Ahmet Emin Koçal Posted September 16, 2017 Share Posted September 16, 2017 (edited) Hello, my opi+2 sometimes dies after long running times and becomes so hot that I cannot touch it. When I looked to logs, I saw kernel panic errors like, you know, tons of meanless numbers. I can provide any information you want. It's been few hours since I started it but here are logs. http://sprunge.us/jJSK Probably it had had 0.05 15 min load before it died. I couldn't see the message I saw before, probably they got removed from the system after few minutes. I'll send you newer logs after I get accurate errors again. This may take a week, or few days. Edited September 16, 2017 by Ahmet Emin Koçal Added logs, Status update Link to comment Share on other sites More sharing options...
chwe Posted September 16, 2017 Share Posted September 16, 2017 1 hour ago, Ahmet Emin Koçal said: my opi+2 sometimes dies after long running times and becomes so hot that i cannot touch it means idling without any tasks or with hard load on the system? To quote Igor: Quote We are not clairvoyant or mind readers Please describe your setup as best as possible so we know what your operating environment is like. 1. Logs, when you can boot the board: armbianmonitor -u (paste URL to your forum post) 2. If your board does not boot, provide a log from serial console or at least make and attach a picture, where it stops. 3. Describe the problem the best you can and provide all necessary info that we can reproduce the problem. Link to comment Share on other sites More sharing options...
Ahmet Emin Koçal Posted September 16, 2017 Author Share Posted September 16, 2017 58 minutes ago, chwe said: means idling without any tasks or with hard load on the system? To quote Igor: It was in idle status. Link to comment Share on other sites More sharing options...
