  2. Igor
    NanoPC T4
    One is certain. You don't need any partitions since all boot stages are happening outside - at fixed positions. You only need a partition if you plan to boot Linux (from it). I am not sure if the type matters ... you will need to dig deep into docs, if and where available.
  3. martinayotte
    Orangepi 3 h6 allwiner chip
    They are there : https://dl.armbian.com/orangepi3/
  4. thexman
    SSH doesn't work on Orange Pi Zero
    @Mabrafs Fixed with latest kernel please read posts in this thread for more information
  5. https://github.com/friendlyarm/linux/blob/sunxi-4.14.y/arch/arm/boot/dts/sun8i-h3-nanopi.dtsi#L518-L523 It's also software problem.
  6. Today
  7. The USB OTG is not working - the microUSB connector data lines are not connected to the SoC (based on schematic rev1704) so Ethernet-over-USB will never work !!!
  8. The client require TCP access to this board via USB - I think they want to get debug info and remote syslog via this port. Sorry I am not the SE on this system so that is beyond my scope of worries.
  9. maddinthebrain
    Hi all, as the image for the Orange Pi 3 seems to be developing, when will be there a beta to try? Or a image that works redumantary? thx Martin
  10. I was able to fix the Ethernet-over-USB problem with the help of another (recent) post. I found the DTS file (after adding some oil on the rusty parts) for the my board @ "./cache/sources/linux-mainline/orange-pi-4.19/arch/arm64/boot/dts/allwinner/sun50i-h5-nanopi-neo-plus2.dts". After changing the USB setting to "otg", I created a patch file and added it to the build/patch/kernel/sunxi-{dev,next} directories. This great build system automatically applied it and I now see a usb0 interface after loading the g_ether module. I've attached my patch file which should work for any v4.19 kernel. So now only the Wifi issue remain board-nanopineoplus2-enable-otg.patch
  11. Merblud
    NanoPC T4
    As a result it is necessary to create the mbr partition? And why then the loader tries to look for the gpt partition? For example: GPT 0x3190d20 signature is wrong LoadTrust Addr:0x4000 Or nobody just knows what occurs in a blob from Rockchip?
  12. 13 Pins Header, with 2x USB, IR pin, AUDIO(MIC, AV)
  13. The client has a device with only a USB port which must be able to connect to this board
  14. Hi LJB, If you need 2 x NIC and WiFi, why didn't go for: http://www.orangepi.org/OrangePiR1/ ?
  15. langerma
    Ethernet not working on SOPINE module
    is it possible to just upgrade my image by apt upgrade? (defreeze kernel pkgs beforehand)
  16. balbes150
    Armbian for TV box rk3328
    https://forum.freaktab.com/forum/main-category/main-forum/770129-rk3588-8k-arm-cortex-a76-a55-soc-rockchip-roadmap-to-2020
  17. Hi, I just got a NanoPi Neo Plus2 for which I must prepare an image for our software. Basically I must have a working Ethernet-over-USB, Wifi and NIC. I started with your current Debian image compiled with uses Armbian v8.75 and Linux kernel v4.19.20. In this image Wifi works, but loading the g_ether module does not seem to work. I assume I need to patch the kernel to make this happen, which means I need to build my own images. So I created a Virtualbox environment as described in the documentation, and compiled an image with all the defaults (apart from a date-tag I add to the kernel name for identification). I installed the image to the eMMC and booted. In this image there is no wifi interface and g_ether also does not work. The armbianmonitor output for my new image is attached to this query (http://ix.io/1H9v), but I also created an armbianmonitor output for your Debian image (http://ix.io/1H9u) in which the Wifi interface does appear. Wifi: Comparing the dmesg output, it is obvious that firmware fails to load into the AP6212 wifi unit on my image. I've downloaded and installed firmware from several sites (official and other) to try and fix, but nothing solves the problem. Any ideas? Is this a regression in the Linux kernel (4.19.20 -> 4.19.36)? OTG: Configuration of the USB-OTG for the Ethernet-over-USB gadget is usually done in the DTS files on ARM processors (I think - a bit rusted). I've noticed that there are several patches applied to the kernel from other boards such as the OrangePi, so maybe someone already has a patch for another H5 based board which will work for the NanoPiNeo+2? Regards, LJB
  18. gus.tech
    ESPRESSObin v7 - Official BIONIC does not boot. HELP
    I have the same issue. Bought my v7 from Amazon. Like your board, my board says its 1000cpu and 800ram. I tried flashing it with the *correct* firmware flash-image-ddr4-1g-1cs-1000_800.bin and got the same kernel panic issues. I then flashed it with flash-image-ddr4-1g-1cs-600_600.bin and it works fine. Problem is, it only runs at 300mhz per core. I'm returning my v7 to Amazon. I'll stick to my v5 until the bugs get ironed out. Oh well.
  19. pkfox
    More SATA questions
    I know what you mean ( many hats and titles ) I've been programming computers since 1971 and I'm still getting paid to do so - some of my previous titles are shown below Programmer Systems Analyst Analyst Programmer Project Manager Lead Programmer Software Engineer l could go on - all those different titles for essentially the same job BTW I have the Pi with 4 Ssd drives working beautifuly
  20. I tried to build Mesa with enabled lima and kmsro drivers, seems like this work mostly ffine: https://launchpad.net/~russianneuromancer/+archive/ubuntu/drivers (for Ubuntu 19.04 only, due to Mesa 19.0 dependencies). However, attempts to interact with lima via X11 always result in "libEGL warning: DRI2: failed to authenticate". https://paste.fedoraproject.org/paste/vmKQVPcEURxlcvqkqLDiTw https://paste.fedoraproject.org/paste/2VbdPxubtS9a-9E~hzZbIA ...and attempts to run glmark2-es2-wayland under Weston reveal that it running on llvmpipe. Testing on NanoPC-M! with current dev kernel: ~$ dmesg | grep lima [ 9.943493] lima 1c40000.gpu: bus rate = 200000000 [ 9.943506] lima 1c40000.gpu: mod rate = 384000000 [ 9.950490] lima 1c40000.gpu: gp - mali400 version major 1 minor 1 [ 9.950539] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1 [ 9.950581] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1 [ 9.950629] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus [ 9.960591] [drm] Initialized lima 1.0.0 20170325 for 1c40000.gpu on minor 1 (full log) I wonder if anyone was able to install Lima from Mesa upstream with current Armbian dev kernel and replicate at least this results?
  21. Igor
    NanoPC T4
    Technical documentation is sometimes abridged, weird or even wrong. For booting you only need one partition with a non-standard off set before. 16K instead of 1K.
  22. Recommended for AP operations: Realtek 8811AU, 8812AU, RT3572, RT5572. mt7610u is yet another cheap key/driver which just got Linux support. But it's in very infant/alfa state. It works, but AP mode comes last to fix, if. We have no resources to fix any of broken drivers since each driver represents a serious operation which we can't possibly afford.
  23. amirul
    Iridium browser aka chromium without google
    https://chat.osb-alliance.de Got in the iridium devs chat room. I'll ask very nicely for an armbian port
  24. Yesterday
  25. Thanks for your message. It is always your help. I have the kernel version 4.19.33 and I tried to operate this device mt7601U, an rtl8192e and another mt7610u TP-LINK Archer T1U that I have. Unsuccessfully. Which device can make the connection easier or would another be recommended? Thanks.
  26. Wireguard is broken on sources that are in repository, while if you use self made, it works. A rebuild of all packages should be done. The question is - is it safe enough?
  27. Here we can see both u-boot and kernel can see the USB drive (pendrive log) scanning usb for storage devices... 1 Storage Device(s) found ... [ 6.517256] usb-storage 1-1:1.0: USB Mass Storage device detected ... [ 8.005130] sda: sda1 The kernel starts USB initialization at [ 5.731114] ehci-platform 1c14000.usb: EHCI Host Controller Absence of this init in the failed case could (imho) be caused by incorrect/damaged device tree. Device tree is loaded to memory by u-boot (and seems patched after this). I'm not familiar with u-boot in details, perhaps it uses the same device tree and this explains why it does not see storage device too. Although, this could be less important because u-boot seems load both kernel and device tree from SD (if I understand this boot process correctly). So the next step would be checking the device tree and presence of device at 1c14000.
