hbars Posted April 20, 2019 Share Posted April 20, 2019 (edited) Hi. Instruction and dts on https://github.com/hbars/BPI-M2-Ultra-Berry-i2c-enable Edited April 20, 2019 by hbars Link to comment Share on other sites More sharing options...
Igor Posted April 20, 2019 Share Posted April 20, 2019 Tnx. Check this: https://github.com/armbian/sunxi-DT-overlays Link to comment Share on other sites More sharing options...
martinayotte Posted April 20, 2019 Share Posted April 20, 2019 Since H3 and R40 are similar, I presume the overlays already provided in any Armbian images under /boot/dtb/overlay should already work. Link to comment Share on other sites More sharing options...
guidol Posted April 20, 2019 Share Posted April 20, 2019 2 hours ago, martinayotte said: Since H3 and R40 are similar, I presume the overlays already provided in any Armbian images under /boot/dtb/overlay should already work. ____ ____ _ __ __ ____ ____ | __ )| _ \(_) | \/ |___ \ | __ ) ___ _ __ _ __ _ _ | _ \| |_) | | | |\/| | __) | | _ \ / _ \ '__| '__| | | | | |_) | __/| | | | | |/ __/ | |_) | __/ | | | | |_| | |____/|_| |_| |_| |_|_____| |____/ \___|_| |_| \__, | |___/ Welcome to ARMBIAN 5.81 user-built Debian GNU/Linux 9 (stretch) 5.0.7-sunxi package bsp-kernel[5.81] u-boot[5.81] dtb[5.81] firmware[5.81] config[5.81] root@bpi-m2-berry(192.168.6.20):/# more /boot/armbianEnv.txt verbosity=1 logo=disabled console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 rootfstype=ext4overlays=analog-codec i2c0 Link to comment Share on other sites More sharing options...
hbars Posted April 20, 2019 Author Share Posted April 20, 2019 59 minutes ago, martinayotte said: Since H3 and R40 are similar, I presume the overlays already provided in any Armbian images under /boot/dtb/overlay should already work. But not work. And how can they work when in dts and dtsi nowhere describes the pins of the ports. Link to comment Share on other sites More sharing options...
martinayotte Posted April 20, 2019 Share Posted April 20, 2019 1 hour ago, hbars said: But not work. And how can they work when in dts and dtsi nowhere describes the pins of the ports. At least for I2C-0, where the PMIC is attached, they are there, but for the other ports, you can prepare a patch and submit a PR to Armbian ... Link to comment Share on other sites More sharing options...
guidol Posted April 20, 2019 Share Posted April 20, 2019 35 minutes ago, martinayotte said: At least for I2C-0, they are there, but for the other ports, you can prepare a patch and submit a PR to Armbian ... I2C-0 doenst work for me on the M2 Berry (like - with the same commands - on my NanoPi Neo Core2) But I also cant compile the V40-I2C-0 root@bpi-m2-berry(192.168.6.20):/home/guido# dtc -I dts -O dtb v40-bananapi-m2-berry-i2c-0.dts -o v40-bananapi-m2-berry-i2c-0.dtbo Error: v40-bananapi-m2-berry-i2c-0.dts:2.2-8 syntax error FATAL ERROR: Unable to parse input tree I did wget the raw version od the dts and also did a clipboard-copy - but the has the same error. When I activate i2C-0 from normal armbian-config I do get root@bpi-m2-berry(192.168.6.20):/home/guido# i2cdetect -y 0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: 30 31 32 33 34 35 36 37 -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- root@bpi-m2-berry(192.168.6.20):/home/guido# i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- UU -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- but my I2C clock should be at 68 on I2C-0 like on my NanoPi Neo Core2 echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device modprobe rtc-ds1307 i2cdetect -y 0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- armbian:https://raw.githubusercontent.com/armbian/sunxi-DT-overlays/master/sun8i-h3/sun8i-h3-i2c0.dts V40:https://raw.githubusercontent.com/hbars/BPI-M2-Ultra-Berry-i2c-enable/master/v40-bananapi-m2-berry-i2c-0.dts Link to comment Share on other sites More sharing options...
hbars Posted April 24, 2019 Author Share Posted April 24, 2019 On 4/20/2019 at 9:34 PM, martinayotte said: At least for I2C-0, where the PMIC is attached, they are there, but for the other ports, you can prepare a patch and submit a PR to Armbian ... So they already are. https://github.com/hbars/BPI-M2-Ultra-Berry-i2c-enable/blob/master/v40-bananapi-m2-berry-i2c-1.dts https://github.com/hbars/BPI-M2-Ultra-Berry-i2c-enable/blob/master/v40-bananapi-m2-berry-i2c-2.dts Just gonna leave this here, because-as how to promote the patch does not know... And about PMIC pins I saw. Strange why was not describe the rest. Link to comment Share on other sites More sharing options...
DerBasti85 Posted May 9, 2019 Share Posted May 9, 2019 Can you please provide the binarys I also can not compile the dts files. Get the same error. Link to comment Share on other sites More sharing options...
DerBasti85 Posted May 9, 2019 Share Posted May 9, 2019 Get it working with a newer version $ wget http://httpredir.debian.org/debian//pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_armhf.deb $ dpkg --install device-tree-compiler_1.4.7-3_armhf.deb Link to comment Share on other sites More sharing options...
DerBasti85 Posted May 9, 2019 Share Posted May 9, 2019 Using it for an OLED in i2c and it is working now Link to comment Share on other sites More sharing options...
luetzel Posted February 3, 2020 Share Posted February 3, 2020 On 4/24/2019 at 10:04 PM, hbars said: So they already are. https://github.com/hbars/BPI-M2-Ultra-Berry-i2c-enable/blob/master/v40-bananapi-m2-berry-i2c-1.dts https://github.com/hbars/BPI-M2-Ultra-Berry-i2c-enable/blob/master/v40-bananapi-m2-berry-i2c-2.dts Just gonna leave this here, because-as how to promote the patch does not know... And about PMIC pins I saw. Strange why was not describe the rest. Howdy, I pick-up this old thread since I've been experimenting with i2c on m2u berry. The above patches did not work with 5.4.14, but with my own customized dts I was able to activate /dev/i2c-2 on 'buster' Linux bananaberry 5.4.14-sunxi #rc1 SMP Sat Jan 25 15:19:01 CET 2020 armv7l GNU/Linux Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target-path = "/aliases"; __overlay__ { i2c2 = "/soc/i2c@01c2b400"; }; }; fragment@1 { target = <&pio>; __overlay__ { i2c2_pins_a: i2c2@0 { pins = "PB20", "PB21"; function = "i2c2"; }; }; }; fragment@2 { target = <&i2c2>; __overlay__ { pinctrl-names = "default"; pinctrl-0 = <&i2c2_pins_a>; status = "okay"; }; }; }; > i2cdetect -y 2 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- 18 -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- -- 40: 40 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- 77 I can retrieve data from all i2c devices attached, however, enabling other overlays, such as spi-spidev in /boot/armbianEnv.txt with overlay_prefix=sun8i-h3 overlays=spi-spidev param_spidev_spi_bus=1 param_spidev_max_freq=100000000 resulted in the loss of /dev/i2c-2 and no spidev at all. I tried different combinations of stock spi-spidev and i2c0, i2c1 ... found in /boot/dtb/overlay. Furthermore, none of the uart overlays seem to work either. At least I would like to enable i2c2, spidev and uart at the same time, but I couldn't find the desired information within the existing threads. Link to comment Share on other sites More sharing options...
martinayotte Posted February 3, 2020 Share Posted February 3, 2020 5 hours ago, luetzel said: resulted in the loss of /dev/i2c-2 and no spidev at all. If you look at schematic, SPI1 bus is sharing pins with UART2, so you can't have both at the same time ! I woulkd rather suggest to use SPI0 instead, it won't conflict with UART2 ... Link to comment Share on other sites More sharing options...
luetzel Posted February 3, 2020 Share Posted February 3, 2020 Thanks for your fast reply. I tried param_spidev_spi_bus=0 as well, but also had no success with it. Link to comment Share on other sites More sharing options...
martinayotte Posted February 3, 2020 Share Posted February 3, 2020 7 minutes ago, luetzel said: param_spidev_spi_bus=1 This still SPI1, you should have specified for SPI0 : param_spidev_spi_bus=0 EDIT : Oh ! I've just saw a difference between M2-Berry UART2 compared to other board using H3 instead of V40. The UART2 is defaulted to PI18/PI19 instead of PA0/PA1. So, you will have to tweak DT here again ... Link to comment Share on other sites More sharing options...
luetzel Posted February 3, 2020 Share Posted February 3, 2020 Yes, you're right. Anyway, all combinations of i2c, spidev and uart failed and I have no clue how to fix it. Link to comment Share on other sites More sharing options...
martinayotte Posted February 3, 2020 Share Posted February 3, 2020 2 hours ago, luetzel said: I have no clue how to fix it. Maybe by editing Main DT directly instead of using overlays ... EDIT: Ok ! I added UART2 patches to my build, and I will commit them in Armbian as soon tests will be done. EDIT2: Committed : https://github.com/armbian/build/commit/64e494384b546be7ba35b32a1ab904389fed4e35 Link to comment Share on other sites More sharing options...
martinayotte Posted February 5, 2020 Share Posted February 5, 2020 On 2/3/2020 at 9:17 AM, luetzel said: I have no clue how to fix it. I've done more work and few more commits : there is now R40 distinct overlays for UART2/UART4/UART5/UART7 and SPIDEV0/SPIDEV1. Feel free to build new images using Armbian build scripts ... Link to comment Share on other sites More sharing options...
luetzel Posted February 7, 2020 Share Posted February 7, 2020 Okay, thanks! I'll give it a try, as soon as I'll find some time for it. Link to comment Share on other sites More sharing options...
