  2. NicoD
    Daily (tech related) news diet
    Belgian journalist and German scientists? I ain't trusting that for a bit. They don't emmit co2. But there's co2 released making them. Just like there's co2 released making any other car. It also takes 1 barrel oil to produce 3 barrels(if we're lucky(tar sand is 2 for 3)) The article is bs. At least the title is. It tries to confirm some people's idea they're not doing anything wrong wasting oil. Acting on their confirmation bias... And that's what 95% of the internet has become. Truth isn't important, that doesn't sell(produce click)
  3. OMG I cant believe I didnt post this. https://github.com/berinc/Asus-Tinker-Board
  4. Linuxcnc is working fine, the only tasks left, are getting the I/O setup in linuxcnc. I do not have a mesa board and I'm prefer to use the GPIO mainly. would love any help from anyone that can. The only other issue that needs to be worked out is the Native resolution of the lcd I'm using is not working in armbian, 1024x600. My finish goal is to PUBLISH a working SD/EMMC image to the world. so people with a tinkerboard have a DROP IN cnc controller just add the boot/distro image and setup your connections for your machine as needed.
  5. Yesterday
  6. seawolfssn
    Helios4 Support
    @gprovost To be clear, once i disconnected the external USB drives and plugged them into my PC and saw them power up and run just fine i decided to power down the whole helios4 and disassemble it to get ready for new drives. Then i just tried to plug one 2 of the 3.5" SATA drives in to see what would happen when i put power back on and nothing spun up. Then i tried a single drive alone, once in each of the 4 power connectors after powering down and up each time. no spinning up. Then I tried a brand new WD Blue drive, and then a brand new WD Red drive and nothing powered up on any single attempt. If i took a random 2.5" drive and plugged it in to the SATA connections, then it worked no problem. and was detected by the OS. So that's what led me to think that there's a problem getting enough power supplied to the 3.5" drives now and from that it can't power USB drives with anything connected either, hence the total system went down and stays down. Each time just to be clear, i completely powered down the device and then powered up with a different slot or drive connected and only the 2.5 connected by SATA worked
  7. TonyMac32
    http://brusselstimes.com/business/technology/15050/electric-vehicles-emit-more-co2-than-diesel-ones,-german-study-shows Sent from my Pixel using Tapatalk
  8. data
    H6 Famous Reboot problem
    Ok, I connected a TTL cable to the serial port but besides the line I get nothing else. Do I need a fresh install of the nightly version? Because I've just did 'apk upgrade'... Or is there a way I can keep my existing setup?
  9. chwe
    [RockPro64] Armbian upstream kernel/uboot test?
    going through the links spotted something for @martinayotte (and maybe @TonyMac32) https://github.com/archlinuxarm/PKGBUILDs/pull/1691/commits/dfe2881b2eaf32a5b2289005c675888345684fd7#diff-2347b909a334e35e45d31e5bb4961a3f there's a a patchset for upstream u-boot for the ram part.. as OP says it's not running stable.. but at least they got upstream u-boot up.. maybe worth a look as well.. to clean the rk u-boot mess asap.
  10. koakh
    X96 MAX (S905X2) with Armbian-ubuntu
    Photos has requested... About eMMC backup and restore, it works using nand-sata-install, but armbian never boots.... I post a lots of related info about boot problems, and partition problems above....please scroll up, and view one image that shows the Crash on boot, related with bad partition (added to. This post) Ir we try to mount the restored Partition, ir inspect it, we sure check that we can mount it root@aml:~# sudo mount /dev/mmcblk1p2 /mnt/mmcblk1p2 mount: /mnt/mmcblk1p2: can't read superblock Thanks for your support @balbes150
  11. data
    Not yet. Will try it and let you know what I see...
  12. martinayotte
    Strange ... The fix done in ATF was commit more than a week ago. Did you check with a USB-TTL Serial Debug dongle what is happening during a "reboot" ?
  13. data
    Dear Martin, thank you for your reply. I am on ARMBIAN 5.82.190422 nightly Ubuntu 18.04.2 LTS 5.0.7-sunxi64 But reboot does not work. Am I supposed to do anything else besides upgrading to the latest nightly? Thank you in advance!
  14. Hello guys, I configured bridge via nmcli/nmtui br0. Slave devices of bridge are eth0 and wlan0(as wifi access point). OS: Armbian_5.59_Orangepizero_Ubuntu_xenial_default_3.4.113 root@orion2:~# nmcli c s NAME UUID TYPE DEVICE bridge-br0 fff57bce-6051-458d-9394-7101741af59f bridge br0 bridge-slave-eth0 25720542-2bdd-498e-992e-4415385673d5 802-3-ethernet eth0 bridge-slave-wlan0 ed8b07bf-a793-4717-8c99-2e84d54af672 802-11-wireless wlan0 Configuration looks fine, but when I try login to AP, my smart phone shows error message: "Authentication issue" , and on side of server: orion2 wpa_supplicant[1017]: WPA: wpa_sm_step() called recursively Device is trying to offload WPS Probe Response while not supporting this Configuration of AP: root@orion2:~# nmcli c s bridge-slave-wlan0 connection.id: bridge-slave-wlan0 connection.uuid: ed8b07bf-a793-4717-8c99-2e84d54af672 connection.interface-name: wlan0 connection.type: 802-11-wireless connection.autoconnect: yes connection.autoconnect-priority: 0 connection.timestamp: 1555962464 connection.read-only: no connection.permissions: connection.zone: -- connection.master: fff57bce-6051-458d-9394-7101741af59f connection.slave-type: bridge connection.autoconnect-slaves: -1 (default) connection.secondaries: connection.gateway-ping-timeout: 0 connection.metered: unknown connection.lldp: -1 (default) 802-11-wireless.ssid: Orion2 802-11-wireless.mode: ap 802-11-wireless.band: bg 802-11-wireless.channel: 7 802-11-wireless.bssid: -- 802-11-wireless.rate: 0 802-11-wireless.tx-power: 0 802-11-wireless.mac-address: -- 802-11-wireless.cloned-mac-address: -- 802-11-wireless.mac-address-blacklist: 802-11-wireless.mac-address-randomization:default 802-11-wireless.mtu: auto 802-11-wireless.seen-bssids: DC:44:6D:F6:92:CB 802-11-wireless.hidden: no 802-11-wireless.powersave: default (0) 802-11-wireless-security.key-mgmt: wpa-psk 802-11-wireless-security.wep-tx-keyidx: 0 802-11-wireless-security.auth-alg: -- 802-11-wireless-security.proto: 802-11-wireless-security.pairwise: 802-11-wireless-security.group: 802-11-wireless-security.leap-username: -- 802-11-wireless-security.wep-key0: <hidden> 802-11-wireless-security.wep-key1: <hidden> 802-11-wireless-security.wep-key2: <hidden> 802-11-wireless-security.wep-key3: <hidden> 802-11-wireless-security.wep-key-flags: 0 (none) 802-11-wireless-security.wep-key-type: 0 (unknown) 802-11-wireless-security.psk: <hidden> 802-11-wireless-security.psk-flags: 0 (none) 802-11-wireless-security.leap-password: <hidden> 802-11-wireless-security.leap-password-flags:0 (none) bridge-port.priority: 32 bridge-port.path-cost: 100 bridge-port.hairpin-mode: no GENERAL.NAME: bridge-slave-wlan0 GENERAL.UUID: ed8b07bf-a793-4717-8c99-2e84d54af672 GENERAL.DEVICES: wlan0 GENERAL.STATE: activated GENERAL.DEFAULT: no GENERAL.DEFAULT6: no GENERAL.VPN: no GENERAL.ZONE: -- GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/ActiveConnection/2 GENERAL.CON-PATH: /org/freedesktop/NetworkManager/Settings/2 GENERAL.SPEC-OBJECT: /org/freedesktop/NetworkManager/AccessPoint/1 GENERAL.MASTER-PATH: /org/freedesktop/NetworkManager/Devices/3 Could you please help me with solving wpa_supplicant issue? Thank you, Marek
  15. At last, I have found something that works, and produces images. In short, use ubuntu_lxde_desktop_OrangePipc_v0_9_1.img . Long story is here: http://www.orangepi.org/orangepibbsen/forum.php?mod=viewthread&amp;tid=4270&amp;page=1&amp;extra=#pid25253 Edit: I also suceeded with image Armbian_5.75_Orangepione_Ubuntu_xenial_default_3.4.113_desktop.7z
  16. balbes150
    Armbian for Amlogic S9xxx kernel 4.1x (>= ver 5.55)
    Kernel N2 for Armbian is the result of joint work BayLibre and developer community Libreelec (we work together closely). It takes time for everything to look finished. Only then will the publication.
  17. balbes150
    Show photos of your model and SATA connector. I just checked image 20190412 on my X96Max (S905X2) 4\32. eMMC without problems visible, works utility DDBR (allows you to create and restore full backup eMMc) and installation works Armbian in eMMC.
  18. martinayotte
    uart interface Gpio 8 + 10 on the rock pi4
    Good catch ! ... I'm often suffer of dyslexia ...
  19. martinayotte
    GPIO Hat not detected over the IIC interface SCL, SDA
    The I2C present on Header pins 3 and 5 is the I2C7. To get I2C7 appearing as /dev/i2c-7, it requires to load the rockchip-i2c7.dtbo overlay which is present in /boot/dtb/rockchip/overlay. To do that, add the "overlays=i2c-7" into the /boot/armbianEnv.txt and reboot.
  20. NicoD
    Great job. Any idea when you'll release? I'm gathering information for a review video about the N2. Ubuntu Mate has too many problems to advice to use for productivity use. Meveric's Stretch is better but swap/zram also ain't working. With that working in your Armbian I think Armbian is the best image for productivity with the N2.
  21. koakh
    Yes it seem that is a USB <> sata bridge Its what I try to find, a way to use it on armbian, it works on android Thanks @balbes150
  22. balbes150
    Sound through HDMI and the rest is there , but it is WIP and not yet for public use.
  23. SecureXperts
    Hi pavelectric The /dev/i2c-2 is not available on my Image. Do in need to load some Kernel modules for that? Thanks
  24. pavelectric
    So check on the other bus ... root@rockpi:~# i2cdetect -y 2
  25. SecureXperts
    The file is /boot/armbianEnv.txt and not in the /etc ;-)
  26. I have the following hat http://wiki.seeedstudio.com/Raspberry_Pi_Relay_Board_v1.0 my image detects the i2c interfaces and mounts them in /dev as i2c-0 i2c-1 i2c-3 i2c-4, I can scan the different i2c interfaces as folloging interface i2cdetect -y 1 root@rockpi:~# i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: UU 11 -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- I have set 0x20 address on my relay Board but cannot see the interface. Has anyone a hint what configuration settings i need to change Many Thanks Roman
  27. NicoD
    It's great to have another option. Only problems I found was no on-board audio(usb audio adapter worked) and no cpu control. Otherwise it's solid. I'll keep an eye open on the progress. I red with kernel 5.2 cpu control will be enabled. Then it's perfect for me. I've put a lot of time into trying to get zram/swap to work with the Odroid kernel without any luck. With yours it works, so I know this will be ok in the future with Armbian. Thanks.
