Bongho Lee Posted July 26, 2017 Share Posted July 26, 2017 At first, I used 3.x kernel with Armbian_5.30_Orangepione_Ubuntu_xenial_default_3.4.113_desktop.img. This has a problem displaying my hdmi 5inch 800x600 lcd. So I changed the kernel to 4.x with nightly build image, Armbian_5.32.170706_Orangepione_Ubuntu_xenial_dev_4.11.8.img. It displays well from u-boot. For x window, I installed Xorg and ubuntu-desktop. When I run startx, it says unable to connect to X server: Connection refused. What should I do for x window? I want to use Chromium. Link to comment Share on other sites More sharing options...
Igor Posted July 26, 2017 Share Posted July 26, 2017 28 minutes ago, Bongho Lee said: At first, I used 3.x kernel with Armbian_5.30_Orangepione_Ubuntu_xenial_default_3.4.113_desktop.img. This has a problem displaying my hdmi 5inch 800x600 lcd. Our kernel supports many screen resolution but not this one. You need to do the math and add it. Check this patch and do some forum search for more info. You are not the first one with such problem. 31 minutes ago, Bongho Lee said: So I changed the kernel to 4.x with nightly build image, Armbian_5.32.170706_Orangepione_Ubuntu_xenial_dev_4.11.8.img. It displays well from u-boot. This kernel is not yet supported. It works or not. Try building dev image with desktop - this might be the best way. Link to comment Share on other sites More sharing options...
Bongho Lee Posted July 27, 2017 Author Share Posted July 27, 2017 I'll try to build dev image with desktop at first. My LCD was hdmi 5inch 800x480. I confused the resolution. After testing, I'll share the result. Thank you very much. 1 Link to comment Share on other sites More sharing options...
Bongho Lee Posted July 28, 2017 Author Share Posted July 28, 2017 Dev image with desktop works well with my 800x480 hdmi lcd on Orange Pi One. I just need using Chromium, so I don't want to install all the heavy desktop package. So I chose dev image without desktop option, and installed xorg and chromium-browser. But it says errors. Fatal server error: (EE) no screens found(EE) Do I have to install other things? Link to comment Share on other sites More sharing options...
Igor Posted July 28, 2017 Share Posted July 28, 2017 You want to run Chromium in kiosk mode? Just Chromium and nothing else? I never done it but there are projects out there which deal with this. Make sure to implement our Chromium optimizations if you want to achieve some decent browsing experience. Link to comment Share on other sites More sharing options...
Bongho Lee Posted December 3, 2017 Author Share Posted December 3, 2017 After updated Xorg package, this problem is solved. Link to comment Share on other sites More sharing options...
