sirob
1348 profile views
sirob's Achievements
  1. Still don't realy know how to forward X11 ^^ but I used this command line to render files : blender -b /home/blender/project.blend --render-output /tmp --render-frame 1 My project need more than 2Gb of Ram, so it can't render pictures on Nano Pi Neo2 (need 4Gb of Ram)
  2. Hello, I want to use nano pi neo2 as a compiler server (for picture rendering with "Blender") Is it possible to forward X11 via ssh ? What img must I use to do this ? (I don't know if server bionic is suitable to do this) Best Regards, Boris
  3. I use my own enclosure (and I will not change) so I try to keep thermal settings back, if someone knows how to downscale DDR reduce CPU number and Freq on a NanoPi neo (like in the 3.4.113 kernel for example with h3consumption), it should be great ^^^^^
  4. Linux nanopineo 5.3.9-sunxi #19.11.3 SMP Mon Nov 18 18:49:43 CET 2019 armv7l armv7l armv7l GNU/Linux CPU temp: 54°C CPU temp: 54°C Without heatsink it is normal, I think, but with previous configuration I never come over 50° so I try to reach this. What range of temperature do you have ? If I use a closed enclosure, temperature increases to 80° and I stop the board. With h3consumption and a 3.4.113-sun8i I can keep under 50° reducing number of cpu and ddr freq If I use a closed enclosure, so that's what I try to have.
  5. Linux nanopineo 5.3.9-sunxi #19.11.3 SMP Mon Nov 18 18:49:43 CET 2019 armv7l armv7l armv7l GNU/Linux CPU temp: 54°C CPU temp: 54°C Without heatsink it is normal, I think, but with previous configuration I never come over 50° so I try to reach this. What range of temperature do you have ? If I use a closed enclosure, temperature increases to 80° and I stop the board. With h3consumption and a 3.4.113-sun8i I can keep under 50° reducing number of cpu and ddr freq, if I use a closed enclosure, so that's what I try to have.
  6. Thank you for your answer Guidol, I wget the latest h3consumtion script (https://raw.githubusercontent.com/armbian/build/master/packages/bsp/h3consumption) thanks to tkaiser, but it does not fits to Nano Pi Neo. I used armbian-config instead to successfully change processor consumption, but temperature is too high. Reduce the DDR clock is really what I need. I modified script.bin thanks to you,. Thank for your help I added "dram_clk=360" to uboot environment with armbian-config but it does not seems to decrease the temperature.
  7. Mmm I'll do my best, hope the next generation of box will have more success to my customers and then I could do that.
  8. Hi All, I am looking for h3consumption utility to change ddr freq (I want to set ddr and processor as low as possible) Could someone help me ? Best Regards, Boris
  9. Hello, I am on a nano pi neo, I get an optical input with an external usb audio card. I d'ont know how to use the onboard spdif as an optical input so is it possible to get the optical input of an usb card (wich I see with alsamixer) an output sound to the local analog output (I already can play sound on this output) ? Maybe a loopback or an audio software could helps.... Best Regards
  10. Hello, I try to download beelink image (there is a 404 error) I know that this version is not supported but could amrbian team make these links work again ? Best Regards
  11. Do Mpv memory increases when playing on a standard install with the latest armbian ? (I think it will be the same on any install) I must know if it is due to audio drivers before doing what you tell me to do. Can you please tell me what you see on your install ? Launch for example the following command line and check : mpv http://stream.radiohamburg.de/rhh-live/mp3-128/radiode/ & (it is not my prefered radio lol) And check with top command if memory increase indefinitly (just launch "top" after)
  12. Is it hard to reproduce ? I am the only one who have this problem ?
  13. Mpv is a video and an audio player. Can you launch mpv (with a stream url) and watch memory status with top command Tido ?
  14. I have the same problem with the latest kernel (updated an upgraded) Mpv memory starts from about 10% and increases about 0.1% each 15s and system crashes a few hours later. (I don't have the problem on my ubuntu PC) I am sure someone will find the solution :)))) Must I report a bug ? (I install latest kernel, update and upgrade, activate analog input with armbian-config and I play an url with mpv) I tried with moc but : Running the server... Trying JACK... Trying ALSA... Trying OSS... FATAL_ERROR: No valid sound driver! (I try to have a multiroom audio solution)
