Jota79
Posts
11 -
Joined
Last visited
Content Type
Forums
Store
Crowdfunding
Applications
Events
Community Map
Posts posted by Jota79
Please... Could someone to take a photo of BSN20 MOSFET in te PCB? I would like to check my Orange Pi Zero Plus 2.
Thanks in advance
On 15/2/2018 at 10:53 PM, Jota79 said:
It is probabily for my weak charger/psu. I only need 0.5a but my weak charger/psu only get 4.88v at 0.45a. With an estimated vdroop of 0.2-0.3 with my usb cable ( 1 meter, not AWG20... ) my orange pi probabily get 4.6v. I am not very sure, I am going testing that some days.
At last the guilty was not my weak charger/psu, the issue was at client side. My PC, my samba client, connects to 2.4Ghz wifi sometimes and connects to 5Ghz wifi anothertimes. 2.4Ghz -> poor network throughput, 5Ghz -> good network throughput.
It was not a kernel problem, nor power/hardware issue. It is my fault, sorry for confusion. -
On 12/2/2018 at 9:50 PM, Jota79 said:
Another time poor network throughput with last kernel ( 5.37.180117 - 4.14.18-sunxi64 ). Is it possible to select another kernel ?
Thanks in advance
with last kernel ( 5.37.180117 - 4.14.18-sunxi64 ). Is it possible to select another kernel ?At last It was an issue in my PC, at samba client side. My PC connects to 2.4Ghz instead of 5Ghz one
Thanks in advance
On 21/1/2018 at 10:38 AM, guidol said:
No - only passive inside a black cube Raspberry Zero Case - but my Opi Zero Plus is almost idle
You could see my "modified" black qube cas here:but my case does stand on the side (heat can flow away and the room temperature is aroud 20 degree): root@opi-zeroplus:~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 12:36:14: 816MHz 0.07 0% 0% 0% 0% 0% 0% 42.2°C 0/2 12:36:19: 816MHz 0.06 0% 0% 0% 0% 0% 0% 43.3°C 0/2 12:36:24: 816MHz 0.06 0% 0% 0% 0% 0% 0% 41.9°C 0/2 12:36:29: 816MHz 0.05 0% 0% 0% 0% 0% 0% 43.4°C 0/2 12:36:34: 816MHz 0.05 0% 0% 0% 0% 0% 0% 42.7°C 0/2
As attachment some temperatures - out of my NodeRed Dashboard - to compare
uooohhhh!!!!! What a tiny "big" CPD!!!!! ;-) Thank you very much, guidol. It is a very good reference for me. Now, I have moved my orange pi zero plus H5 to a very open-space ( it was inside a very closed furniture before.... ). I have moved it behind my plasma TV ;-). And now, almost idle, temperature is in normal values ( with 21C room temperature ):
root@zeus:~# armbianmonitor -m
Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St.22:02:28: 816MHz 0.36 10% 1% 1% 3% 3% 0% 47.2°C 0/2
22:02:33: 816MHz 0.33 4% 1% 2% 0% 0% 0% 44.4°C 0/2
22:02:38: 816MHz 0.31 2% 1% 1% 0% 0% 0% 45.0°C 0/2
22:02:43: 816MHz 0.28 2% 1% 1% 0% 0% 0% 42.2°C 0/2
22:02:49: 816MHz 0.34 2% 0% 1% 0% 0% 0% 44.3°C 0/2
22:02:54: 816MHz 0.31 3% 1% 2% 0% 0% 0% 45.3°C 0/2
22:02:59: 816MHz 0.29 2% 1% 1% 0% 0% 0% 46.2°C 0/2
22:03:04: 816MHz 0.34 2% 0% 1% 0% 0% 0% 43.0°C 0/2
22:03:09: 816MHz 0.32 6% 1% 5% 0% 0% 0% 47.2°C 0/2
22:03:14: 816MHz 0.29 2% 1% 1% 0% 0% 0% 44.5°C 0/2
22:03:19: 816MHz 0.27 3% 1% 1% 0% 0% 0% 43.9°C 0/2
22:03:24: 816MHz 0.25 3% 1% 1% 0% 0% 0% 45.4°C 0/2
22:03:29: 816MHz 0.23 2% 1% 1% 0% 0% 0% 44.9°C 0/2
22:03:34: 816MHz 0.21 5% 1% 3% 0% 0% 0% 45.4°C 0/2
22:03:39: 816MHz 0.19 2% 1% 1% 0% 0% 0% 44.2°C 0/2
22:03:44: 816MHz 0.17 2% 1% 1% 0% 0% 0% 44.6°C 0/2
22:03:50: 816MHz 0.16 3% 1% 1% 0% 0% 0% 44.3°C 0/2
I use my OP Zero for NAS Server ( samba/nfs ) and for p2p downloads with mldonkey.
You can see my brico-project with an old celeron heatsink ( I am very worried with temperatures, perhaps I am a little friki... ):
Guidol... Do you have any active cooling? Your temperatures are very low...
9 hours ago, guidol said:
On my Zero Plus H5 its working:
ARMBIAN 5.37.180117 nightly Debian GNU/Linux 9 (stretch) 4.14.13-sunxi64
Linux opi-zeroplus 4.14.13-sunxi64 #35 SMP Tue Jan 16 17:51:14 CET 2018 aarch64 GNU/Linux
Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St.14:47:32: 816MHz 0.00 0% 0% 0% 0% 0% 0% 43.4°C 0/2
14:47:38: 816MHz 0.00 0% 0% 0% 0% 0% 0% 42.8°C 0/2
14:47:43: 816MHz 0.00 0% 0% 0% 0% 0% 0% 42.5°C 0/2
14:47:48: 816MHz 0.00 0% 0% 0% 0% 0% 0% 42.8°C 0/2root@opi-zeroplus:~# ls -la /etc/armbianmonitor/datasources/soctemp
lrwxrwxrwx 1 root root 47 Jan 14 08:17 /etc/armbianmonitor/datasources/soctemp -> /sys/devices/virtual/thermal/thermal_zone0/temp
It is very strange.....
I have lost symbolyc link to /sys/devices/virtual/thermal/thermal_zone0/temp:
Time CPU load %cpu %sys %usr %nice %io %irq C.St.20:47:06: 816MHz 0.33 14% 1% 5% 2% 3% 0% 0/2^C
root@zeus:~# ls -la /etc/armbianmonitor/datasources/soctemp
ls: cannot access '/etc/armbianmonitor/datasources/soctemp': No such file or directoryI have to create it manually and voila! :
root@zeus:~# ln -s /sys/devices/virtual/thermal/thermal_zone0/temp /etc/armbianmonitor/datasources/soctemp
root@zeus:~# armbianmonitor -m Stop monitoring using [ctrl]-[c]
Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St.20:52:46: 816MHz 1.79 14% 1% 5% 2% 3% 0% 64.6°C 0/2
20:52:51: 816MHz 1.81 30% 5% 7% 4% 11% 1% 63.4°C 0/2^C
Thank you guidol!
Showing Temperature is missing in last two kernels:
root@zeus:/sys/class/thermal/thermal_zone0# uname -a
Linux zeus 4.14.13-sunxi64 #35 SMP Tue Jan 16 17:51:14 CET 2018 aarch64 GNU/Linux
root@zeus:/sys/class/thermal/thermal_zone0# armbianmonitor -m
Time CPU load %cpu %sys %usr %nice %io %irq C.St.20:50:25: 816MHz 1.82 22% 3% 3% 4% 10% 0% 0/2
20:50:30: 816MHz 1.83 16% 3% 1% 6% 5% 0% 0/2Although, you can see it manually:
root@zeus:~# cat /sys/class/thermal/thermal_zone0/temp
59169
62678
On 2/1/2018 at 9:59 AM, Jota79 said:
hello,
Trying last kernel, 4.14.8-sunxi64, I am getting a very poor network throughput, only 3.98MB/s via samba.... Before that, I got 30MB/s ( via samba with my USB 2.0 HDD as bottleneck ).
Furtheremore, I see a max CPU Freq at 812Mhz ( before 1Ghz ) and very high temperatures at idle... Perhaps CPU Freq Scaling is not fully implemented. I am very excited with this little board and I am sure
I am going to see some improvements soon. I had been using an Orange pi One with armbian for one year very happy. This board, Orange Pi Zero Plus, is my gigabit upgrade as NAS. Great distro armbian!!
Thank you armbain-team!
Best RegardsHello again,
New kernel, new news. I am getting very good network throughput again with last kernel 4.14.10-sunxi64. I am getting 30MB/s transfer speed with my config, via samba with an USB 2.0 HDDD as bottleneck. Great!!
On 21/12/2017 at 8:18 PM, guidol said:
4.14.8-sunxi64
hello,
Best Regards
Orange Pi Zero Plus2 H5 hardware oddity in VDD_CPUX power circuit
in Allwinner sunxi
Thanks for photo!
Mine is missing too.... I do not understand this Xunlong decission...
