Root by UUID leftovers and using armbianEnv.txt for more targets
If I checked the configuration correctly, only Cubox, S500 and Udoo* don't have HAVE_UUID_SUPPORT=yes set, but AFAIK all boot scripts now load the initrd.
@Igor can you add and test root by UUID on those boards?
Also boot scripts for more boards could use /boot/ambianEnv.txt, I already tested it on XU4 and will try to test it on C2, will anybody be able to test it on C1 or C0 (it has much older u-boot)?
If I remember correctly there were some problems either on Cubox or Udoo, but hopefully it can work on most of the left over configurations.
