67 -
Ok, got it! I've moved finally to Ubuntu Focal server: make SSD from disk image make eMMC from the same disk image edit /boot/ on eMMC to my needs make SSD via USB 3.0 as root file system in kernel parameters Kernel upgrade is hard but possible.
There was unneeded line in /etc/samba/smb.conf: ; socket options = TCP_NODELAY IPTOS_LOWDELAY SO_KEEPALIVE SO_RCVBUF=8192 SO_SNDBUF=8192
I am observing huge difference in samba speed (both ways to/from PC on Gigabit Ethernet) with Rock Pi 4B. Earlier I had Debian and Ubuntu provided by Radxa and recently speed has gone from 115 MB/s to ~12 MB/s. I moved to Armbian which is currently available for download. Before any updates I had 115 MB/s transfer speed. When I updated to Armbian 20.08.11 Focal with Linux 5.8.15-rockchip64 the speed has go down to ~15 MB/s. The bigger change that happened was kernel upgrade. I exclude problems like: PSU (it is over enough), home network (nothing has changed) and SSD speed (checked - 330 MB/s). Has anyone else also observed limited speed recently?
Hi All! I've recently moved to Armbian (Debian buster server) on my Rock Pi 4B - from Ubuntu provided by Radxa (some way failed upgrade). However system is booting from eMMC which has Radxa kernel and then directly to Armbian file system on SSD connected via USB 3.0. Great is that Armbian is working with Radxa kernel, which I want to change to 5.8.14-rockchip64. My question is how should I prepare /boot folder on eMMC (which is FAT file system) to boot Armbian kernel? Is there any other way (reformat eMMC for ext4@32768 sector for /boot folder) to achieve this? Thanks.
I bought here https://pishop.at/index.php/single-board-computer/rock-pi-4-model-b-4gb-detail with overall price (with shipment) €114.78 (504.44 PLN). I've seen the same model €105 from Spain without shipment...
@Dante4 unfortunately there are some countries which they are not shipping to. Poland is one of them.
@NicoD I will need to order heatsink. For now it is just a test board. I'll try not to heat it too much.
No heatsink, no fan. $ stress-ng --cpu 1 --cpu-method matrixprod --metrics-brief -t 60 stress-ng: info: [1125] successful run completed in 60.22s (1 min, 0.22 secs) stress-ng: info: [1125] stressor bogo ops real time usr time sys time bogo ops/s bogo ops/s stress-ng: info: [1125] (secs) (secs) (secs) (real time) (usr+sys time) stress-ng: info: [1125] cpu 253 60.22 60.19 0.00 4.20 4.20 $ stress-ng --cpu 6 --cpu-method matrixprod --metrics-brief -t 60 stress-ng: info: [1147] successful run completed in 60.30s (1 min, 0.30 secs) stress-ng: info: [1147] stressor bogo ops real time usr time sys time bogo ops/s bogo ops/s stress-ng: info: [1147] (secs) (secs) (secs) (real time) (usr+sys time) stress-ng: info: [1147] cpu 793 60.20 359.21 0.08 13.17 2.21 $ sysbench --test=cpu --cpu-max-prime=20000 --num-threads=1 --max-time=60 run sysbench 1.0.11 (using system LuaJIT 2.1.0-beta3) Running the test with following options: Number of threads: 1 Initializing random number generator from current time Prime numbers limit: 20000 Initializing worker threads... Threads started! CPU speed: events per second: 701.24 General statistics: total time: 60.0014s total number of events: 42084 Latency (ms): min: 1.42 avg: 1.42 max: 6.72 95th percentile: 1.42 sum: 59964.36 Threads fairness: events (avg/stddev): 42084.0000/0.00 execution time (avg/stddev): 59.9644/0.00 $ sysbench --test=cpu --cpu-max-prime=20000 --num-threads=6 --max-time=60 run sysbench 1.0.11 (using system LuaJIT 2.1.0-beta3) Running the test with following options: Number of threads: 6 Initializing random number generator from current time Prime numbers limit: 20000 Initializing worker threads... Threads started! CPU speed: events per second: 2237.70 General statistics: total time: 60.0024s total number of events: 134280 Latency (ms): min: 1.42 avg: 2.68 max: 22.67 95th percentile: 3.62 sum: 359842.66 Threads fairness: events (avg/stddev): 22380.0000/8091.23 execution time (avg/stddev): 59.9738/0.01 $ 7z b 7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=pl_PL.UTF-8,Utf16=on,HugeFiles=on,64 bits,6 CPUs LE) LE CPU Freq: 1064 979 894 1260 1651 1792 1792 1792 1792 RAM size: 3812 MB, # CPU hardware threads: 6 RAM usage: 1323 MB, # Benchmark threads: 6 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 4218 478 858 4104 | 92601 523 1509 7897 23: 4035 494 833 4112 | 87611 544 1394 7581 24: 3793 516 791 4079 | 84930 564 1323 7455 25: 3592 530 774 4102 | 81479 586 1237 7251 ---------------------------------- | ------------------------------ Avr: 504 814 4099 | 554 1365 7546 Tot: 529 1090 5823 7z b: 1.609 more total MIPS than RPi 3B+ with fan.
cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 lscpu: Architecture: aarch64 Byte Order: Little Endian CPU(s): 6 On-line CPU(s) list: 0-5 Thread(s) per core: 1 Core(s) per socket: 3 Socket(s): 2 Vendor ID: ARM Model: 4 Model name: Cortex-A53 Stepping: r0p4 CPU max MHz: 1800.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 uname -a: Linux rock 4.4.154-ge0ce80a-dirty #6 SMP Fri Nov 23 16:58:02 CST 2018 aarch64 aarch64 aarch64 GNU/Linux dmesg attached. dmesg.txt
@martinayotte I am not asking about Armbian. I am asking about the mentioned OSes. I have Armbian on armv7l and it is 32-bit. At least provided binaries are 32-bit. I ask about bitness of the provided OSes for Rock Pi 4. There is no Armbian for this board.
@martinayotte I am not asking for CPU bitness. I am asking if these OSes images are 64-bit!
@hipboi I already have this one. I was asking if these are 64-bit or 32-bit...
Thank you for the links! Are these 64-bit Debian/Ubuntu?
@mboehmer Where did you get Debian for this board?
