Posts
88 -
Joined
Last visited
Content Type
Forums
Store
Crowdfunding
Applications
Events
Raffles
Community Map
Everything posted by Lion Wang
about WOC , BPI-M2 Zero`s CPUX-SET is PL1, and orange pi ,Nano Pi use PL6. just GPIO PIN define not same.
orange pi is a perfect product ??, not any defect ??? they have complete product information service??? and write all right doucments??? Why didn't you attack them???, why ,why .............What makes you lose basic justice??? And then you understand why I ignore you. You even send email to our customers to let our customers choose orange PI.
we have public schematic : http://forum.banana-pi.org/t/bpi-m2-zero-schematic-diagram-public/4111
this is Network interface PIN define , you can contact RJ45 port.
I'm sorry, I just can't stand the continuous attacks from tkaiser in recent years. I will continue my work and try to make everything better. I've always had a lot of respect and admiration for the work that the armbian community has done, and they're a group of great people.I also want to have a better cooperation.
you don't work for SinoVoip,but your actions justify your working for someone else.
we test H2+, H3, H5 chip on this design , for Allwinner H2+,H3,H5 chip is PIN to PIN compatibility. this design can support 3 type chip onboard.
BPI-M2 Zero schematic: http://forum.banana-pi.org/t/bpi-m2-zero-schematic-diagram-public/4111 BPI-M2 zero DXF file: http://forum.banana-pi.org/t/bpi-m2-zero-dxf-file-public/4110
Image --------------------------- New test images(kernel and root.squashfs) are available: http://pan.baidu.com/s/1nuXrUTb How to program both uImage and root file system ---------------------------- 1. Copy both uImagelede and root.squashfs to tftp server 2. Run below command to program uImagelede > tftp 84000000 uImagelede > mmc dev 0 > mmc write 84000000 1000 6000 3. Run below command to program root.squashfs to EMMC: > tftp 84000000 root.squashfs > mmc dev 0 > mmc write 84000000 20A00 6000 4. Run command: boot 5. Configure an available IP address and then run below commands when entering OS > opkg update > opkg install luci-theme-bootstrap > opkg install luci-mod-admin-full 6. Connect R2 board via web
I've test the AP mode, find it works fine, please follow my steps to enable it. Firstly please install Ubuntu 16.04 image, and then: 1,Remove pkg wpasupplicant(apt-get remove wpa_supplicant) if you're using Ubuntu 16.04 image 2,Comment out echo 1 > ${{WIFI_DEV} in /etc/init.d/wifi_enable if you're using Ubuntu 16.04 image 3,Reboot 4,Run command "echo A >/dev/wmtWifi" 5,Run comand : hostapd -dd -C /etc/hostapd/hostapd.conf Below is an example of hostapd.conf: hw_mode=g interface=ap0 driver=nl80211 channel=1 auth_algs=1 ssid=test Also the patch @BitMaster provided is delivered to github. Thanks a lot, BitMaster. https://github.com/BPI-SINOVOIP/BPI-R2-bsp/commit/219be3221aadb2d316557df8064bb231ca46ed51
as igor said ,armbian not support BPI-R2, we now development LEDE on BPI-R2, Use kernel 4.9 . and support H-NAT now. http://forum.banana-pi.org/t/bpi-r2-lede-source-code-for-hardware-nat/3940
no problem , can you give me a list ?? we will send out it
It's probably not going to be that price soon, now the R3399 chip is about 20 USD
1,BPI-M2+ ,just HDMI , you need use HDMI to VGA accessories line to let it support VGA. Just BPI-M1 with VGA and HDMI port. 2,about H2+,H3,H5 chip , all is PIN to PIN compatibility, to support your project ,more support is about software support. 3,this is open source project ,you can get all design documents. we can support you. 4, armbian have do a good work for support allwinner H3 chip.:)
Read that 4.14 will have additional ARM Board Support including some Banana Pi products .. Among the new ARM boards supported are for the Beaglebone X15 Rev C (TI AM57xx), Raspberry Pi Zero W, D-Link DIR-685 router (Gemini-based), Banana Pi R2 (MT7623), Cubietruck Plus, Banana Pi M3/M2M/M64, NanoPi A64, A64-OLinuXino, Pine64, Rockchip RK3328 Pine64/Rock64 support, ZTE ZX296718 PCBOX Board, and others. link: https://www.phoronix.com/scan.php?page=news_item&px=ARM-Hardware-Linux-4.14
We're just documenting some of the real data that we've gotten in the development process.Let everyone have a reference, also hope more help us to test.:) The test of hardware performance is sometimes very much related to the test environment, and we try our best to test our overall hardware performance to meet the requirements of chip design
we test a SAMSUNG SSD DISK, the Read/Write performance are below: (1) Read from disk: 230MB/s (command: dd if=/dev/sda of=/dev/zero bs=1M count=10240) (2) Write to disk: 192MB/s (command: dd if=/dev/zero of=/dev/sda bs=1M count=1024 oflag=direct)
Below is the performance of IP forwarding over GMACs(eth0 and eth1): Single direction flow Bidirection flow Statistics on R2 board: root@LEDE:/proc/irq/70# ifconfig eth0 Link encap:Ethernet HWaddr EE:86:59:C8:EB:3A inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::ec86:59ff:fec8:eb3a/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:26822854 errors:0 dropped:0 overruns:0 frame:0 TX packets:37617944 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:35021520367 (32.6 GiB) TX bytes:49849909918 (46.4 GiB) Interrupt:68 eth1 Link encap:Ethernet HWaddr 8E:3B:FE:FC:EA:BE inet addr:192.168.10.1 Bcast:192.168.10.255 Mask:255.255.255.0 inet6 addr: fe80::8c3b:feff:fefc:eabe/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:37621811 errors:0 dropped:0 overruns:0 frame:0 TX packets:26821988 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:49699772484 (46.2 GiB) TX bytes:35127932237 (32.7 GiB) Interrupt:68
BPI-M1, BPI-M1+, BPI-M2 Berry ,BPI-M2 Ultra with sata interface ,maybe can support you . even BPI-R2 also can support , but cost is higher.
BPI-R2 new Image :2017-09-04-ubuntu-16.04-mate-desktop-bpi-r2-sd-emmc-v1.2.0.img.zip http://forum.banana-pi.org/t/bpi-r2-new-image-ubuntu-16-04-mate-desktop-bpi-r2-sd-emmc-v1-2-0-img-zip-2017-09-04/3783/1 BPI-R2 with BPI-7615(based on MT7615) module development progress http://forum.banana-pi.org/t/bpi-r2-with-bpi-7615-based-on-mt7615-module-development-progress/3796 BPI-R2 New image : Openwrt/LEDE 2017-09-08 http://forum.banana-pi.org/t/bpi-r2-new-image-openwrt-lede-2017-09-08/3797
Review Quick review of Banana Pi M2+
Lion Wang replied to tkaiser's topic in Reviews, Tutorials, Hardware hacks
update schematic : 2017-08-24 https://drive.google.com/file/d/0B4PAo2nW2KfnbzQ5MTB5eXNEN1U/view?usp=sharing -
Banana pi BPI-M3 android source code public: https://drive.google.com/open?id=0B_YnvHgh2rwjXzVwWk94WWdQRmM
yes, with friendly way.
