Joel Müller
  1. Hi! I have a Espressobin V7 and would make a router with this tutorial https://blog.tjll.net/building-my-perfect-router/ Dnsmasq is nativ with ArchLinux ARM That is dnsmasq.conf of the floder /etc # Listen for requests on this interface interface=br0 # Address range to draw from dhcp-range=192.168.1.5,192.168.1.250,255.255.255.0,24h # Default route for clients (the address we used in /etc/systemd/network/br0.network) dhcp-option=option:router,192.168.1.1 cat /etc/systemd/network/ br0.netdev [NetDev] Name=br0 Kind=bridge br0.network [Match] Name=br0 [Network] Address=192.168.1.1/24 IPForward=ipv4 #IPMasquerade=yes not activ while I need 1 Gbit/s between wan and br0 ConfigureWithoutCarrier=yes eth0.network [Match] Name=eth0 lan.network [Match] Name=lan* [Network] Bridge=br0 BindCarrier=eth0 wan.network [Match] Name=wan [Network] DHCP=yes DNSSEC=no BindCarrier=eth0 IPForward=ipv4 Error when i start dnsmasq with systemctl start dnsmasq May 13 00:49:46 alarm systemd-resolved[344]: Using degraded feature set (UDP) f> May 13 00:49:50 alarm systemd-resolved[344]: Using degraded feature set (UDP) f> lines 2046-2068/2068 (END)[ 1302.028960] audit: type=1130 audit(1557699855.230:359): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' [ 1302.048344] audit: type=1131 audit(1557699855.230:360): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' [ 1302.105771] audit: type=1130 audit(1557699855.310:361): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed' ifconfig [root@alarm ~]# ifconfig br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.1 netmask 255.255.255.0 broadcast 192.168.1.255 inet6 2a02:120b:c3f6:f671:50ea:a8ff:fe06:b6a prefixlen 64 scopeid 0x0<global> inet6 fe80::50ea:a8ff:fe06:b6a prefixlen 64 scopeid 0x20<link> ether 52:ea:a8:06:0b:6a txqueuelen 1000 (Ethernet) RX packets 722 bytes 408503 (398.9 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 562 bytes 70734 (69.0 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1508 inet6 fe80::f2ad:4eff:fe09:6a7f prefixlen 64 scopeid 0x20<link> ether f0:ad:4e:09:6a:7f txqueuelen 1024 (Ethernet) RX packets 722 bytes 424387 (414.4 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 582 bytes 76891 (75.0 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 11 lan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether f0:ad:4e:09:6a:7f txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 lan1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 ether f0:ad:4e:09:6a:7f txqueuelen 1000 (Ethernet) RX packets 722 bytes 408503 (398.9 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 562 bytes 70734 (69.0 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 80 bytes 6320 (6.1 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 80 bytes 6320 (6.1 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wan: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether f0:ad:4e:09:6a:7f txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 What is wrong ? And have also no Internet I pluged a FritzBox 5490 with DHCP v6 and v4 to the Wan Port Shorewall is not running
