The only way is to do the assembly yourself. First, it is necessary to check the correctness of applying patches to the kernel and u-boot.
@dhlii I wish good health to the developer of embedded Linux. It will be very interesting for me to talk to you. I have a question. Do you use specialized build systems such as buildroot in your work? The first thing to do is add the target DTS to the u-boot. You can take this as a basis: u-boot> find ./arch/arm/dts/ -name '*nanopi-r1*' ./arch/arm/dts/sun8i-h3-nanopi-r1.dts ./arch/arm/dts/sun50i-h5-nanopi-r1s-h5.dts linux-stable> find ./arch/arm/boot/dts/ -name '*nanopi*' ./arch/arm/boot/dts/allwinner/sun8i-h3-nanopi-duo2.dts ./arch/arm/boot/dts/allwinner/sun8i-h3-nanopi-m1-plus.dts ./arch/arm/boot/dts/allwinner/sun8i-h3-nanopi-m1.dts ./arch/arm/boot/dts/allwinner/sun8i-h3-nanopi-neo-air.dts ./arch/arm/boot/dts/allwinner/sun8i-h3-nanopi-neo.dts ./arch/arm/boot/dts/allwinner/sun8i-h3-nanopi-r1.dts ./arch/arm/boot/dts/allwinner/sun8i-h3-nanopi.dtsi This DTS must match the wiring of the pins of the printed circuit board and match the brands of soldered chips. The second good step is if you add the default u-boot configuration file. This will allow you to repeat the loader assembly by changing only the dts You can take this as a basis: u-boot> find ./configs/ -name '*h3*' u-boot> find ./configs/ -name '*nanopi*' Special attention is paid to the CONFIG_DRAM_CLK parameter. Even on identical boards but from different series, different memory chips can be soldered. After u-boot has done its job and it loads the dtb of the kernel and the kernel itself, we will be able to dynamically change the dtb using overlays. I.e., the DTB in u-boot is hard-coded, the DTB for the kernel we can change dynamically.
Looks like the CE (China Export NOT the EU CE) have "re branding" one RK to some HUW chop that was likely in one phone copy running one RK chip and (or more likely tablet).
Two same boards but different cpu. Rockchip labeled works fine with armbian, multitool and libreelec. The board with huawei labeled cpu has the previously described problem, multitool and armbian stop working after a minute. Method of switching bootloaders suggested by @jock works.
@fortdevv you're welcome and thanks for reporting 👍
@IronIgel there's also a small paragraph in the first page about special hardware with a link to a guide on how to fix the issue.
Description armsom-sige7: enable gpu rock-5a: enable gpu, fix poweroff, enable pcie2x1 for M.2 E slot hinlink-h88k: enable gpu How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] ./compile.sh kernel BOARD=armsom-sige7 BRANCH=edge DEB_COMPRESS=xz [x] Tested with armsom-sige7, rock-5a and hinlink-h88k Checklist: Please delete options that are not relevant. [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
Yes, that will work unless there is some special weirdness in the R1S-H3 that needs custom drivers...which I doubt for now
Armbian-Base-Files doesn't build for bullseye
j0ta replied to j0ta's topic in Software, Applications, Userspace
Ok it builds now for bullseye it seems it will be available on 24.5 Thanks all ! Cheers -
It appears that the nanopi-r1 image is working. I am an embdded linux developer. I am not expert in Armbian building. But I have built kernels from scratch, written drivers, and created complete linux installs from scratch - i.e. manually done what the Armbian build script does automatically. But I am not looking to do a huge amount of work to get a bunch of embedded linux systems up to use for other purposes. I have a very large collection of SBC's - probably half can run linux. I like Armbian, and it is pretty uptodate - though frankly I am just using these as network conneced devices to manage other systems I am developing on. Regardless they are laying arround collecting dust, they do not require much power and I do not need lots of horsepower. The bad news is that I am an embdded linux developer - so I have one or two of lots of different boards - not 10 BBB's. My 2nd question was if I choose a similar H3 device to the nanopi-r1s-h3 and I either find a nonopi-r1s-h3 device tree or I modify an H3 device tree to match the nanopi-r1s-h3 hardware and then substite that device tree in a different H3 image - that should work ? Though the question appears to be moot and the nanopi-r1 image appears to work for me.
Hello, I'm new to this forum. I would like to know which recent version of ARMBIAN I can install on my X96 Max+ TV box (2GB ram and 16GB version). I've tried to install several recent 24.5 versions but it won't start. Here is the link to the versions I tried to install(Armbian_community_24.5.0-trunk.250_Aml-s9xx-box) I simply renamed the file corresponding to my S905X3.............. box to u-boot.ext https://github.com/armbian/community/releases/tag/24.5.0-trunk.250 The only version I managed to install is Armbian_20.10_Arm-64_focal_current_5.9.0_desktop. So I'd like to know which version is best suited to my box. The CPU in the box is an Amlogic S905X3 only, I followed a procedure that made me use an S905X2 with Armbian_20.10_Arm-64_focal_current_5.9.0_desktop. Here is the link https://www.youtube.com/watch?v=nETXagKHYGI Is it possible to have your help if possible by telling me the procedure for a perfect installation. Thank you in advance.
I noticed this thread, I had the same issue. And found the solution here: Pine A64-LTS not booting and [RESOLVED] PineA64LTS doesn't want to boot. Seems that in my dtb-file there was something missing what caused the root not being found or mounted??, the option: non-removable; meson-sm1-a95xf3-air.dtb has it also missing on mmc@ffe05000 from what I think is your root, the option: non-removable; Hope it helps It solved my UUID not found problem.
See steps 18-23 in the (outdated) guide
Hello! Thank you jock for fixing the problems! I am just updated, and it's really working now. Thanks!
Changes upstream rarely match exactly what is happening this far downstream. So let's take control by moving the old and patching a new. This gives us more freedom to make edits when we want or need to and avoid errors. View the full article
Yes. However there are various SoC manufacturs for arm64 SoCs like Allwinner, Rockchip, Amlogic and so on and they require custom patching for often both uboot and kernel. So while saying the device tree is indeed the biggest difference it does not boil down to just that.
Would I be correct in assuming that the biggest difference between images for the same architecture would be the device tree ?
Description The issue When using ./compile.sh rewrite-kernel-config and then running the menuconfig with ./compile.sh kernel-config, just exiting and saving without any manual changes, the kernel config may still change. This is because rewrite-kernel-config does force some kernel options without any additional checks e.g. for dependencies. Using the config menu with kernel-config does those checks automatically and solves all dependencies. Example: Using ./compile.sh kernel-config on linux-rockchip64-edge.config (e.g. with BOARD=nanopi-r5c), the option CONFIG_DEBUG_KERNEL=y is automatically selected, since it is a dependency for CONFIG_EXPERT=y, which is selected in this kernel config as well. But then, ./compile.sh rewrite-kernel-config forces CONFIG_DEBUG_KERNEL to disabled. However, this breaks the dependency for CONFIG_EXPERT=y, which is still enabled. In consequence, CONFIG_DEBUG_KERNEL will be set to =y next time anyone runs ./compile.sh kernel-config on this config. The goal Doing a kernel-config (with no manual changes, just start and exit with saving) or a rewrite-kernel-config should lead to the exact same config file. It should be consistent. The solution This PR tries to solve this in the following way: Save the config right after the forced configs were applied Do an oldconfig after forced configs were applied to have kernel make solve any issues (will add ~3 seconds on each rewrite-kernel-config) Let the user see what was changed by kernel make so changes can be made accordingly Changes in forced kernel options by armbian-kernel.sh Set DEBUG_INFO_NONE=y instead of DEBUG_INFO=n since the latter is not configurable Remove GDB_SCRIPTS=n since DEBUG_INFO_NONE=y already implies this Example output in build log (for rk3588-legacy kernel): [🚸] Forced kernel options introduced misconfigurations or missing dependencies! [ Please re-run rewrite-kernel-config ] [🚸] If this warning persists [ please remove dependent options using kernel-config or adapt your custom_kernel_config hooks ] [🐛] In some cases, the issue might also be [ misconfigured options in armbian_kernel_config hooks ] [🔨] -DEBUG_INFO_NONE y [🔨] -MODULE_COMPRESS_NONE y [🔨] DEBUG_KERNEL n -> y [🔨] EXPERT n -> y [🚸] See options above which have been changed automatically [ to solve dependencies and/or misconfigurations ] As you can see, some of the forced kernel options did not have the expected results since kernel make had to change these to solve dependencies and make the config sane. Warning: This will output lots of changes on the first time it runs. Re-run it, the second run will output only the relevant changes. Some kernel configs will have to be adapted to solve the issues which are output in the warnings (like above), or armbian-kernel.sh might have to be adapted a bit linux-rockchip64-edge.config is an example, I just ran rewrite-kernel-config on this and kernel make did its magic. Overall, this should lead to more sane kernel configs. How Has This Been Tested? [x] rewrite-kernel-config for nanopi-r5c-edge [ ] Other kernels should be tested as well Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings View the full article
[PINE64 A64] Kernel panics with headless boot
daniele95100 replied to daniele95100's topic in Pine A64
Any help on this one? I still can't figure out what's happening here. -
Hello, I have been trying to switch to kernel 6.8 but images are not working properly. Screen does not show anything at all. 6.1 images can boot so users can proceed with installation. Failure has been observed for some time starting with earlier 6.8-rc versions. Has anyone tried any 6.6 build?
@moddien Hello! Yes, a serial adapter would indeed provide some debug info that can be useful. I don't remember such "r3229q-221p" board, so perhaps it is a new board. Be sure to use the latest multitool first. User @svdmk had a similar problem, you can check the latest two pages of this thread for some reference. At the moment the solution is a bit of a hack and involves switching bootloaders, which is not the easier thing to do.
OPI5+ nvme not found [jammy_legacy_5.10.160 16Gb RAM]
ozacas replied to Barmaleykin's topic in Orange Pi 5 Plus
Maybe sudo armbianmonitor -u might help shed some light about what is going on - perhaps there is an issue with the device or driver? But no problems for me with the arm64 uefi image on my opi5+ 16GB - acas@opi:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS zram0 252:0 0 7.7G 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk nvme0n1 259:0 0 1.8T 0 disk ├─nvme0n1p1 259:1 0 259M 0 part /boot/efi └─nvme0n1p2 259:2 0 1.8T 0 part /var/log.hdd / -
ok I can confirm it works better . just typed "sudo dd if=rkspi_loader.img of=/dev/mtdblock0 conv=notrunc sync " waited about five minutes and rebooted. After 5 reboots it has always go on .. so probably it is better. Ah my os is armbian jammy 22 , I used file from ubuntu rockchip 23, nvme lexar I wonder if works on all version , and how it differs. but it is rather low level buissnes.
Unfortunately opi5 is not near me and can't make any test right now. I'll try to find what's wrong with usbc on 6.8 when i find a chance to try.
- 15 replies
- Orange Pi 5
- Orange Pi 5B
(and 1 more)
Tagged with:
