dchanceafs Posted April 21, 2019 Share Posted April 21, 2019 Upgraded kernel on existing working project and g_ether no longer working. So did fresh install on formatted card of Armbian_5.75_Orangepizeroplus2-h5_Ubuntu_bionic_next_4.19.20 If I do modprobe g_ether and then dmesg, I get the following udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers Is there something new in 4.19.20 that I must do? It used to work in older releases from 9 months ago or so... Link to comment Share on other sites More sharing options...
Igor Posted April 21, 2019 Share Posted April 21, 2019 5 hours ago, dchanceafs said: in older releases from 9 months ago or so... Which older release? Which kernel? Did you perhaps used your own kernel? By default mUSB port on smaller boards is used as additional serial console (g_serial) and AFAIK both can't operate at the same time. Link to comment Share on other sites More sharing options...
dchanceafs Posted April 22, 2019 Author Share Posted April 22, 2019 Works great in in ARMBIAN 5.34.171121 nightly Ubuntu 16.04.3 LTS 4.13.14-sunxi64 Fresh install of Armbian_5.75_Orangepizeroplus2-h5_Ubuntu_bionic_next_4.19.20 on new sd card. Simply logged in and changed password as required. Disabled g_serial in /etc/modules Then do modprobe g_ether and then dmesg, I get the following udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers Have never build a kernel... Link to comment Share on other sites More sharing options...
Igor Posted April 22, 2019 Share Posted April 22, 2019 6 hours ago, dchanceafs said: Have never build a kernel... Never to late to do that but essentially not needed to solve this problem. You have to add those OTG bits which fell out from board hardware configuration - which is normal due to extreme complexity of the project and lack of resources. And this- hw config - is considered as users part/problem - but ofc you have to understand what and where. If you don't, wait for next update, build image on your own, hire someone to do it for you ... Link to comment Share on other sites More sharing options...
