-usb/dvb-usb-technisat-usb2.ko
Hello Tony,
can You please explain how the powersave settings are to be tuned ?
The data rates on USB would be about 10MBit/s per Transponder and i would like to install 3 USB tuners.
With 2 transponders on 3 tuners round about 60MBit/s on USB and this transferred to GBit LAN should be possible.
The Raspy 2 fails with more than 4 transponders because of the slow LAN attached behind USB.
