ROCKPiLER
  1. Yes I did, and now I think it has nothing to do with the SSD. I installed the latest Armbian image from today. Apparently my Rockpi is trying to load files from my Fritzbox via TFTP. I canceled the serial console and restarted via reset, and now the rockpi starts again without problems. Armbian 20.11.6 Focal ttyS2 rockpi-4a login: [ 36.932811] watchdog: watchdog0: watchdog did not stop! [ 37.227029] reboot: Restarting system U-Boot TPL 2020.10-armbian (Jan 05 2021 - 03:54:57) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2020.10-armbian (Jan 05 2021 - 03:54:57 +0100) Trying to boot from SPI NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: If lpddr4 need support multi frequency, INFO: please update loader! INFO: Current ctl index[0] freq=400MHz INFO: Current ctl index[1] freq=800MHz INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Jan 05 2021 - 03:54:57 +0100) SoC: Rockchip rk3399 Reset cause: RST Model: Radxa ROCK Pi 4B DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPIFlash... SF: Detected XT25F32B with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Radxa ROCK Pi 4B Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! Card did not respond to voltage select! PCIe link training gen1 timeout! Device 0: unknown device starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device failed to find ep-gpios property ethernet@fe300000 Waiting for PHY auto negotiation to complete........ done Speed: 1000, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.1.11 (4 ms) *** Warning: no boot file name; using 'C0A8010B.img' Using ethernet@fe300000 device TFTP from server 192.168.1.1; our IP address is 192.168.1.11 Filename 'C0A8010B.img'. Load address: 0x800800 Loading: *T T T T T T T T T T Retry count exceeded; starting again missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-5e-35-1a-eb-5a-8d Speed: 1000, full duplex Using ethernet@fe300000 device TFTP from server 192.168.1.1; our IP address is 192.168.1.11 Filename 'pxelinux.cfg/01-5e-35-1a-eb-5a-8d'. Load address: 0x600000 Loading: *T T T T T T T T T T Retry count exceeded; starting again missing environment variable: bootfile Retrieving file: pxelinux.cfg/C0A8010B Speed: 1000, full duplex Using ethernet@fe300000 device TFTP from server 192.168.1.1; our IP address is 192.168.1.11 Filename 'pxelinux.cfg/C0A8010B'. Load address: 0x600000 Loading: *T T T T T T T Another reboot hangs on the kernel loading: Last login: Mon Jan 25 23:33:11168.1.105 on pts/0 rock@rockpi-4a:~$ reboot rock@rockpi-4a:~$ [ 148.654202] watchdog: watchdog0: watchdog did not stop! [ 148.932579] reboot: Restarting system U-Boot TPL 2020.10-armbian (Jan 05 2021 - 03:54:57) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2020.10-armbian (Jan 05 2021 - 03:54:57 +0100) Trying to boot from SPI NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: If lpddr4 need support multi frequency, INFO: please update loader! INFO: Current ctl index[0] freq=400MHz INFO: Current ctl index[1] freq=800MHz INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Jan 05 2021 - 03:54:57 +0100) SoC: Rockchip rk3399 Reset cause: RST Model: Radxa ROCK Pi 4B DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPIFlash... SF: Detected XT25F32B with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Radxa ROCK Pi 4B Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! Card did not respond to voltage select! Device 0: Vendor: 0x15b7 Rev: 211070WD Prod: 20427P462511 Type: Hard Disk Capacity: 953869.7 MB = 931.5 GB (1953525168 x 512) ... is now current device Scanning nvme 0:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 2 ms (1.5 MiB/s) ## Executing script at 00500000 Boot script loaded from nvme 0 261 bytes read in 2 ms (127 KiB/s) 15790152 bytes read in 37 ms (407 MiB/s) 27507200 bytes read in 55 ms (477 MiB/s) 74439 bytes read in 3 ms (23.7 MiB/s) 267 bytes read in 2 ms (129.9 KiB/s) Applying kernel provided DT overlay rockchip-pcie-gen2.dtbo 1314 bytes read in 2 ms (641.6 KiB/s) Applying kernel provided DT overlay rockchip-spi-jedec-nor.dtbo 2698 bytes read in 2 ms (1.3 MiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Moving Image from 0x2080000 to 0x2200000, end=3cd0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15790088 Bytes = 15.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f100d000, end f1f1c008 ... OK Loading Device Tree to 00000000f0f92000, end 00000000f100cfff ... OK Starting kernel ...
  2. The WDS100T2B0C doesn't seem to work so well after all. Sometimes the reboot hangs and the system only restarts after a power reset.
  3. And another one. WD Blue SN550 NVMe SSD 1TB (WDS100T2B0C) Working like a charm...
  4. Awesome, I have been waiting for this possibility for so long. I can confirm that it also runs with an HP SSD EX900 M.2 NVMe 120GB. Model: 2YY42AA#ABB Armbian 20.11.3 Focal with Linux 5.9.14-rockchip64 Rock Pi 4A v1.4 Thank you @piter75
