XX7
Posts
6 -
Joined
Last visited
Content Type
Forums
Store
Crowdfunding
Applications
Events
Raffles
Community Map
Posts posted by XX7
On 07/12/2017 at 10:18 AM, balbes150 said:
To work WiFi need a proper dtb, kernel module (can be integrated into the kernel itself), the firmware and the right settings. You need to determine in which element the error.
I didt find propret dtb file I open my box and find out that there is WiFi modul based on SCI S9082C could anybody advise how to solve this problem..
hi I have two AMLogic TV box.
1. MeCool M8S pro plus - Mate working ok, but there is no Wifi (is there any way to add driver for this Wifi)
2.T95Zplus - Mate working ok, but there is problem with LAN driver, I cannot conect over lan cable, Wifi working ok, but every restart I need to enter comand "sudo modprobe dhd" is it any solution to permanent change this options
Thx balbes150 and big respect for your work!
In my research I find out that possible problem is because teamviewer not support architecture arm64, only support armHF.
Possibel this two version have some similarity and can be hack, but I did't find the way.
Pls correct me if I am wrong.
hi
I am newbie and need help regarding instaling teamviewer on armbian.
I have TVbox M8Spro+ with armbian mate, all working well except wifi, but this is minorr problem LAN working ok.
But my biggest problem is how to instal and start working with teamviewer.
I try to follow command :
wget http://download.teamviewer.com/download/linux/version_11x/teamviewer-host_armhf.deb sudo dpkg -i teamviewer-host_armhf.deb sudo apt install -f cat /etc/teamviewer/global.conf | grep ClientID teamviewer passwd my_password
After that I try to find out ID in the: /etc/teamviewer/global.conf, and some ID is recorder.
I check but ID always is offline.
I try to start teamviewer with comand sudo teamviewer daemon start, I get feedback from system:
systemctl start teamviewerd.service
Failed to start teamviewerd.service: Unit teamviewerd.service not found.
failPls advise, thx.
hi guys I have two question:
- how to enable autologin (mate ver. 1104)
- on same version I have problem with running Teamviewer installing temaviewrer pass ok, but I cannot start, windows never show up
H96Max (RK3399) - mate image!?
in General Chat
Hi to all,
I update this box with VS RK3399 debian Image.
Working yes, but USB 3.0 and wifi not work.
But I am looking for ubuntu mate imafe, if exist
thx
