chaijate
  • Content Count
    9
  1. chaijate
    ARMBIAN for Amlogic S905 and S905X (ver 5.44 =<)
    I tested it with my android tv box, found the 5.37 version (3.14.29) best and very stable. I tested version 5.44 has a midi sequencer with this kennel, but there are many problems. So I need to use the midi sequencer with 5.37 version, I noob linux. Can you describe the process of compiling kernels? Thank you
  2. chaijate
    Thank you very much.
  3. chaijate
    @balbes150 sorry again. Yesterday i used the "modprobe wlan" command, which it works. But after I added the wlan into file /etc/modules and reboot again. I Can't see any wifi anymore. I tried to help myself. But it was not successful. Do you have any recommendations for this?
  4. chaijate
    Thank you very much It's work ..... thank you very much @balbes150. You are exellent!
  5. chaijate
    Unsuccess ~~~~ It's not work. I searched the M8S Pro wifi chipset from the internet. It is labeled as WiFi Chip: QCA9377. http://www.fn-link.com/a-b-g-n-ac-wi-fi-bt-module/8223a-sr.html
  6. chaijate
    @pisach Thank you very much. This will return home to test the machine at home. There is another question, I have a searh package in synaptic, which is very long time. Do you know this problem? Thank again.
  7. chaijate
    mecool M8S pro Amlogic S912 (3/32GB)
  8. chaijate
    Hello I have tested Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_mate_20180515.img. I can not use wifi network. I tried to use command "modprobe wifi_dummy" as it used to work with previous versions, but this image was not successful. Have tested with the version Armbian_5.44_S9xxx_Debain_stretch_3.14.29_xfce.img and not as successful. Can anyone tell me how to solve this problem? Thanks in advance
  9. chaijate
    Trying to recompile the Kernel for MINI M8S...
    Hello whoman I used "Armbian_5.24_Amlogic-s905x_Debian_jessie_3.14.29 I think the problem is the same as you. The problem is that the kernel does not support midi. (/dev/snd/seq not found) I am an end user, so it's hard to get a kernel file. I tried to follow the example of Nofan Tasi and it was not successful. As I said, I'm not expert and do not understand the config values of kernel. Can you describe your kernel compilation successfully? Hope to receive your kindness from you. Thank you
