Ucino Posted October 5, 2017 Share Posted October 5, 2017 Hello, I'm trying to have the onboard bluetooth working with OrangePi PC+ (to evaluate OPPC+ to deploy it in school with open source OS and software cf. https://forum.armbian.com/index.php?/topic/4929-which-card-choose-to-deploy-an-educational-open-source-os-in-schools/&tab=comments#comment-40408 ). I'm using the ubuntu desktop legacy version that we can download on https://www.armbian.com/orange-pi-pc-plus/ Here is the result of armbianmonitor -u : http://sprunge.us/WeEO If I'm running bluetooth in command line I have this problem : La connexion à BlueZ a échoué (The connexion to BlueZ failed) Le démon Bluez n'est pas actif, blueman-manager ne peut pas continuer. (The BlueZ demon is not active, blueman-manager cannot follow). Cela signifie probablement qu'aucun adaptateur Bluetooth n'a été détecté ou que le démon Bluetooth n'a pas été démarré. (This probably mean that there is no bluetooth adapter or bluetooth demon has not started - sorry for my bad translation ) And in the terminal we have : blueman-manager ** (blueman-manager:4637): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files _________ Load (/usr/lib/python3/dist-packages/blueman/main/PluginManager.py:60) ['PulseAudioProfile', 'Services'] _________ __load_plugin (/usr/lib/python3/dist-packages/blueman/main/PluginManager.py:133) loading <class 'blueman.plugins.manager.Services.Services'> _________ __load_plugin (/usr/lib/python3/dist-packages/blueman/main/PluginManager.py:133) loading <class 'blueman.plugins.manager.PulseAudioProfile.PulseAudioProfile'> _________ pa_context_event (/usr/lib/python3/dist-packages/blueman/main/PulseAudioUtils.py:341) 1 blueman-manager version 2.0.4 starting _________ pa_context_event (/usr/lib/python3/dist-packages/blueman/main/PulseAudioUtils.py:341) 2 _________ on_bluez_name_owner_changed (/usr/bin/blueman-manager:96) org.bluez owner changed to _________ pa_context_event (/usr/lib/python3/dist-packages/blueman/main/PulseAudioUtils.py:341) 3 _________ pa_context_event (/usr/lib/python3/dist-packages/blueman/main/PulseAudioUtils.py:341) 4 _________ on_pa_ready (/usr/lib/python3/dist-packages/blueman/plugins/manager/PulseAudioProfile.py:29) connected _________ <lambda> (/usr/lib/python3/dist-packages/blueman/main/PulseAudioUtils.py:353) Reading this french webpage about bluetooth problem on debian http://debian-facile.org/doc:systeme:bluetooth I tried this command lines : service bluetooth status ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at jeu. 2017-10-05 23:46:26 CEST; 13min ago ConditionPathIsDirectory=/sys/class/bluetooth was not met Docs: man:bluetoothd(8) and sudo service bluetooth start and after an other time : service bluetooth status ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at ven. 2017-10-06 00:01:17 CEST; 5s ago ConditionPathIsDirectory=/sys/class/bluetooth was not met Docs: man:bluetoothd(8) So it seems that the demon BlueZ doesn"t want to start, no ? Is there anybody that have an idea on how to start BlueZ or how can I have the bluetooh working on Orange PiPC with legacy ? Please note that I have made an upgrade after installing armbian ubuntu desktop, I don't know if this can explain this. Thanks for your reply Link to comment Share on other sites More sharing options...
Igor Posted October 6, 2017 Share Posted October 6, 2017 What if you switch to beta repository, conduct an update and try to connect to BT device withing armbian-config (under networking)? What kind of BT dongle do you have? I'll check later if things are broken on our side. Link to comment Share on other sites More sharing options...
Igor Posted October 6, 2017 Share Posted October 6, 2017 I can confirm that it doesn't work for me either. I have to check where is the problem - on our side or upstream. It used to work fine and image from download section should also work fine. Link to comment Share on other sites More sharing options...
tkaiser Posted October 6, 2017 Share Posted October 6, 2017 11 hours ago, Ucino said: onboard bluetooth working with OrangePi PC+ There is no such thing and according to lsusb you also don't use an USB BT dongle. 1 Link to comment Share on other sites More sharing options...
Ucino Posted October 6, 2017 Author Share Posted October 6, 2017 3 hours ago, Igor said: What if you switch to beta repository, conduct an update and try to connect to BT device withing armbian-config (under networking)? Thanks for your reply. Is it to do this : run armbian-config > Switch (and not nightly) > Switching to linux-image-dev-sun8i ? or this ? : run armbian-config > Nightly 3 hours ago, Igor said: What kind of BT dongle do you have? This is the on board OPPC+, I'm not using an USB dongle. Rooooo; ok i was searching what was the on board bluetooth, there isn't ! I'm so sorry !!! Do you recommend if it's exist, an open hardware Bluetooth Dongle that run nice with armbian ? If there isn't open hardware dongle bluetooth, what non open hardware is recommended ? Thanks, and I'm sorry and confused for this error :/ Link to comment Share on other sites More sharing options...
Ucino Posted October 6, 2017 Author Share Posted October 6, 2017 5 minutes ago, Ucino said: Bluetooth Dongle that run nice with armbian ? If there isn't open hardware dongle bluetooth, what non open hardware is recommended ? Thanks, and I'm sorry and confused for this error :/ Ok there is thread about this : https://forum.armbian.com/index.php?/topic/2983-usb-bluetooth-dongle-for-orange-pi-lite-zero/ and https://forum.armbian.com/index.php?/topic/3455-which-bt-dongle-for-orangepi-lite/ tkaiser and Igor thanks for your replies, the problem is solved Link to comment Share on other sites More sharing options...
Igor Posted October 6, 2017 Share Posted October 6, 2017 6 minutes ago, Ucino said: an open hardware Bluetooth Dongle that run nice with armbian ? Open hardware won't exists since Bluetooth is a closed protocol. Check download page. On the bottom, there are links to tested equipment. 1 Link to comment Share on other sites More sharing options...
Ucino Posted October 6, 2017 Author Share Posted October 6, 2017 Just now, Igor said: Open hardware won't exists since Bluetooth is a closed protocol. Check download page. On the bottom, there are links to tested equipment. Ok, thanks a lot. Link to comment Share on other sites More sharing options...
Igor Posted October 6, 2017 Share Posted October 6, 2017 I just made self-build image with those fixes https://github.com/armbian/build/commit/ad3e331cef5374941c6317412470d5e145607d73 and Bluetooth is up and ready by default with such dongle. Opi PC+ legacy Ubuntu desktop http://sprunge.us/aJAc 1 Link to comment Share on other sites More sharing options...
Ucino Posted October 6, 2017 Author Share Posted October 6, 2017 2 hours ago, Igor said: I just made self-build image with those fixes https://github.com/armbian/build/commit/ad3e331cef5374941c6317412470d5e145607d73 and Bluetooth is up and ready by default with such dongle. Opi PC+ legacy Ubuntu desktop http://sprunge.us/aJAc Perfect, thanks a lot Link to comment Share on other sites More sharing options...
