krachlatte
Posts
81 -
Joined
Last visited
Content Type
Forums
Store
Crowdfunding
Applications
Events
Raffles
Community Map
Posts posted by krachlatte
https://github.com/orangepi-xunlong/orangepi-build
so wee need to wait for 3.0.0 to shwo up on git to use the device trees form 5.16.17.
best regards
i will try to check which images is running tomorrow,
i recommend using focal and if possible 5.xx kernel
Am 21.2.2022 um 11:35 schrieb lamobot:
the same problem, after upgrade, update - red LED and Armbian initializing boot loader on the screen (connected via microhdmi)
https://redirect.armbian.com/region/EU/orangepizero2/Focal_edge
did you try this one it works fine
hi
if you set the volume mixer to software it is no problem tuning the volume up and down, from volumino, but this could cause lossy output.
best regards
vor 1 Stunde schrieb nightguest:
no. it doen't work from armbian-config (it's about both docker and hassio)
i do not understand how i should help you?
vor 5 Minuten schrieb nightguest:
you can try this for debian
update-alternatives --set iptables /usr/sbin/iptables-legacy curl -fsSL http://mirrors.aliyun.com/docker-ce/linux/debian/gpg | apt-key add - add-apt-repository "deb [arch=arm64] https://mirrors.aliyun.com/docker-ce/linux/debian $(lsb_release -cs) stable" apt update apt install docker-ce
i use it to install home assistant supervised
could you use armbian-config 3rd party software and install docker from there, does this work ?
Hi TRS-80, yes,
i got a orangepi zero 512MB running with volumino, found here
https://community.volumio.org/t/volumio-debian-buster-beta-orange-pi-images/44826/12
i am using the orangepione image Volumio-3.078-2021-07-15-orangepione.img and going to upgrade soon to Volumio-3.198-2022-01-31-orangepione relreased recently
and a USB DAC with SPDIF based on PCM2704 found here https://www.ebay.de/itm/401578060510
its the blue board dropdown is PCM2704
connected to the USB Port of the orangepi zero pi, dac is connected to onkyo receiver, and powered via USB output of that Onkyo Receiver on the back to + and - on the Orangepi Zero Header, USB output on the back of the receveir is rated 5v 1A.
use proper powersupply and proper SD card than thats totaly enough
Am 2.2.2022 um 06:09 schrieb mantouboji:
USB is still broken
orangepizero2 login: [ 36.424984] usb 2-1: device descriptor read/64, error -62
[ 36.728997] usb 2-1: device descriptor read/64, error -62
[ 37.220946] usb 2-1: device descriptor read/64, error -62
[ 37.525006] usb 2-1: device descriptor read/64, error -62
[ 38.268960] usb 2-1: device not accepting address 4, error -62
[ 38.876945] usb 2-1: device not accepting address 5, error -62
[ 38.882920] usb usb2-port1: unable to enumerate USB deviceshwoing this on console when blugin in a usb stick
vor 2 Stunden schrieb Hervé Changue:
Hello did you try supported images from website?? (24 jan) i can't make it work i got nothing thanks
this one, i used the EU server for download. runns total fine, no issues sd card is extended and inital startup sript for root password goes througth, and reboot works also fine.
which tools do you use to write the sd card, do you use sd card formatter and win32diskimager ?
these two are not booting nothing on console only Network led
This image boots fine, reboot does work too
Armbian_21.08.9_Orangepizero2_focal_edge_5.15.11.img.xz
this image not showing anything on console Armbian_22.02.0-trunk.0023_Orangepizero2_jammy_edge_5.15.18.img
as far as i rember this was the latest verion which was working 22.02.0-trunk.0004
vor 6 Stunden schrieb Werner:
I have my doubts that an image made for H2+ SoC will boot on H616...
totalay right the 2 is missing, goole search, i have this image here, its not in the archive anymore.
Armbian_21.08.1_Orangepizero2_hirsute_edge_5.13.12.img.xz
this image boots no problem, but has still the reboot issue
so same problem again any idea on how to fix this from uboot shell ?
vor 5 Stunden schrieb krachlatte:
hi guys,
this morning after upgrading the uboot image to (22.02.0-trunk.0005)
=> boot
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2612 bytes read in 3 ms (849.6 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
180 bytes read in 3 ms (58.6 KiB/s)
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
12373835 bytes read in 518 ms (22.8 MiB/s)
Failed to load '/boot/uImage'
Wrong Image Format for bootm command
ERROR: can't get kernel image!
SCRIPT FAILED: continuing...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
BootOrder not defined
EFI boot manager: Cannot load any image
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.x.yz (1901 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-02-00-15-7f-b0-f4
Retrieving file: pxelinux.cfg/C0A80837
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
Config file not foundany idea on how to fix this ?
many thanks and best regards
ther was a chane in the boot.cmd file booti has changed from booti to bootm
bootm ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
hi guys,
=> boot
Scanning mmc 0:1...
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
BOOTP broadcast 1
BOOTP broadcast 2
29 minutes ago, balbes150 said:
To do this, you need a working u-boot for this model.
There are only two launch options for AML. 1. using the standard u-boot from eMMC, which added universal multi-boot. 2. completely remove the u-boot in eMMC and try to use an external u-boot from the SD card.
how can i provide/build this ? as far as i can see there are dts files available in latest kerne and uboot
anyone can let me know on how to get this runing on the beeling gs1 with h6 allwinner soc?
many thanks
guys finally i got it complied and it is booting
____ _ _ _ ____ ____ _
| __ ) ___ ___| (_)_ __ | | __ / ___/ ___|/ |
| _ \ / _ \/ _ \ | | '_ \| |/ / | | _\___ \| |
| |_) | __/ __/ | | | | | < | |_| |___) | |
|____/ \___|\___|_|_|_| |_|_|\_\ \____|____/|_|Welcome to Focal with Linux 5.8.0-sunxi64
No end-user support: built from trunk
System load: 7.64 5.94 3.76 Up time: 17 min Local users: 2
Memory usage: 23 % of 1926MB IP: 192.168.
CPU temp: 59°C
Usage of /: 10% of 29GLast login: Fri Aug 14 11:43:02 2020 from 192.168.
root@beelink-gs1:/home/beelink# cat /var/log/dmesg
[ 2.018058] kernel: ohci-platform: OHCI generic platform driver
[ 2.018233] kernel: ohci-platform 5101400.usb: Generic Platform OHCI controller
[ 2.018260] kernel: ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2
[ 2.018371] kernel: ohci-platform 5101400.usb: irq 30, io mem 0x05101400
[ 2.081166] kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
[ 2.081186] kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.081202] kernel: usb usb2: Product: Generic Platform OHCI controller
[ 2.081215] kernel: usb usb2: Manufacturer: Linux 5.8.0-sunxi64 ohci_hcd
[ 2.081228] kernel: usb usb2: SerialNumber: 5101400.usb
[ 2.081604] kernel: hub 2-0:1.0: USB hub found
[ 2.081642] kernel: hub 2-0:1.0: 1 port detected
[ 2.082378] kernel: usbcore: registered new interface driver usb-storage
[ 2.082864] kernel: mousedev: PS/2 mouse device common for all mice
[ 2.083641] kernel: sun6i-rtc 7000000.rtc: registered as rtc0
[ 2.083682] kernel: sun6i-rtc 7000000.rtc: setting system clock to 1970-01-01T00:00:07 UTC (7)
[ 2.083699] kernel: sun6i-rtc 7000000.rtc: RTC enabled
[ 2.083801] kernel: i2c /dev entries driver
[ 2.084183] kernel: sun8i-thermal 5070400.thermal-sensor: Failed to get calibration nvmem cell (-517)
[ 2.084207] kernel: sun8i-thermal 5070400.thermal-sensor: Failed to probe thermal sensor (-517)
[ 2.084616] kernel: sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 2.085770] kernel: sdhci: Secure Digital Host Controller Interface driver
[ 2.085789] kernel: sdhci: Copyright(c) Pierre Ossman
[ 2.085818] kernel: Synopsys Designware Multimedia Card Interface Driver
[ 2.086425] kernel: sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.086569] kernel: sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
[ 2.087061] kernel: ledtrig-cpu: registered to indicate activity on CPUs
[ 2.087483] kernel: hid: raw HID events driver (C) Jiri Kosina
[ 2.087582] kernel: usbcore: registered new interface driver usbhid
[ 2.087593] kernel: usbhid: USB HID core driver
[ 2.089102] kernel: NET: Registered protocol family 10
[ 2.114747] kernel: Segment Routing with IPv6
[ 2.114855] kernel: NET: Registered protocol family 17
[ 2.114998] kernel: 8021q: 802.1Q VLAN Support v1.8
[ 2.115159] kernel: 9pnet: Installing 9P2000 support
[ 2.115235] kernel: Key type dns_resolver registered
[ 2.115705] kernel: registered taskstats version 1
[ 2.115721] kernel: Loading compiled-in X.509 certificates
[ 2.119429] kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 8f056047adb00eda9ac57e97a166dd2fcf7fa442'
[ 2.119559] kernel: zswap: loaded using pool lzo/zbud
[ 2.119818] kernel: Key type ._fscrypt registered
[ 2.119830] kernel: Key type .fscrypt registered
[ 2.119839] kernel: Key type fscrypt-provisioning registered
[ 2.120863] kernel: Btrfs loaded, crc32c=crc32c-generic
[ 2.132867] kernel: Key type encrypted registered
[ 2.132938] kernel: AppArmor: AppArmor sha1 policy hashing enabled
[ 2.132981] kernel: ima: No TPM chip found, activating TPM-bypass!
[ 2.133016] kernel: ima: Allocated hash algorithm: sha1
[ 2.133048] kernel: ima: No architecture policies found
[ 2.133097] kernel: evm: Initialising EVM extended attributes:
[ 2.133109] kernel: evm: security.selinux
[ 2.133117] kernel: evm: security.SMACK64
[ 2.133125] kernel: evm: security.SMACK64EXEC
[ 2.133133] kernel: evm: security.SMACK64TRANSMUTE
[ 2.133141] kernel: evm: security.SMACK64MMAP
[ 2.133149] kernel: evm: security.apparmor
[ 2.133156] kernel: evm: security.ima
[ 2.133164] kernel: evm: security.capability
[ 2.133172] kernel: evm: HMAC attrs: 0x1
[ 2.150324] kernel: sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[ 2.150634] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
[ 2.151106] kernel: printk: console [ttyS0] disabled
[ 2.151193] kernel: 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 24, base_baud = 1500000) is a 16550A
[ 3.529582] kernel: printk: console [ttyS0] enabled
[ 3.535241] kernel: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 3.540777] kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[ 3.548578] kernel: xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010
[ 3.558022] kernel: xhci-hcd xhci-hcd.1.auto: irq 31, io mem 0x05200000
[ 3.564306] kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 3.572585] kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.579816] kernel: usb usb3: Product: xHCI Host Controller
[ 3.584704] kernel: usb usb3: Manufacturer: Linux 5.8.0-sunxi64 xhci-hcd
[ 3.590717] kernel: usb usb3: SerialNumber: xhci-hcd.1.auto
[ 3.596021] kernel: hub 3-0:1.0: USB hub found
[ 3.599811] kernel: hub 3-0:1.0: 1 port detected
[ 3.604011] kernel: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 3.609516] kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[ 3.617190] kernel: xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 3.623780] kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.631993] kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[ 3.640267] kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.647497] kernel: usb usb4: Product: xHCI Host Controller
[ 3.652383] kernel: usb usb4: Manufacturer: Linux 5.8.0-sunxi64 xhci-hcd
[ 3.658396] kernel: usb usb4: SerialNumber: xhci-hcd.1.auto
[ 3.663639] kernel: hub 4-0:1.0: USB hub found
[ 3.667431] kernel: hub 4-0:1.0: 1 port detected
[ 3.672184] kernel: usb_phy_generic usb_phy_generic.2.auto: supply vcc not found, using dummy regulator
[ 3.681520] kernel: musb-hdrc musb-hdrc.3.auto: MUSB HDRC host driver
[ 3.687292] kernel: musb-hdrc musb-hdrc.3.auto: new USB bus registered, assigned bus number 5
[ 3.695187] kernel: phy id_det change to host
[ 3.699041] kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 3.707320] kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.714549] kernel: usb usb5: Product: MUSB HDRC host driver
[ 3.719523] kernel: usb usb5: Manufacturer: Linux 5.8.0-sunxi64 musb-hcd
[ 3.725535] kernel: usb usb5: SerialNumber: musb-hdrc.3.auto
[ 3.730941] kernel: hub 5-0:1.0: USB hub found
[ 3.734730] kernel: hub 5-0:1.0: 1 port detected
[ 3.740148] kernel: sun8i-thermal 5070400.thermal-sensor: Thermal sensor ready!
[ 3.746926] kernel: sun50i_cpufreq_nvmem: Using CPU speed bin speed0
[ 3.753271] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 3.762545] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[ 3.771531] kernel: scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
[ 3.778802] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 3.787934] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[ 3.796839] kernel: sun8i-mixer 1100000.mixer: deferred probe timeout, ignoring dependency
[ 3.804617] kernel: sun4i-drm display-engine: deferred probe timeout, ignoring dependency
[ 3.830986] kernel: sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800010d6fb88)
[ 3.838733] kernel: sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800010d73d30)
[ 3.846811] kernel: sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800010d6b948)
[ 3.855223] kernel: sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator
[ 3.863319] kernel: sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY)
[ 3.873595] kernel: sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver
[ 3.881396] kernel: sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800010d6ef50)
[ 3.888928] kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.895861] kernel: [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 3.968992] kernel: Console: switching to colour frame buffer device 128x48
[ 3.992047] kernel: sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[ 4.000015] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 4.009558] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[ 4.018859] kernel: of_cfs_init
[ 4.021482] kernel: of_cfs_init: OK
[ 4.025804] kernel: Freeing unused kernel memory: 2240K
[ 4.044966] kernel: Run /init as init process
[ 4.048715] kernel: with arguments:
[ 4.048718] kernel: /init
[ 4.048720] kernel: with environment:
[ 4.048724] kernel: HOME=/
[ 4.048726] kernel: TERM=linux
[ 4.048729] kernel: ubootpart=26535d99-01
[ 4.048732] kernel: cgroup_enable=memory
[ 4.232944] kernel: usb 2-1: new full-speed USB device number 2 using ohci-platform
[ 4.451552] kernel: sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PD regulator
[ 4.458928] kernel: sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 96
[ 4.465995] kernel: sun50i-h6-pinctrl 300b000.pinctrl: pin-96 (5020000.ethernet) status -517
[ 4.473943] kernel: sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 96 (PD0) from group PD0 on device 300b000.pinctrl
[ 4.476000] kernel: usb 2-1: New USB device found, idVendor=1997, idProduct=2433, bcdDevice=20.12
[ 4.484985] kernel: dwmac-sun8i 5020000.ethernet: Error applying setting, reverse things back
[ 4.501453] kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.508803] kernel: usb 2-1: Product: Mini Keyboard
[ 4.513119] kernel: usb 2-1: Manufacturer:
[ 4.534287] kernel: axp20x-i2c 1-0036: AXP20x variant AXP806 found
[ 4.542202] kernel: input: Mini Keyboard as /devices/platform/soc/5101400.usb/usb2/2-1/2-1:1.0/0003:1997:2433.0001/input/input0
[ 4.558861] kernel: input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-1/1-0036/axp221-pek/input/input1
[ 4.613647] kernel: hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [ Mini Keyboard] on usb-5101400.usb-1/input0
[ 4.639122] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 4.655231] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[ 4.671115] kernel: dcdca: supplied by vcc-5v
[ 4.671886] kernel: sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PD regulator
[ 4.694589] kernel: sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 96
[ 4.707715] kernel: sun50i-h6-pinctrl 300b000.pinctrl: pin-96 (5020000.ethernet) status -517
[ 4.721665] kernel: sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 96 (PD0) from group PD0 on device 300b000.pinctrl
[ 4.738715] kernel: dwmac-sun8i 5020000.ethernet: Error applying setting, reverse things back
[ 4.753369] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 4.753525] kernel: dcdcc: supplied by vcc-5v
[ 4.770085] kernel: input: Mini Keyboard Mouse as /devices/platform/soc/5101400.usb/usb2/2-1/2-1:1.1/0003:1997:2433.0002/input/input2
[ 4.802605] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[ 4.818224] kernel: input: Mini Keyboard System Control as /devices/platform/soc/5101400.usb/usb2/2-1/2-1:1.1/0003:1997:2433.0002/input/input3
[ 4.841183] kernel: dcdcd: supplied by vcc-5v
[ 4.854162] kernel: vdd-sys: Bringing 900000uV into 960000-960000uV
[ 4.866816] kernel: dcdce: supplied by vcc-5v
[ 4.875776] kernel: random: fast init done
[ 4.887097] kernel: aldo1: supplied by vcc-5v
[ 4.897618] kernel: aldo2: supplied by vcc-5v
[ 4.901294] kernel: input: Mini Keyboard Consumer Control as /devices/platform/soc/5101400.usb/usb2/2-1/2-1:1.1/0003:1997:2433.0002/input/input4
[ 4.932759] kernel: vcc-ac200: Bringing 700000uV into 3300000-3300000uV
[ 4.933378] kernel: hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [ Mini Keyboard] on usb-5101400.usb-1/input1
[ 4.963419] kernel: aldo3: supplied by vcc-5v
[ 4.964035] kernel: sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PD regulator
[ 4.987342] kernel: sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 96
[ 5.000821] kernel: sun50i-h6-pinctrl 300b000.pinctrl: pin-96 (5020000.ethernet) status -517
[ 5.015194] kernel: sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 96 (PD0) from group PD0 on device 300b000.pinctrl
[ 5.032739] kernel: dwmac-sun8i 5020000.ethernet: Error applying setting, reverse things back
[ 5.047402] kernel: vcc25-dram: Bringing 700000uV into 3300000-3300000uV
[ 5.047968] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 5.076683] kernel: bldo1: supplied by vcc-5v
[ 5.076742] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[ 5.104047] kernel: bldo2: supplied by vcc-5v
[ 5.115551] kernel: bldo3: supplied by vcc-5v
[ 5.126615] kernel: vcc-dcxoio: Bringing 700000uV into 1800000-1800000uV
[ 5.140353] kernel: bldo4: supplied by vcc-5v
[ 5.151482] kernel: cldo1: supplied by vcc-5v
[ 5.162396] kernel: cldo2: supplied by vcc-5v
[ 5.173065] kernel: vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV
[ 5.186275] kernel: cldo3: supplied by vcc-5v
[ 5.196981] kernel: vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV
[ 5.210056] kernel: sw: supplied by regulator-dummy
[ 5.221279] kernel: axp20x-i2c 1-0036: AXP20X driver loaded
[ 5.233712] kernel: dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
[ 5.246394] kernel: dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
[ 5.258577] kernel: dwmac-sun8i 5020000.ethernet: PTP uses main clock
[ 5.270620] kernel: dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator
[ 5.393164] kernel: dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000)
[ 5.408691] kernel: dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[ 5.421985] kernel: dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[ 5.435122] kernel: dwmac-sun8i 5020000.ethernet: COE Type 2
[ 5.445803] kernel: dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[ 5.458242] kernel: dwmac-sun8i 5020000.ethernet: Normal descriptors
[ 5.469381] kernel: dwmac-sun8i 5020000.ethernet: Chain mode enabled
[ 5.480804] kernel: libphy: stmmac: probed
[ 5.505096] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 5.519833] kernel: sunxi-mmc 4020000.mmc: Got CD GPIO
[ 5.553711] kernel: sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 5.569097] kernel: sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
[ 5.607719] kernel: sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[ 5.634376] kernel: mmc0: host does not support reading read-only switch, assuming write-enable
[ 5.650005] kernel: mmc0: new high speed SDHC card at address 214f
[ 5.661979] kernel: mmcblk0: mmc0:214f APPSD 29.5 GiB
[ 5.673809] kernel: mmcblk0: p1
[ 5.784967] kernel: mmc1: new DDR MMC card at address 0001
[ 5.796093] kernel: mmcblk1: mmc1:0001 NCard 14.5 GiB
[ 5.806370] kernel: mmcblk1boot0: mmc1:0001 NCard partition 1 4.00 MiB
[ 5.818099] kernel: mmcblk1boot1: mmc1:0001 NCard partition 2 4.00 MiB
[ 5.830837] kernel: sunxi-mmc 4022000.mmc: data error, sending stop command
[ 5.842442] kernel: sunxi-mmc 4022000.mmc: send stop command failed
[ 6.004521] kernel: EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[ 6.742262] systemd[1]: System time before build time, advancing clock.
[ 6.781915] systemd[1]: systemd 245.4-4ubuntu3.2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 6.816069] systemd[1]: Detected architecture arm64.
[ 6.876201] systemd[1]: Set hostname to <beelink-gs1>.
[ 7.287330] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[ 7.575776] kernel: random: systemd: uninitialized urandom read (16 bytes read)
[ 7.591924] systemd[1]: Created slice system-modprobe.slice.
[ 7.610341] kernel: random: systemd: uninitialized urandom read (16 bytes read)
[ 7.624224] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.643154] kernel: random: systemd: uninitialized urandom read (16 bytes read)
[ 7.656839] systemd[1]: Created slice User and Session Slice.
[ 7.675383] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.696582] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.719643] systemd[1]: Reached target User and Group Name Lookups.
[ 7.739394] systemd[1]: Reached target Remote File Systems.
[ 7.758252] systemd[1]: Reached target Slices.
[ 7.775723] systemd[1]: Reached target Swap.
[ 7.792731] systemd[1]: Reached target System Time Set.
[ 7.811314] systemd[1]: Listening on Syslog Socket.
[ 7.829763] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.850030] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.870935] systemd[1]: Listening on Journal Audit Socket.
[ 7.890415] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.910399] systemd[1]: Listening on Journal Socket.
[ 7.929266] systemd[1]: Listening on udev Control Socket.
[ 7.948557] systemd[1]: Listening on udev Kernel Socket.
[ 7.971931] systemd[1]: Mounting Huge Pages File System...
[ 7.994845] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.018812] systemd[1]: Mounting Kernel Debug File System...
[ 8.038057] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 8.058149] systemd[1]: Starting Restore / save the current clock...
[ 8.082280] systemd[1]: Starting Set the console keyboard layout...
[ 8.106895] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 8.129214] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 8.134309] systemd[1]: Started Nameserver information manager.
[ 8.163655] systemd[1]: Reached target Network (Pre).
[ 8.184104] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 8.199693] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.221376] systemd[1]: Starting Load Kernel Modules...
[ 8.243842] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.268054] systemd[1]: Starting udev Coldplug all Devices...
[ 8.275635] kernel: EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[ 8.307187] systemd[1]: Mounted Huge Pages File System.
[ 8.326001] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.345558] systemd[1]: Mounted Kernel Debug File System.
[ 8.366524] systemd[1]: Finished Restore / save the current clock.
[ 8.388368] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 8.414863] systemd[1]: Finished Load Kernel Modules.
[ 8.437134] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 8.463094] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 8.482511] systemd[1]: Mounting Kernel Configuration File System...
[ 8.509852] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 8.525165] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 8.545351] systemd[1]: Starting Load/Save Random Seed...
[ 8.568847] systemd[1]: Starting Apply Kernel Variables...
[ 8.592514] systemd[1]: Starting Create System Users...
[ 8.617833] systemd[1]: Finished Set the console keyboard layout.
[ 8.638609] systemd[1]: Mounted Kernel Configuration File System.
[ 8.648511] systemd[1]: Finished Apply Kernel Variables.
[ 8.658214] systemd[1]: Finished Create System Users.
[ 8.670294] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 8.679845] systemd[1]: Finished udev Coldplug all Devices.
[ 8.694205] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[ 8.713447] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[ 8.725467] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 8.732511] systemd[1]: Reached target Local File Systems (Pre).
[ 8.743412] systemd[1]: Mounting /tmp...
[ 8.755186] systemd[1]: Starting udev Kernel Device Manager...
[ 8.765766] systemd[1]: Mounted /tmp.
[ 8.772653] systemd[1]: Reached target Local File Systems.
[ 8.783554] systemd[1]: Starting Armbian ZRAM config...
[ 8.794995] systemd[1]: Starting Set console font and keymap...
[ 8.806081] systemd[1]: Starting Raise network interfaces...
[ 8.816959] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 8.823235] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
[ 8.823536] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 8.835401] systemd[1]: Finished Set console font and keymap.
[ 8.875663] systemd[1]: plymouth-read-write.service: Succeeded.
[ 8.877604] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[ 9.165229] systemd[1]: Started udev Kernel Device Manager.
[ 9.172200] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 9.172775] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active.
[ 9.183188] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 9.183344] systemd[1]: Reached target Local Encrypted Volumes.
[ 9.322415] kernel: zram: Added device: zram0
[ 9.323038] kernel: zram: Added device: zram1
[ 9.330684] kernel: zram: Added device: zram2
[ 9.420988] kernel: cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz
[ 9.426950] kernel: cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1080000 KHz
[ 9.509564] kernel: zram1: detected capacity change from 0 to 1009922048
[ 9.531119] systemd[1]: Finished Raise network interfaces.
[ 9.547950] systemd[1]: Found device /dev/ttyS0.
[ 10.476338] kernel: mc: Linux media interface: v0.10
[ 10.506102] kernel: panfrost 1800000.gpu: clock rate = 432000000
[ 10.506123] kernel: panfrost 1800000.gpu: bus_clock rate = 100000000
[ 10.507481] kernel: panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0
[ 10.507490] kernel: panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400
[ 10.507495] kernel: panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7
[ 10.507498] kernel: panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1
[ 10.512197] kernel: [drm] Initialized panfrost 1.1.0 20180908 for 1800000.gpu on minor 1
[ 10.551039] kernel: videodev: Linux video capture interface: v2.00
[ 10.556151] kernel: sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[ 10.556729] kernel: sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 10.563629] kernel: sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 10.563807] kernel: sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 10.563861] kernel: sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 10.563931] kernel: sun8i-ce 1904000.crypto: Register cbc(aes)
[ 10.564091] kernel: sun8i-ce 1904000.crypto: Register ecb(aes)
[ 10.564156] kernel: sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[ 10.564210] kernel: sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[ 10.564287] kernel: sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[ 10.585969] kernel: asoc-simple-card sound-spdif: dit-hifi <-> 5093000.spdif mapping ok
[ 10.664954] kernel: Registered IR keymap rc-beelink-gs1
[ 10.684522] kernel: IR NEC protocol handler initialized
[ 10.696585] kernel: sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.697736] kernel: cedrus 1c0e000.video-codec: deferred probe timeout, ignoring dependency
[ 10.700975] kernel: random: crng init done
[ 10.700982] kernel: random: 7 urandom warning(s) missed due to ratelimiting
[ 10.709777] kernel: cedrus 1c0e000.video-codec: Device registered as /dev/video0
[ 10.713093] kernel: rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[ 10.713206] kernel: rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[ 10.713288] kernel: input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input5
[ 10.713539] kernel: sunxi-ir 7040000.ir: initialized sunXi IR driver
[ 17.740260] kernel: asoc-simple-card hdmi-sound: i2s-hifi <-> 5091000.i2s mapping ok
[ 17.759824] systemd[1]: Finished Load/Save Random Seed.
[ 17.764939] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 17.765237] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 17.769527] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 17.772803] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 17.773238] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 17.776550] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 17.776780] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 17.776851] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 17.777037] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 17.777128] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 17.777187] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 17.785469] systemd[1]: plymouth-read-write.service: Succeeded.
[ 17.786603] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[ 17.789135] kernel: Adding 986248k swap on /dev/zram1. Priority:5 extents:1 across:986248k SSFS
[ 17.945845] kernel: zram0: detected capacity change from 0 to 52428800
[ 18.016642] systemd[1]: Finished Armbian ZRAM config.
[ 18.024760] systemd[1]: Starting Armbian memory supported logging...
[ 18.099804] kernel: EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[ 18.099833] kernel: ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[ 19.915005] systemd[1]: Finished Armbian memory supported logging.
[ 19.922466] systemd[1]: Starting Journal Service...
[ 20.070173] systemd[1]: Started Journal Service.
[ 476.917860] kernel: dwmac-sun8i 5020000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
[ 476.919616] kernel: dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found
[ 476.919628] kernel: dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available
[ 476.919633] kernel: dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW
[ 476.919641] kernel: dwmac-sun8i 5020000.ethernet eth0: configuring for phy/rgmii link mode
[ 480.997681] kernel: dwmac-sun8i 5020000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 480.997713] kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 1486.413495] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1487.405448] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1490.413318] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1491.405276] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1494.413142] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1495.405103] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1498.412972] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1499.404926] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1502.412823] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1503.404753] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1506.412619] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1507.404576] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1510.412445] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1511.404403] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1514.412274] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1515.404227] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1518.412100] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1519.404053] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1522.411926] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1523.403882] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1526.411750] sun6i-rtc 7000000.rtc: rtc is still busy.
[ 1527.403706] sun6i-rtc 7000000.rtc: rtc is still busy.RCT Problem ?
what needs to bee done to build a valid uboot form the beelink gs1 dts file ?
so as far as i understand i have build the uboot image correctly, what needs to be done to create a uboot image that cann be flashed like the one provided here for the tanix tx6 device ?
i have it booting, with network,
Hi,
i would love to have this running on a beelink GS1 from SD card, what si needed to build a working uboot image, or a complete working image of armbian on this box, dts files are allready in place in uboot and kernel repositorys, it builds fine but ist does not boot. any help ?
Hi Guys,
i am using this XL6009 board step down module together with a 2Tb Thosiba 2,5" usb 3 HDD and arduino nano with networking shield and 2.4Ghz Radio connected to this Board and a 12V Ultra silent Fan, i am feeding 12v to the stepdown and the output is tuned to 5.12V. i recommend puting small head sinks on the step down while using the opi3 with a HDD and additinal stuff. i am powering the opi3 directly via PIN Header and not the DC Jack.
Model Specification:DSN6000AUD Automatic Buck module
Module Properties:Non- isolated boost (BOOST)
Rectification:Non- Synchronous Rectification
Input Range:3.8V - 32V
Output Range:1.25V - 35V
Input Current:3A ( max ) , no-load 18mA (5V input , 8V output , no-load is less than 18mA. Higher the voltage , the greater the load current . )
Conversion efficiency:<94% ( greater the pressure , the lower the efficiency )
Switching frequency:400KHz
Output Ripple:50mV ( the higher the voltage , the greater the current , the greater the ripple )
Load Regulation:± 0.5%
Voltage Regulation:± 0.5%
Operating Temperature:-40 - +85for the 12V 1,5A i am using a generic power supply.
runns pretty nice for mor then a year
Hi,
and ethernet is working for you with this settings on the eachlink ?
because the beelink device has 1000 eg 1 Gbit ethernet. and the eachlink 100mbit only
best regards
OrangePi Zero2 - Allwinner H616
in Orange Pi Zero 2
what do you mean by chanige apt repositories ?? change the sourelists to something else ?
