Please Test img Octoprint on Orange Pi Lite
prahjister
Can someone please test this img on Orange Pi Lite. 4gb sd card or larger
You can use nmtui to connect to wifi
Connect to wifi the point browser to port 5000 of the IP address to see if gui starts and doesn't have any issues. http://x.x.x.x:5000
Thank you for your help.
login root password octoprint
Full instructions here
http://www.cnx-software.com/2017/07/11/how-to-use-octoprint-on-orange-pi-lite-board-amlogic-s905x-and-s912-tv-boxes/
I'm also very interested in the 5MP camera opi comes with there is alreadya guy that figured it out. http://sanchosk.blogspot.ro/2016/08/orange-pi-one-and-camera.html
there is a forum post (that I'm not able to find at the moment) that makes it copy pastable but still there is no tut to combine all with Octo. This can be all scripted for !!!!!!armbian-config!!!!!!! instead of images.
Sorry guys thanks for the reply.
No Cura Engine on this build. It is really old so didnt see the need
Camera does work. Dont recommend opi camera. Not very good. But to use usb camera.  First plug in the camera. Go into settings and video adjust the one ip address from 10.0.0.40 to the IP address of your orange PI. Then under power button turn on the webcam
Is anyone successfully using this for multiple days?
I just start Testing , so far great , I was able to start the device , connect to my network , reach oktoprint, so im close to a few Tests, only one point I didnt get working so far ( sorry im a rel beginner) how to set a fixed IP adress for the wifi connection ?
br
Thomas
@prahjister Have you set up Avahi on that image? Just wondering if something like http://octoprint.local would work with your image, making IP addresses not necessary? Otherwise it's probably either setting a fixed address on your router, using (sudo) nmtui to configure the connection (assuming network manager is managing the connection) or some ugly /etc/network/interfaces edits.
octoprint.local is not working in mycase ( if that information is helping you)
one more point i just find out, I could sucessfully connect to the printer now , but the webcam only show me webcamstream loading .
Any idea for that Camera Point ?
br
Thomas
Thanks pfeerick the network point i could solve with your tip ( i not found the edit connectione before)
so finaly I only not get my logitech webcam runnng, hope someone have an idea here too.
tomorrow hope to test with a first print on it
BR
Thomas
I test the image for 10 days and so far everything work  great i have  one more question what is (
OctoPrint checkout folder path) so we can set auto plugin update.
 (Please configure the checkout folder of OctoPrint, otherwise this plugin won't be able to update it. )
 thanks
Thank you so much for the feedback. This is for an article I am writing and will update and make it easier with full instructions. Also one for s905x box.
Did you find wifi dropping periodically. I think I might have got a bad board.
I will setup avahi as well. Thank yoy
Also sorry for ling time between reply. I didn't have notifications setup properly
