Igor
Administrators
Everything posted by Igor
  1. Nightly versions are released virtually every day. https://forum.armbian.com/topic/2422-more-proper-testing-better-armbian-experience/?tab=comments#comment-17455 You can use armbian-config -> system -> Nightly
  2. In case automatic way is not working ... you need to proceed manual way (https://www.google.com/search?q=access+point+debian) or try updating to beta/nightly repository, update and do it again. Perhaps this problem is already fixed in the development version ...
  3. Branch "development" is fixed. It should work now: https://github.com/armbian/build/commit/cd4f7d2423b84b3cf3ddf6e6bdc0344f3200a5d7
  4. A few more fixes: - Clearfog SFP and eMMC support on 4.14.y - FriendlyARM S5P6818 based boards 2G memory support and back to latest 4.14.y - fix broken 8822bs-patch for z28pro - Odroid C2 next updated patches
  5. This should fix this problem. https://github.com/armbian/config/commit/d7b283e7b8af0c64189f47d0765a790767b44e99
  6. I am trying to use this approach but no luck. It looks like my Gitfu is not ready for proper advance Git manipulation. I only know dirty ways atm. Perhaps it is better than you do this merge since for me all looks safe - "one big pull request" Merge everything, except those Bionic hacks to the master and focus to make master as stable as possible and start with a new development(s) fork(s)? Not necessarily today but after a few more test builds.
  7. Igor
    New forum UI!!
    I don't use this function ... was this working properly before this update?
  8. Today's nightly or build from development branch: - packages cleanup and reorganize: removed Libre writer and Thunderbird from the default desktop install. This brings CLI < 1G and desktop < 2G. - many bugfixes, enhancements and new software added to armbian-config https://github.com/armbian/config/blob/development/README.md - fixed FriendlyARM M3 kernel - wireless for Z28PRO - removed HDD temperature from MOTD - many upstream changes for Espressobin kernel(s) - Odroid DT blob switching was added to the armbian-config. This speeds up boot process and lower consumption on HC1/HC2 - docker building improved ... more changes will be found at the merge Tomorrow website launch ... then: - merging patches to the stable - testing - testing - fixing - testing - testing - fixing
  9. Exactly as written in the documentation but this chip is ... just read known issues section at Orange Pi Zero download page.
  10. Igor
    New forum UI!!
    Another bug. Wrong picture when posting a forum link to the facebook. Now we have random(?) avatar with the link: Before:
  11. Igor
    New forum UI!!
    I haven't read posts here and install anything yet since I do try to get some rest on weekends ... It has been a busy week and upcoming looks even more. Fixing cosmetic issues on a forum has low priority and can wait for a while. In any case, I will seek help from theme designer since I don't want to spend precious weekends solving this.
  12. Igor
    New forum UI!!
    I liked yours Wrote on mobile
  13. Igor
    New forum UI!!
    Fixed, re-enabled but need to be properly configured.
  14. Igor
    New forum UI!!
    It looks like a theme issue, let's collect more and report here: https://invisioncommunity.com/forums/topic/439176-haze-42x-by-ips-themes/?page=2 Right.
  15. Igor
    New forum UI!!
    Removed since its broken.
  16. Igor
    New forum UI!!
    If you find one dark that works perfectly well. I can add it and adjust. I'll see how can I force change for all users.
  17. Igor
    New forum UI!!
    Tapatalk plugin still works. Wrote on mobile
  18. Igor
    New forum UI!!
    https://invisioncommunity.com/news/product-updates/invision-community-43-r1055 I hope more bugs were fixed than added. Edit: well I already found a new one in the first post Pasted URL has not changed to URL automatically at posting but at editing.
  19. It should work on both ... well, it looks like a bug in config script. There is still a manual way by studying this data: https://www.armbian.com/kernel
  20. https://github.com/MarvellEmbeddedProcessors/linux-marvell/issues or better notify @kostap https://github.com/kostapr
  21. You are already on beta ... run update, reboot and you should see "Switch" "Switch to alternative kernels" there. Edit: I just tested switching and it works fine, logs: http://ix.io/19ob | ____|___ _ __ _ __ ___ ___ ___ ___ | |__ (_)_ __ | _| / __| '_ \| '__/ _ \/ __/ __|/ _ \| '_ \| | '_ \ | |___\__ \ |_) | | | __/\__ \__ \ (_) | |_) | | | | | |_____|___/ .__/|_| \___||___/___/\___/|_.__/|_|_| |_| |_| Welcome to ARMBIAN 5.43.180428 nightly Ubuntu 18.04 LTS 4.16.5-mvebu64 System load: 0.18 0.30 0.13 Up time: 3 min Memory usage: 6 % of 993MB IP: 172.16.100.189 Usage of /: 8% of 15G [ 0 security updates available, 1 updates total: apt upgrade ] Last check: 2018-05-04 08:36 Last login: Fri May 4 08:36:52 2018 from 172.16.100.175
  22. Sorry. "Nightly" "Switch to nightly automated builds" is a proper term.
