Posts
5 -
Joined
Last visited
Content Type
Forums
Store
Crowdfunding
Applications
Events
Raffles
Community Map
Posts posted by Gabor Csuri
15 hours ago, balbes150 said:
You need to take the latest image version 20181207. install the package ffmpeg_4.0.4 (from the same directory on the website where the images are). Need to check (choose correct options) run ffplay for video playback decoders "*_v4l2m2m".
Hi, where is that website?
On 11/3/2018 at 10:57 AM, jock said:
Try to run fdisk /dev/mmcblk0 and then issue the command p to take a look to the real partitions on the device
Hi jock,
thank you for your answer! I realized that partitions defined in the factory dtb. I'm using the mainline dtb so I had to define with the blkdevparts. Now I can access factory partitions with mainline kernel...
best regards, Gabor
Hi,
ok, I had to half the frequency in the device-tree. mmcblk1 mmcblkboot0, mmcblkboot1, mmcblkgp0 and mmcblkrpmb have appeared.
How can I access the system,logo,env ...etc partitions ?
In earlier kernel logs (4.12) I found:
[ 3.369031] mmcblk0: emmc:0001 AWPD3R 14.6 GiB [ 3.377416] mmcblk0boot0: emmc:0001 AWPD3R partition 1 4.00 MiB [ 3.383431] mmcblk0boot1: emmc:0001 AWPD3R partition 2 4.00 MiB [ 3.385447] mmcblk0rpmb: emmc:0001 AWPD3R partition 3 4.00 MiB [ 3.392229] Enter aml_emmc_partition_ops [ 3.395735] [mmc_read_partition_tbl] mmc read partition OK! [ 3.400990] add_emmc_partition [ 3.404385] [mmcblk0p01] bootloader offset 0x000000000000, size 0x000000400000 [ 3.412716] [mmcblk0p02] reserved offset 0x000002400000, size 0x000004000000 [ 3.421077] [mmcblk0p03] cache offset 0x000006c00000, size 0x000020000000 [ 3.429441] [mmcblk0p04] env offset 0x000027400000, size 0x000000800000 [ 3.437806] [mmcblk0p05] logo offset 0x000028400000, size 0x000002000000 [ 3.446176] [mmcblk0p06] recovery offset 0x00002ac00000, size 0x000002000000 [ 3.454532] [mmcblk0p07] rsv offset 0x00002d400000, size 0x000000800000 [ 3.462900] [mmcblk0p08] tee offset 0x00002e400000, size 0x000000800000 [ 3.471284] [mmcblk0p09] crypt offset 0x00002f400000, size 0x000002000000 [ 3.479641] [mmcblk0p10] misc offset 0x000031c00000, size 0x000002000000 [ 3.488001] [mmcblk0p11] instaboot offset 0x000034400000, size 0x000020000000 [ 3.496370] [mmcblk0p12] boot offset 0x000054c00000, size 0x000002000000 [ 3.504732] [mmcblk0p13] system offset 0x000057400000, size 0x000040000000 [ 3.513100] [mmcblk0p14] data offset 0x000097c00000, size 0x00030c200000 [ 3.521334] amlmmc_dtb_init: register dtb chardev [ 3.526130] amlmmc_dtb_init: register dtb chardev OK [ 3.531101] Exit aml_emmc_partition_ops OK.
Is it removed from the latest kernels?
best regards, Gabor
Hi,
I've just tried mainline kernel 4.19 with my two TV boxes and first impression is wow! it works! It's faster than expected! Thanks!
With Magicsee N5 I can't access the internal eMMC. I use factory bootloder, meson-gxl-s905x-p212 dtb, released 4.19 kernel.
I got:
root@lepotato:~# dmesg|grep mmc [ 0.000000] Kernel command line: console=ttyAML0,115200 root=/dev/mmcblk0p2 [ 0.979648] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2 [ 0.985812] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1 [ 0.992676] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1 [ 0.999184] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2 [ 1.005962] meson-gx-mmc d0072000.mmc: Linked as a consumer to regulator.2 [ 1.012580] meson-gx-mmc d0072000.mmc: Linked as a consumer to regulator.1 [ 1.019383] meson-gx-mmc d0072000.mmc: Got CD GPIO [ 1.050790] meson-gx-mmc d0074000.mmc: Linked as a consumer to regulator.4 [ 1.052173] meson-gx-mmc d0074000.mmc: Linked as a consumer to regulator.1 [ 1.058938] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq [ 1.100626] mmc0: new high speed SDHC card at address 0001 [ 1.107836] mmcblk0: mmc0:0001 SD8GB 7.28 GiB [ 1.122762] mmcblk0: p1 p2 [ 1.694717] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2 [ 1.700530] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1 [ 1.707411] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1 [ 1.713888] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2 [ 1.737590] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2 [ 1.738912] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1 [ 1.745766] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1 [ 1.752240] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2 [ 1.759846] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2 [ 1.765629] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1 [ 1.772497] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1 [ 1.778990] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2 [ 1.833559] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: (null) [ 2.193186] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2 [ 2.198747] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1 [ 2.205782] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1 [ 2.212138] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2 [ 2.627095] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2 [ 2.629932] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1 [ 2.636841] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.1 [ 2.643348] meson-gx-mmc d0070000.mmc: Dropping the link to regulator.2 [ 4.942703] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro [ 5.641638] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.2 [ 5.641745] meson-gx-mmc d0070000.mmc: Linked as a consumer to regulator.1 [ 5.641821] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq [ 5.697460] mmc2: queuing unknown CIS tuple 0x01 (3 bytes) [ 5.708349] mmc2: queuing unknown CIS tuple 0x1a (5 bytes) [ 5.713097] mmc2: queuing unknown CIS tuple 0x1b (8 bytes) [ 5.714044] mmc2: queuing unknown CIS tuple 0x14 (0 bytes) [ 5.716514] mmc2: queuing unknown CIS tuple 0x80 (1 bytes) [ 5.716561] mmc2: queuing unknown CIS tuple 0x81 (1 bytes) [ 5.716607] mmc2: queuing unknown CIS tuple 0x82 (1 bytes) [ 5.716638] mmc2: new high speed SDIO card at address 0001 [ 242.654386] Workqueue: events_freezable mmc_rescan [ 242.654487] mmc_wait_for_req_done+0x44/0x160 [ 242.654497] mmc_wait_for_req+0x98/0xd4 [ 242.654505] mmc_send_tuning+0x11c/0x1b8 [ 242.654521] meson_mmc_execute_tuning+0x6c/0x20c [ 242.654531] mmc_execute_tuning+0x48/0xbc [ 242.654543] mmc_init_card+0x9f0/0x19c4 [ 242.654554] mmc_attach_mmc+0xac/0x170 [ 242.654564] mmc_rescan+0x394/0x3cc
SDcard is recognized and works but internal one is didn't. How I can access the internal eMMC? Why I got mmc_rescan hints periodically ?
My second box is Beelink MiniMX. GBit phy is initialized but there is no link ... - I use the standard meson-gxbb-p201.dtb. I need to change something in the device-tree?
bets regards, Gabor
Armbian for Amlogic S9xxx kernel 5.x
in General Chat
Hi,
s905x2 is not supported very well yet in the mainline kernel. Use image based on the 3.14 kernel.
