koftikes
1 Follower
  1. Can you provide full hardware config of your device? I mean board version, additional adapters, eMMC, power supply etc ...
  2. Yes almost In your solution mess in rk3399-rock-pi-4.dtsi still exist, and I think it's not good for system stable work. Also I try different variants with/without vpcie0v9-supply, vpcie1v8-supply but I got different errors or not soft reboot with this two parameters... So yes, we were digging in the right direction )))
  3. It wasn't easy, but it wasn't that difficult considering my minimum level .... First of all. After analyzing the sources https://github.com/torvalds/linux/blob/v5.10/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4.dtsi https://github.com/torvalds/linux/blob/v5.15/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4.dtsi https://github.com/torvalds/linux/blob/v6.1/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4.dtsi it became clear that the source code already has the part of changes: &pcie0 { ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; num-lanes = <4>; pinctrl-0 = <&pcie_clkreqnb_cpm>; pinctrl-names = "default"; vpcie0v9-supply = <&vcc_0v9>; vpcie1v8-supply = <&vcc_1v8>; vpcie3v3-supply = <&vcc3v3_pcie>; status = "okay"; }; &pcie_phy { status = "okay"; }; BUT board-rockpi4-0003-arm64-dts-pcie.patch --- creates a mess: &pcie0 { ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; num-lanes = <4>; max-link-speed = <1>; pinctrl-names = "default"; pinctrl-0 = <&pcie_clkreqnb_cpm>; vpcie12v-supply = <&vcc12v_dcin>; vpcie3v3-supply = <&vcc3v3_pcie>; status = "okay"; }; &pcie_phy { status = "okay"; }; &pmu_io_domains { status = "okay"; pmu1830-supply = <&vcc_3v0>; }; &pcie_phy { status = "okay"; }; &pcie0 { ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; num-lanes = <4>; pinctrl-0 = <&pcie_clkreqnb_cpm>; pinctrl-names = "default"; vpcie0v9-supply = <&vcc_0v9>; vpcie1v8-supply = <&vcc_1v8>; vpcie3v3-supply = <&vcc3v3_pcie>; status = "okay"; }; An attempt to simply disable the patch provided a negative result. Then I compared the source and the old patch and highlighted the following changes in a separate patch. Also based on the sources I added bus-scan-delay-ms = <1000>; https://gitlab.manjaro.org/manjaro-arm/packages/core/linux/-/issues/10 https://www.spinics.net/lists/linux-pci/msg103349.html https://www.spinics.net/lists/linux-pci/msg103351.html diff --git a/Documentation/devicetree/bindings/pci/rockchip-pcie-host.txt b/Documentation/devicetree/bindings/pci/rockchip-pcie-host.txt index af34c6577..1829b442c 100644 --- a/Documentation/devicetree/bindings/pci/rockchip-pcie-host.txt +++ b/Documentation/devicetree/bindings/pci/rockchip-pcie-host.txt @@ -57,6 +57,8 @@ Optional Property: using 24MHz OSC for RC's PHY. - ep-gpios: contain the entry for pre-reset GPIO - num-lanes: number of lanes to use +- bus-scan-delay-ms: delay before PCIe bus scan in milliseconds. + Provides a workaround for some devices causing a crash in bus scan. - vpcie12v-supply: The phandle to the 12v regulator to use for PCIe. - vpcie3v3-supply: The phandle to the 3.3v regulator to use for PCIe. - vpcie1v8-supply: The phandle to the 1.8v regulator to use for PCIe. diff --git a/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4.dtsi b/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4.dtsi index 1f5101dac..c67528e23 100644 --- a/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4.dtsi +++ b/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4.dtsi @@ -80,6 +80,8 @@ vcc3v3_pcie: vcc3v3-pcie-regulator { regulator-name = "vcc3v3_pcie"; regulator-always-on; regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; vin-supply = <&vcc5v0_sys>; }; @@ -525,11 +527,12 @@ &pcie_phy { &pcie0 { ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; num-lanes = <4>; + max-link-speed = <1>; pinctrl-0 = <&pcie_clkreqnb_cpm>; pinctrl-names = "default"; - vpcie0v9-supply = <&vcc_0v9>; - vpcie1v8-supply = <&vcc_1v8>; + vpcie12v-supply = <&vcc12v_dcin>; vpcie3v3-supply = <&vcc3v3_pcie>; + bus-scan-delay-ms = <1000>; status = "okay"; }; AND now it's working booting from uSD; working "boot from eMMC system on eMMC"; working soft reboot too root@rockpi-4b:~# uname -a Linux rockpi-4b 5.15.85-rockchip64 #trunk SMP PREEMPT Mon Dec 26 15:48:30 +03 2022 aarch64 GNU/Linux root@rockpi-4b:~# fdisk -l Disk /dev/nvme0n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors Disk model: NE-1TB Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk1: 57.62 GiB, 61865984000 bytes, 120832000 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x425824f4 Device Boot Start End Sectors Size Id Type /dev/mmcblk1p1 32768 119603199 119570432 57G 83 Linux Disk /dev/zram0: 1.89 GiB, 2025594880 bytes, 494530 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/zram1: 50 MiB, 52428800 bytes, 12800 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes root@rockpi-4b:~# dd if=/dev/nvme0n1 of=/dev/null bs=1M count=2048 iflag=direct status=progress 1118830592 bytes (1.1 GB, 1.0 GiB) copied, 1 s, 1.1 GB/s 2048+0 records in 2048+0 records out 2147483648 bytes (2.1 GB, 2.0 GiB) copied, 1.88694 s, 1.1 GB/s Armbian_22.11.2-trunk_Rockpi-4b_bullseye_5.15.85.log This is console log cool boot + soft reboot from uSD
  4. @desperex Hello, actually I fixed issue. I need additional testing for provide a path to armbian branch
  5. Sorry my falls I do a bad erase for EMMC and I think a boot loader will taken from this, so I fix this and add a new console log. See: Armbian_22.11.0_bullseye_5.15.80_linux.log Behavior is sometimes strange (((( In most cases, booting and rebooting goes fine. But a couple of times I caught errors during verbose boot and linux reboot. See: Armbian_22.11.0_bullseye_5.15.80_linux-reboot.log Armbian_22.11.0_bullseye_5.15.80_linux_verbose-error.log Armbian_22.11.0_bullseye_5.15.80_linux_verbose-error-2.log Also as you ask I provide normal verbose loading log: Armbian_22.11.0_bullseye_5.15.80_linux_verbose.log BUT one thing is stable, every time when I try start 5.15.80-rockchip64 it's fail... See: Armbian_22.11.0_bullseye_5.15.80_5.15.80-rockchip64.log So this is my trying... and again thank you for help!
  6. So I do erase my SPI, EMMc and NVMe devices, create new uSD and try again. And your build work from uSD !!!! See: console logs It's amazing and thank you for your investigations and help. as I understand this issue because some patches not include [ 3.841967] systemd[233]: /usr/lib/systemd/system-generators/netplan failed with exit status 1. [ OK ] Found device /dev/ttyS2. [ OK ] Started Show Plymouth Boot Screen. [ OK ] Started Forward Password R…s to Plymouth Directory Watch. [ OK ] Reached target Local Encrypted Volumes. [ OK ] Reached target Paths. [ OK ] Finished Raise network interfaces. [ 14.748907] rockchip-pinctrl pinctrl: pin gpio3-29 already requested by leds; cannot claim for ff880000.i2s [ 14.749798] rockchip-pinctrl pinctrl: pin-125 (ff880000.i2s) status -22 [ 14.750402] rockchip-pinctrl pinctrl: could not request pin 125 (gpio3-29) from group i2s0-8ch-bus-bclk-off on device rockchip-pinctrl [ 14.751486] rockchip-i2s ff880000.i2s: Error applying setting, reverse things back [ 14.752163] rockchip-i2s ff880000.i2s: bclk disable failed -22 [ 14.844258] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch. Again thank you for help, what I can/should do next ? How I as noob can propose fixing for Armbiam Armbian_22.11.0_bullseye_5.15.80_test.log
  7. Sorry for that I will clean emmc and nvme and try again from clean install.
  8. Some additional testing: I try different images and some of them work for example - 1. Armbian_21.08.1_Rockpi-4b_bullseye_5.10.60 and Armbian_21.08.2_Rockpi-4b_bullseye_5.10.63 - works if kernel not updated see Armbian_21.08.1_Rockpi-4b_bullseye_5.10.60.log and Armbian_21.08.2_Rockpi-4b_bullseye_5.10.63.log 2. Randomly found resource https://sd-card-images.johang.se/boards/rock_pi_4.html with debian-bookworm works, but it's very minimal image and all even simple config need to be done by manual. It's will take so many time (((( see debian-bookworm-minimal.log If upgrade kernel to next release apt install armbian-firmware=21.08.6 linux-dtb-current-rockchip64=21.08.2 linux-image-current-rockchip64=21.08.2 linux-u-boot-rockpi-4b-current=21.08.1 Armbian_22.02.1_Rockpi-4b_bullseye_5.15.25 The system stop working correctly, see Armbian_22.02.1_Rockpi-4b_bullseye_5.15.25.log And it's not working on all next releases including 6.0.9 and 6.1.0 Armbian_21.08.1_Rockpi-4b_bullseye_5.10.60.log Armbian_21.08.2_Rockpi-4b_bullseye_5.10.63.log debian-bookworm-minimal.log Armbian_22.02.1_Rockpi-4b_bullseye_5.15.25.log
  9. I download and try your build, got the same issue Starting kernel ... [ 2.047065] Internal error: synchronous external abort: 0000000096000210 [#1] SMP [ 2.047772] Modules linked in: [ 2.048070] CPU: 1 PID: 64 Comm: kworker/u12:2 Not tainted 6.1.0-65.fc37.aarch64 #1 [ 2.048769] Hardware name: Radxa ROCK Pi 4B (DT) [ 2.049197] Workqueue: events_unbound deferred_probe_work_func [ 2.049754] pstate: 604000c5 (nZCv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2.050392] pc : rockchip_pcie_rd_conf+0x128/0x164 [ 2.050846] lr : rockchip_pcie_rd_conf+0x120/0x164 [ 2.051294] sp : ffff80000c5db890 [ 2.051601] x29: ffff80000c5db890 x28: ffff00000156b800 x27: 0000000000000000 [ 2.052268] x26: ffff000001568800 x25: 0000000000000001 x24: 0000000000000000 [ 2.052931] x23: ffff80000b386588 x22: 0000000000000000 x21: ffff80000c5db90c [ 2.053596] x20: 0000000000000004 x19: ffff80000e100000 x18: ffffffffffffffff [ 2.054259] x17: 000000005e80c22f x16: 000000002c060080 x15: ffff80000c5db788 [ 2.054922] x14: ffff000001b55a1c x13: ffff000001b55290 x12: 00000000914f756d [ 2.055586] x11: 000000002f359453 x10: 0000000000000000 x9 : ffff8000088aacb0 [ 2.056249] x8 : ffff80000c5db810 x7 : ffff0000074abb80 x6 : ffff000001568800 [ 2.056912] x5 : ffff00000156b800 x4 : 0000000000c00008 x3 : ffff800011000000 [ 2.057575] x2 : 000000000080000a x1 : ffff800011c00008 x0 : ffff800011c0000c [ 2.058239] Call trace: [ 2.058471] rockchip_pcie_rd_conf+0x128/0x164 [ 2.058892] pci_bus_read_config_dword+0x70/0xcc [ 2.059325] pci_bus_generic_read_dev_vendor_id+0x38/0x17c [ 2.059839] pci_scan_single_device+0x84/0x100 [ 2.060258] pci_scan_slot+0x5c/0x200 [ 2.060609] pci_scan_child_bus_extend+0x50/0x2e0 [ 2.061051] pci_scan_bridge_extend+0x300/0x574 [ 2.061478] pci_scan_child_bus_extend+0x1c4/0x2e0 [ 2.061928] pci_scan_root_bus_bridge+0x6c/0xe0 [ 2.062355] pci_host_probe+0x20/0xd0 [ 2.062705] rockchip_pcie_probe+0x374/0x560 [ 2.063110] platform_probe+0x70/0xcc [ 2.063464] really_probe+0xc8/0x3e0 [ 2.063807] __driver_probe_device+0x84/0x190 [ 2.064221] driver_probe_device+0x44/0x120 [ 2.064619] __device_attach_driver+0xc4/0x160 [ 2.065040] bus_for_each_drv+0x74/0xb4 [ 2.065406] __device_attach+0xa8/0x1c0 [ 2.065773] device_initial_probe+0x1c/0x30 [ 2.066170] bus_probe_device+0xa4/0xb0 [ 2.066536] deferred_probe_work_func+0xc0/0x114 [ 2.066971] process_one_work+0x1ec/0x470 [ 2.067353] worker_thread+0x200/0x410 [ 2.067709] kthread+0xec/0x100 [ 2.068018] ret_from_fork+0x10/0x20 [ 2.068368] Code: 52800141 97fffa11 7100129f 54fffb41 (b9400273) [ 2.068929] ---[ end trace 0000000000000000 ]--- [ 2.069356] note: kworker/u12:2[64] exited with preempt_count 1 [ 2.085324] mmc_host mmc2: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 2.293765] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 228 [ 2.298632] mmc2: new ultra high speed SDR104 SDIO card at address 0001 [ 90.443481] random: crng init done
  10. Thank you in advance. I will check it tomorrow morning and publish console log here.
  11. Thank you for your response. But it's a bit at odds with my goals. I not so skill in linux for this...
  12. Please provide link to distributive what you use. And additional question: Are Bluetooth work fine with this distributive?
  13. Hello, no in 6.1 it's still doesn't work root@rockpi-4b:~# uname -a Linux rockpi-4b 6.1.0-rockchip64 #trunk.0055 SMP PREEMPT Fri Dec 16 13:28:04 UTC 2022 aarch64 GNU/Linux root@rockpi-4b:~# dmesg | grep -E 'brcm|Blue|ieee' [ 9.726956] Bluetooth: Core ver 2.22 [ 9.726979] Bluetooth: Starting self testing [ 9.747224] brcmfmac: F1 signature read @0x18000000=0x15294345 [ 9.752572] Bluetooth: ECDH test passed in 24985 usecs [ 9.753978] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 9.754443] usbcore: registered new interface driver brcmfmac [ 9.758076] Bluetooth: SMP test passed in 5295 usecs [ 9.758124] Bluetooth: Finished self testing [ 9.758232] Bluetooth: HCI device and connection manager initialized [ 9.758254] Bluetooth: HCI socket layer initialized [ 9.758265] Bluetooth: L2CAP socket layer initialized [ 9.758288] Bluetooth: SCO socket layer initialized [ 10.014472] Bluetooth: HCI UART driver ver 2.3 [ 10.014504] Bluetooth: HCI UART protocol H4 registered [ 10.014511] Bluetooth: HCI UART protocol BCSP registered [ 10.014668] Bluetooth: HCI UART protocol LL registered [ 10.014679] Bluetooth: HCI UART protocol ATH3K registered [ 10.014735] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 10.015237] Bluetooth: HCI UART protocol Intel registered [ 10.016319] Bluetooth: HCI UART protocol Broadcom registered [ 10.016409] Bluetooth: HCI UART protocol QCA registered [ 10.016416] Bluetooth: HCI UART protocol AG6XX registered [ 10.016449] Bluetooth: HCI UART protocol Marvell registered [ 10.120786] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Jun 16 2017 12:38:26 version 7.45.96.2 (66c4e21@sh-git) (r) FWID 01-1813af84 [ 10.273867] systemd[1]: Reached target Bluetooth Support. [ 12.288751] Bluetooth: hci0: command 0xfc18 tx timeout [ 20.448622] Bluetooth: hci0: BCM: failed to write update baudrate (-110) [ 20.448652] Bluetooth: hci0: Failed to set baudrate [ 22.464451] Bluetooth: hci0: command 0x0c03 tx timeout [ 30.688615] Bluetooth: hci0: BCM: Reset failed (-110)
  14. So I got serial console cable and what I figured out: From https://github.com/radxa-build/rock-pi-4b/releases/tag/20221201-0200 Image: Armbian_22.11.0-trunk_Rockpi-4b_bullseye_current_5.15.80_minimal.img uname -a: Linux rockpi-4b 5.15.80-rockchip64 #trunk SMP PREEMPT Thu Dec 1 07:25:43 UTC 2022 aarch64 GNU/Linux From https://imola.armbian.com/dl/rockpi-4b/archive/ Image: Armbian_22.11.1_Rockpi-4b_bullseye_current_5.15.80.img uname -a: Linux rockpi-4b 5.15.80-rockchip64 #22.11.1 SMP PREEMPT Wed Nov 30 11:12:47 UTC 2022 aarch64 GNU/Linux Works without NVMe, but when I insert NVMe, the system stuck on next: [ 2.450469] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: [ 2.451172] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 [ 2.452008] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 [ 2.453746] rockchip-pcie f8000000.pcie: no bus scan delay, default to 0 ms [ 2.508191] rockchip-pcie f8000000.pcie: wait 0 ms (from device tree) before bus scan [ 2.509380] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 2.509992] pci_bus 0000:00: root bus resource [bus 00-1f] [ 2.510502] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] [ 2.511135] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) [ 2.512088] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400 [ 2.512819] pci 0000:00:00.0: supports D1 [ 2.513195] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.520737] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.532997] Internal error: synchronous external abort: 96000210 [#1] PREEMPT SMP [ 2.533685] Modules linked in: [ 2.533980] CPU: 3 PID: 223 Comm: kworker/u12:4 Not tainted 5.15.80-rockchip64 #22.11.1 [ 2.534711] Hardware name: Radxa ROCK Pi 4B (DT) [ 2.535136] Workqueue: events_unbound deferred_probe_work_func [ 2.535686] pstate: 600000c5 (nZCv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2.536322] pc : rockchip_pcie_rd_conf+0xb0/0x230 [ 2.536764] lr : rockchip_pcie_rd_conf+0xec/0x230 [ 2.537203] sp : ffff80000a723830 [ 2.537509] x29: ffff80000a723830 x28: 0000000000000000 x27: 0000000000000000 [ 2.538172] x26: 0000000000000000 x25: 0000000000000000 x24: ffff80000a723974 [ 2.538834] x23: ffff000005a8b000 x22: 0000000000000000 x21: 0000000000000004 [ 2.539495] x20: ffff80000a7238b4 x19: ffff80000c100000 x18: 0000000000000000 [ 2.540157] x17: 6572202c295d3030 x16: 2d3030207375625b x15: ffffffffffffffff [ 2.540818] x14: ffff80000954e228 x13: ffff000005a6ba1c x12: ffff000005a6b290 [ 2.541480] x11: 0000000000000028 x10: 0000000000000001 x9 : 0000000001001d87 [ 2.542142] x8 : 000000000000ea60 x7 : ffff80000a723800 x6 : 0000000000000001 [ 2.542803] x5 : 0000000000000003 x4 : 0000000000000000 x3 : 0000000000c00008 [ 2.543464] x2 : 000000000080000a x1 : ffff80000fc00008 x0 : ffff80000fc0000c [ 2.544127] Call trace: [ 2.544358] rockchip_pcie_rd_conf+0xb0/0x230 [ 2.544768] pci_bus_read_config_dword+0x84/0xd8 [ 2.545200] pci_bus_generic_read_dev_vendor_id+0x34/0x1b0 [ 2.545711] pci_bus_read_dev_vendor_id+0x4c/0x70 [ 2.546151] pci_scan_single_device+0x84/0xd8 [ 2.546560] pci_scan_slot+0x38/0x120 [ 2.546907] pci_scan_child_bus_extend+0x58/0x330 [ 2.547346] pci_scan_bridge_extend+0x340/0x5a0 [ 2.547771] pci_scan_child_bus_extend+0x1fc/0x330 [ 2.548219] pci_scan_root_bus_bridge+0xd4/0xf0 [ 2.548643] pci_host_probe+0x18/0xb0 [ 2.548991] rockchip_pcie_probe+0x4a8/0x4c0 [ 2.549392] platform_probe+0x68/0xd8 [ 2.549740] really_probe+0xbc/0x428 [ 2.550076] __driver_probe_device+0x114/0x188 [ 2.550490] driver_probe_device+0xb0/0x110 [ 2.550879] __device_attach_driver+0xbc/0x158 [ 2.551293] bus_for_each_drv+0x7c/0xd0 [ 2.551658] __device_attach+0xec/0x1a8 [ 2.552017] device_initial_probe+0x14/0x20 [ 2.552407] bus_probe_device+0x9c/0xa8 [ 2.552766] deferred_probe_work_func+0x9c/0xf0 [ 2.553186] process_one_work+0x20c/0x4c8 [ 2.553567] worker_thread+0x208/0x478 [ 2.553921] kthread+0x138/0x150 [ 2.554229] ret_from_fork+0x10/0x20 [ 2.554575] Code: f94013f5 a8c37bfd d50323bf d65f03c0 (b9400273) [ 2.555132] ---[ end trace b08bc39ec7a1232e ]--- [ 2.555557] note: kworker/u12:4[223] exited with preempt_count 1 I know you said no money for this but still, maybe it's will helpful And also maybe someone can help me with it... Armbian_22.11.1_Rockpi-4b_bullseye_5.15.80.log Armbian_22.11.0-trunk_Rockpi-4b_bullseye_5.15.80.log
