7" hdmi display
Mike R9FT
Hi
I connect 7" hdmi display from waveshare to orange pi one on mainline dev kernel.
http://www.waveshare.com/wiki/7inch_HDMI_LCD
When it is powered before orange, it works ok.
But it don't work if it is powered at the same time.
I am tried to add hpd_delay at the top of  boot.cmd:
setenv video-mode sunxi:1024x768-24@60,monitor=hdmi,hpd=1,hpd_delay=20000,edid=1
saveenv
the do mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
But still no lack, display shows "no cable connected"
Also when board start up, u-boot show on serial console this if display powered up before board:
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi One
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   vidconsole
Err:   vidconsole
And this if display powered same time with board:
DRAM:  512 MiB
In:    serial
Out:   serial
Err:   serial
How can I debug this?
Also I tried another 5" hdmi display, that is working correctly (it have another hdmi chip, so it starts more quickly)
Actually you can't do much except patch U-Boot. H3 and newer chips uses driver in U-Boot which doesn't consider video-mode variable. Since kernel relies on U-Boot to set up HDMI for now, the only thing you can do is to create U-Boot patch and rebuild the image on your own. You only need to change line 131.
Thank you.
It is working now with this patch:
diff --git a/drivers/video/sunxi/sunxi_dw_hdmi.c b/drivers/video/sunxi/sunxi_dw_hdmi.c
index 33920a2..9ae547a 100644
--- a/drivers/video/sunxi/sunxi_dw_hdmi.c
+++ b/drivers/video/sunxi/sunxi_dw_hdmi.c
@@ -122,13 +122,14 @@ static int sunxi_dw_hdmi_get_plug_in_status(void)
 static int sunxi_dw_hdmi_wait_for_hpd(void)
        ulong start;
+       mdelay(3000);
        start = get_timer(0);
        do {
                if (sunxi_dw_hdmi_get_plug_in_status())
                        return 0;
                udelay(100);
-       } while (get_timer(start) < 300);
+       } while (get_timer(start) < 5000);
        return -1;
Is it possible to set timeouts from environment variable?
Touch screen is also working with following tune up
sun8i-h3-spi-ads7846.dts
/dts-v1/;
/plugin/;
        compatible = "allwinner,sun8i-h3";
        fragment@0 {
                target = <&pio>;
                __overlay__ {
                        ads7846_pins: ads7846_pins {
                                pins= "PA2";
                                function = "irq";
        fragment@1 {
                target = <&spi0>;
                __overlay__ {
                        #address-cells = <1>;
                        #size-cells = <0>;
                        status = "okay";
                        ads7846@0 {
                                compatible = "ti,ads7846";
                                reg = <1>; /* Chip Select 0 */
                                status = "okay";
                                pinctrl-names = "default";
                                pinctrl-0 = <&ads7846_pins>;
                                spi-max-frequency = <500000>;
                                interrupt-parent = <&pio>;
                                interrupts = <0 2 2>; /* PA7 IRQ_TYPE_EDGE_FALLING */
                                pendown-gpio = <&pio 0 2 0>; /* PA7 */
                                /* driver defaults, optional */
                                ti,x-min = /bits/ 16 <0>;
                                ti,x-max = /bits/ 16 <4095>;
                                ti,y-min = /bits/ 16 <0>;
                                ti,y-max = /bits/ 16 <4095>;
                                ti,swap-xy = <1>;
                                ti,pressure-min = /bits/ 16 <0>;
                                ti,pressure-max = /bits/ 16 <255>;
/*                              ti,x-plate-ohms = /bits/ 16 <180>;  */
                                ti,x-plate-ohms = /bits/ 16 <100>;
                                ti,debounce_max = /bits/ 16 <15000>;
                                ti,debounce_tol = /bits/ 16 <65535>;
                                ti,debounce_rep = /bits/ 16 <100>;
                                ti,vref-delay-usecs = /bits/ 16 <450>;
                                ti,keep_vref_on =  <1>;
                                ti,settle_delay_usecs = /bits/ 16 <100>;
                                ti,penirq-recheck-delay-usecs = /bits/ 16 <100>;
/etc/X11/xorg.conf.d/99-calibr.conf
Section "InputClass"
        Identifier      "calibration"
        MatchProduct    "ADS7846 Touchscreen"
        Option  "Calibration"   "154 3975 3933 66"
        Option  "SwapAxes"      "0"
EndSection
2 minutes ago, Mike R9FT said:
Is it possible to get it from environment variable?
Of course, consider following line in drivers/video/videomodes.c
char *p = getenv("video-mode");
Please note that video drivers are loaded very quickly, before U-Boot command line, so variable has to exist before. This can be achieved by setting variable and save it with "saveenv" command.
