BeauSlim Posted August 21, 2017 Share Posted August 21, 2017 It would be nice to be able to use hardware crypto for VPNs. The rockchip's hardware crypto acceleration has apparently been supported since Kernel 4.5. I noticed that the CONFIG_CRYPTO_DEV_ROCKCHIP option hadn't been compiled into the standard Armbian builds, so I built a custom kernel. Having the rk_crypto module loaded gives me additional ciphers in /proc/crypto as expected. Without the module loaded (either blacklisted with my build, or with the normal Armbian kernel), my tunnel (IKEv2/IPSEC w Strongswan) works fine. But with the module installed, no traffic passes. Sometimes I see kernel errors in syslog. A couple of times the box has locked up. I tried a -next build and a -dev build. I tried applying the 2 patches (https://patchwork.kernel.org/patch/9858691/ etc) from July onto the -dev build. No joy. Unfortunately, I'm used to working on PC hardware where AES-NI pretty much "just works," so I'm not really sure where to go from here. Am I missing something? Was the kernel module excluded due to a known issue? As a total aside, when I did the -next build, I enabled XZ for squashfs. This allows Ubuntu's snapd stuff to run. Works really very well on Armbian/Tinker. Worth including in the standard Armbian builds? Link to comment Share on other sites More sharing options...
TonyMac32 Posted August 21, 2017 Share Posted August 21, 2017 Welcome to the forum! 3 hours ago, BeauSlim said: Was the kernel module excluded due to a known issue? Not on my part, do you have the logged errors you were speaking of? 3 hours ago, BeauSlim said: As a total aside, when I did the -next build, I enabled XZ for squashfs. This allows Ubuntu's snapd stuff to run. Works really very well on Armbian/Tinker. Worth including in the standard Armbian builds? I was unaware of that entire system, looks interesting enough. Is there a specific benefit over normal package management, ease of publication/etc? Also, how on earth do you snap boot files and kernels? Ok, off-topic... Perhaps simply pull request with changes and explanation. @Igor, any harm? Or maybe a feature we'd want? Link to comment Share on other sites More sharing options...
Igor Posted August 21, 2017 Share Posted August 21, 2017 1 hour ago, TonyMac32 said: Igor, any harm? Or maybe a feature we'd want? IMHO if there is some need for snapd kernel wise, just add. Package/service install can be left for user to install. Link to comment Share on other sites More sharing options...
TonyMac32 Posted August 22, 2017 Share Posted August 22, 2017 I've added XZ for squashfs to dev and enabled crypto, I confirm it's loading and new ciphers reflected in /proc/crypto. I'm not sure what would be causing issue, trying to get some more background on it. Link to comment Share on other sites More sharing options...
Jamess Huang Posted August 24, 2017 Share Posted August 24, 2017 On 2017/8/21 at 8:50 AM, BeauSlim said: It would be nice to be able to use hardware crypto for VPNs. The rockchip's hardware crypto acceleration has apparently been supported since Kernel 4.5. I noticed that the CONFIG_CRYPTO_DEV_ROCKCHIP option hadn't been compiled into the standard Armbian builds, so I built a custom kernel. Having the rk_crypto module loaded gives me additional ciphers in /proc/crypto as expected. Without the module loaded (either blacklisted with my build, or with the normal Armbian kernel), my tunnel (IKEv2/IPSEC w Strongswan) works fine. But with the module installed, no traffic passes. Sometimes I see kernel errors in syslog. A couple of times the box has locked up. I tried a -next build and a -dev build. I tried applying the 2 patches (https://patchwork.kernel.org/patch/9858691/ etc) from July onto the -dev build. No joy. Unfortunately, I'm used to working on PC hardware where AES-NI pretty much "just works," so I'm not really sure where to go from here. Am I missing something? Was the kernel module excluded due to a known issue? As a total aside, when I did the -next build, I enabled XZ for squashfs. This allows Ubuntu's snapd stuff to run. Works really very well on Armbian/Tinker. Worth including in the standard Armbian builds? As I know the kernel version which rockchip release is kernel 4.4. Where can I get the Kernel 4.5 to do some test ? Link to comment Share on other sites More sharing options...
TonyMac32 Posted August 24, 2017 Share Posted August 24, 2017 You'll have to go to Github and clone the repo, look over the documentation (it's pretty straightforward) and build the "Rockchip Dev" image. Then you'll have an image for SD card to run tests with. Pre-built images don't currently have hardware crypto turned on. Link to comment Share on other sites More sharing options...
Rfreire Posted April 9, 2018 Share Posted April 9, 2018 (edited) Reviving a old thread, I was looking to enable the 3288 RNG that supposedly lies in the processor and I stumbled upon this thread. I was able to backport the aforementioned patchset (see in https://pastebin.com/fauem89j and I found zero changes in /proc/crypto :-P # Original kernel, no backport [root@tinkerboard shm]# uname -r 4.4.120-beleza9-rockchip [root@tinkerboard ~]# modinfo rk_crypto modinfo: ERROR: Module rk_crypto not found. [root@tinkerboard ~]# cat /proc/crypto > build9 [root@tinkerboard ~]# ll total 10968 -rw-r--r-- 1 root root 7502 Apr 9 03:00 build9 <-- here -rw-r--r-- 1 root root 28207 Apr 7 20:10 dmesg.txt -rw-r--r-- 1 root root 37713 Apr 8 14:34 dmesg.txt1 -rw-r--r-- 1 root root 38222 Apr 8 14:54 dmesg.txt2 =========== [root@tinkerboard ~]# uname -a Linux tinkerboard 4.4.120-beleza-10-rockchip #25 SMP Mon Apr 9 03:59:22 UTC 2018 armv7l GNU/Linux [root@tinkerboard ~]# cat /proc/crypto > build10-pre [root@tinkerboard ~]# ll total 11000 -rw-r--r-- 1 root root 7502 Apr 9 03:00 build9 -rw-r--r-- 1 root root 7502 Apr 9 04:03 build10-pre <==== here, prior to load module -rw-r--r-- 1 root root 28207 Apr 7 20:10 dmesg.txt -rw-r--r-- 1 root root 37713 Apr 8 14:34 dmesg.txt1 -rw-r--r-- 1 root root 38222 Apr 8 14:54 dmesg.txt2 [root@tinkerboard ~]# modinfo rk_crypto filename: /lib/modules/4.4.120-beleza-10-rockchip/kernel/drivers/crypto/rockchip/rk_crypto.ko license: GPL description: Support for Rockchip's cryptographic engine author: Zain Wang <zain.wang@rock-chips.com> alias: of:N*T*Crockchip,rk3288-crypto* depends: intree: Y vermagic: 4.4.120-beleza-10-rockchip SMP mod_unload ARMv7 p2v8 [root@tinkerboard 4.4.120-beleza-10-rockchip]# modprobe rk_crypto [root@tinkerboard 4.4.120-beleza-10-rockchip]# [root@tinkerboard /]# cat /proc/crypto > build10-after [root@tinkerboard /]# lsmod Module Size Used by rk_crypto 24576 0 uas 20480 0 [root@tinkerboard ~]# ll total 11000 -rw-r--r-- 1 root root 7502 Apr 9 03:00 build9 -rw-r--r-- 1 root root 7502 Apr 9 04:04 build10-after <==== HERE -rw-r--r-- 1 root root 7502 Apr 9 04:03 build10-pre -rw-r--r-- 1 root root 28207 Apr 7 20:10 dmesg.txt -rw-r--r-- 1 root root 37713 Apr 8 14:34 dmesg.txt1 -rw-r--r-- 1 root root 38222 Apr 8 14:54 dmesg.txt2 Well, pretty much the same ¯\_(ツ)_/¯ And no sign of HWRNG too: [root@tinkerboard ~]# strace -fxvvt -e trace=file rngd [...] 04:21:36 open("/dev/hwrng", O_RDONLY|O_LARGEFILE) = 3 [...] 04:21:36 read(3, 0xbeb555ec, 4) = -1 ENODEV (No such device) 04:21:36 write(2, "error reading from entropy sourc"..., 50error reading from entropy source:: No such device) = 50 04:21:36 write(2, "\n", 1 ) = 1 04:21:36 exit_group(1) = ? 04:21:36 +++ exited with 1 +++ /dev/hwrng is there because it does exist in kconfig. oh well. FYI. UPDATE: I have asked Rockchip in https://github.com/rockchip-linux/u-boot/issues/21 . Edited April 9, 2018 by Rfreire Added Rockchip Question issue Link to comment Share on other sites More sharing options...
Rfreire Posted April 9, 2018 Share Posted April 9, 2018 Some more test results here while in the Uber on my way to work. I wrote the Developer, let's see what comes up. I have built a kernel backporting your 3288 Crypto acceleartor (using a TinkerBoard) and I'm puzzled about how do I take advantage of the Crypto Engine. I have done some OpenSSL tests and both shows no deviation from both with and without the module. See: ===> TESTING WITH THE ENGINE [root@tinkerboard cron.d]# modprobe rk_crypto [root@tinkerboard cron.d]# openssl speed aes-256-cbc Doing aes-256 cbc for 3s on 16 size blocks: 7134953 aes-256 cbc's in 2.99s Doing aes-256 cbc for 3s on 64 size blocks: 2990888 aes-256 cbc's in 3.00s Doing aes-256 cbc for 3s on 256 size blocks: 778812 aes-256 cbc's in 3.00s Doing aes-256 cbc for 3s on 1024 size blocks: 195865 aes-256 cbc's in 3.00s Doing aes-256 cbc for 3s on 8192 size blocks: 24452 aes-256 cbc's in 3.00s OpenSSL 1.0.1t 3 May 2016 built on: Thu Mar 29 12:42:31 2018 options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr) compiler: gcc -I. -I.. -I../include -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-z,relro -Wa,--noexecstack -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DGHASH_ASM The 'numbers' are in 1000s of bytes per second processed. type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes aes-256 cbc 38180.35k 63805.61k 66458.62k 66855.25k 66770.26k ===> REMOVING THE ENGINE [root@tinkerboard cron.d]# modprobe -r rk_crypto [root@tinkerboard cron.d]# [root@tinkerboard cron.d]# [root@tinkerboard cron.d]# openssl speed aes-256-cbc Doing aes-256 cbc for 3s on 16 size blocks: 7014728 aes-256 cbc's in 2.98s Doing aes-256 cbc for 3s on 64 size blocks: 2975590 aes-256 cbc's in 3.00s Doing aes-256 cbc for 3s on 256 size blocks: 773596 aes-256 cbc's in 3.00s Doing aes-256 cbc for 3s on 1024 size blocks: 195292 aes-256 cbc's in 3.00s Doing aes-256 cbc for 3s on 8192 size blocks: 24386 aes-256 cbc's in 2.99s OpenSSL 1.0.1t 3 May 2016 built on: Thu Mar 29 12:42:31 2018 options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr) compiler: gcc -I. -I.. -I../include -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-z,relro -Wa,--noexecstack -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DGHASH_ASM The 'numbers' are in 1000s of bytes per second processed. type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes aes-256 cbc 37662.97k 63479.25k 66013.53k 66659.67k 66812.75k ===> NOW TRYING A DIFFERENT OPENSSL TEST. STILL WITHOUT ENGINE [root@tinkerboard cron.d]# [root@tinkerboard cron.d]# [root@tinkerboard cron.d]# openssl speed -evp aes-256-cbc Doing aes-256-cbc for 3s on 16 size blocks: 6525393 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 64 size blocks: 2932580 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 256 size blocks: 770173 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 1024 size blocks: 195867 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 8192 size blocks: 24496 aes-256-cbc's in 3.00s OpenSSL 1.0.1t 3 May 2016 built on: Thu Mar 29 12:42:31 2018 options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr) compiler: gcc -I. -I.. -I../include -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-z,relro -Wa,--noexecstack -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DGHASH_ASM The 'numbers' are in 1000s of bytes per second processed. type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes aes-256-cbc 34802.10k 62561.71k 65721.43k 66855.94k 66890.41k [root@tinkerboard cron.d]# [root@tinkerboard cron.d]# [root@tinkerboard cron.d]# ===> RE-INSERTING THE ENGINE [root@tinkerboard cron.d]# [root@tinkerboard cron.d]# modprobe rk_crypto [root@tinkerboard cron.d]# [root@tinkerboard cron.d]# openssl speed -evp aes-256-cbc Doing aes-256-cbc for 3s on 16 size blocks: 6918935 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 64 size blocks: 2939849 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 256 size blocks: 771348 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 1024 size blocks: 195315 aes-256-cbc's in 3.00s Doing aes-256-cbc for 3s on 8192 size blocks: 24436 aes-256-cbc's in 3.00s OpenSSL 1.0.1t 3 May 2016 built on: Thu Mar 29 12:42:31 2018 options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr) compiler: gcc -I. -I.. -I../include -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-z,relro -Wa,--noexecstack -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DGHASH_ASM The 'numbers' are in 1000s of bytes per second processed. type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes aes-256-cbc 36900.99k 62716.78k 65821.70k 66667.52k 66726.57k ===> The test results are pretty much in line with both with and without the module. Module information: [root@tinkerboard cron.d]# modinfo rk_crypto filename: /lib/modules/4.4.120-beleza-10-rockchip/kernel/drivers/crypto/rockchip/rk_crypto.ko license: GPL description: Support for Rockchip's cryptographic engine author: Zain Wang <zain.wang@rock-chips.com> alias: of:N*T*Crockchip,rk3288-crypto* depends: intree: Y vermagic: 4.4.120-beleza-10-rockchip SMP mod_unload ARMv7 p2v8 Link to comment Share on other sites More sharing options...
BeauSlim Posted April 14, 2018 Author Share Posted April 14, 2018 OpenSSL is user-space, so you need to use AF_ALG (or Cryptodev but that's kind of old-school) to bridge to kernel-space and access the rk_crypto driver. I looked at this (referring to some Marvell pogo-plug era documentation) but never bothered to sort out all the pieces needed. My application was a VPN, and I went the easy way and used IPSec, which lives in kernel-space. A good kernel module, StrongSwan, and the related NetworkManager plugin and you *should* be good to go. But, like I mentioned in my post above: with no module loaded, traffic flows fine. With the module loaded, I got no traffic and usually had a whole-board lockup. AFAIK, many of the v8 chips out now support ARM crypto acceleration so there's little point in mucking with something proprietary except out of curiosity. 1 Link to comment Share on other sites More sharing options...
Rfreire Posted April 14, 2018 Share Posted April 14, 2018 Hi Beau!! Thanks for clarifying! I appreciate your post. I have just migrated my rpi stuffs into the Tinkerboard and I happen to have a ipsec tunnel between home and a US endpoint. I have the rk_crypto module active and the ipsec tunnel is doing just fine.. Go figure :-) Link to comment Share on other sites More sharing options...
