Posts
96 -
Joined
Last visited
Content Type
Forums
Store
Crowdfunding
Applications
Events
Raffles
Community Map
Posts posted by lxde-OSIREN
I have no access to network line atm, I want to send someone an android with the server app in it to keep it plugged in and connected to your wifi and screen off, just you have to forward a router port, I offer $10/month or you decide, and ill let you limit its bandwidth with a setting, and after were done you can keep the android.
looking for 2 different armbian users from 2 different locations to host.
I currently have: 0 of 2 hosts
same commands I usually use, except mostly for installs if the package doesn't exist I use :
apt-get install appname.deb -f
yes that should work if what your button does is wake it up, the ebay link just leave the chip in the usb port for the power on and the other digital pin soldered to the orange pi button with 1 wire.
it can be done by programming this small microcontroller to send the button pin a voltage periodically: https://www.ebay.com/itm/10Pcs-Digispark-Kickstarter-ATTINY85-Arduino-General-Micro-USB-Development-Board/293002153078?ssPageName=STRK%3AMEBIDX%3AIT&var=591803336110&_trksid=p2057872.m2749.l2649
but that would be a last option for some if the wakeup can be done all programmatically in a shell script and you don't need to buy anything, but I don't write that much shell script so if it were me id send it the voltage with the usb sized chip above.
its autologin no pw, its a desktop img, the other command line ones are probably faster boot for ssh but you can always use default:
user: root
pw: orangepi
keep my custom orange pi zero h2 18sec boot to desktop img, all popup error windows/crash windows disabled, did you solve your sleep issue yet?:
Try the apk on your Linux/android to see if your hardware supports Bluetooth: http://www.skyizo.com/Bluetooth_Support.apk
that is the cortex-a really is that like a specific cpu or all cortex's? the teensy is using the cortex-m4, but lets call it the noob tube because sounds like m4-carbine
aim high with the cortex-m4 carbine found in teensy 3.6
alright am looking at rtos
Bluetooth sounds good, but really why cant we use armbian instantly as a microcontroller or the process seems much less spoken about than doing it on a teensy 3.2/3.6, for example I can have instant access to Bluetooth hc-05 wired to teensy 3.2 on power on but armbian takes boot time to access that.
A good way to prevent downtime for some circumstances is to use NAS as the storage for multiple servers. For my set up its good because one server can go down and users can just join the other server with the same data, only bad when you need to do maintenance on the hard drive.
If one delicate android server freezes up from multiple users using to much cpu function it still shows the server as online until I fix it, but users will see selecting another server works fine. xP
let me know the boot times for lichee pi desktop img.
different speed testers show different results, I'm using fiber.
New results after switching network cards, I think I can still get a better network card and see the 1gbps: https://www.speedtest.net/result/8312143962
that's good, I setup up custom watercooling for poweredge 1950 harpertown cpu and I had setup an app to check lm-sensors from android, would always be 49 degrees, so the server never made noise again but sometimes it would get pretty hot and shutdown, even blew off the water on the mobo and the end. Specific core temperatures would be even better for htop.
apt-get install lm-sensors
shows core temperatures, but the new htop shows temperatures now?
ok, thx
still posting those 3d good job nicoD mind if I share some progress of my 3d engine as well?, easy port to armbian browser btw:
Basically it is going to be a head band with a gyroscope to move around on the game.
I do that too and it helped, I lost some of my old scripts and I remembered my thread, btw boot time for rk?
Nico why don't you upload an hd download of it
what kind of headers you talking
hello pazzoide still shows enough to help, why don't you try to change your htop version.
Hello software side of armbian, today I am releasing the source code for a mini instagram clone that you can publish and finish the rest for your orange pi 2g,3g,4g iot as an app/ios source code in video description, and enjoy the video:
Who can host for me $$get paid$$
in Off-topic
That answer net work for me because our server can only be hosted on windows or android. Not digitalocean/linode machines. Any one want to earn $$$ ? reply to main post
