peej Posted April 23, 2019 Share Posted April 23, 2019 I have read other thread regarding v4l2loopback kernel module installation. I got same problem like this message below ========================================= ------------------------------ Deleting module version: 0.10.0 completely from the DKMS tree. ------------------------------ Done. Unpacking v4l2loopback-dkms (0.10.0-1) over (0.10.0-1) ... Setting up v4l2loopback-dkms (0.10.0-1) ... Loading new v4l2loopback-0.10.0 DKMS files... dpkg: warning: version '3.4.113-sun8i 4.19.25' has bad syntax: invalid character in revision number Building for 4.19.20-sunxi64 Module build for kernel 4.19.20-sunxi64 was skipped since the kernel headers for this kernel does not seem to be installed. =================================== I am usng Nano PI neo2 with armbian 4.19.20. When I install the kernel-headers using armbian-config, the version of kernel-headers installed is 4.19.25. Either the kernel source I have installed using armbian-config is 4.19.25. I just guess the version mistach doesn't make me succeed build of v4l2loopback. But I can't figure out what to do with this error. Please give me some comment. Link to comment Share on other sites More sharing options...
peej Posted April 23, 2019 Author Share Posted April 23, 2019 I have installed correct headers. And tried to build v4l2loopback again and get below message failed. What's wrong with me ? -------------------------------------------- root@nanopineo2:/usr/src# apt-get install --reinstall v4l2loopback-dkms Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 1 not upgraded. Need to get 0 B/23.1 kB of archives. After this operation, 0 B of additional disk space will be used. (Reading database ... 53947 files and directories currently installed.) Preparing to unpack .../v4l2loopback-dkms_0.10.0-1ubuntu1_all.deb ... -------- Uninstall Beginning -------- Module: v4l2loopback Version: 0.10.0 Kernel: 4.19.25-sunxi64 (aarch64) ------------------------------------- Status: Before uninstall, this module version was ACTIVE on this kernel. v4l2loopback.ko: - Uninstallation - Deleting from: /lib/modules/4.19.25-sunxi64/updates/dkms/ - Original module - No original module was found for this module on this kernel. - Use the dkms install command to reinstall any previous module version. depmod.... DKMS: uninstall completed. ------------------------------ Deleting module version: 0.10.0 completely from the DKMS tree. ------------------------------ Done. Unpacking v4l2loopback-dkms (0.10.0-1ubuntu1) over (0.10.0-1ubuntu1) ... Setting up v4l2loopback-dkms (0.10.0-1ubuntu1) ... Loading new v4l2loopback-0.10.0 DKMS files... Building for 4.19.25-sunxi64 Building initial module for 4.19.25-sunxi64 Error! Bad return status for module build on kernel: 4.19.25-sunxi64 (aarch64) Consult /var/lib/dkms/v4l2loopback/0.10.0/build/make.log for more information. root@nanopineo2:/usr/src# cd linux-headers-4.19.25-sunxi64/ root@nanopineo2:/usr/src/linux-headers-4.19.25-sunxi64# make scripts root@nanopineo2:/usr/src/linux-headers-4.19.25-sunxi64# root@nanopineo2:/usr/src/linux-headers-4.19.25-sunxi64# apt-get install --reinstall v4l2loopback-dkms Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 1 not upgraded. Need to get 0 B/23.1 kB of archives. After this operation, 0 B of additional disk space will be used. (Reading database ... 53947 files and directories currently installed.) Preparing to unpack .../v4l2loopback-dkms_0.10.0-1ubuntu1_all.deb ... ------------------------------ Deleting module version: 0.10.0 completely from the DKMS tree. ------------------------------ Done. Unpacking v4l2loopback-dkms (0.10.0-1ubuntu1) over (0.10.0-1ubuntu1) ... Setting up v4l2loopback-dkms (0.10.0-1ubuntu1) ... Loading new v4l2loopback-0.10.0 DKMS files... Building for 4.19.25-sunxi64 Building initial module for 4.19.25-sunxi64 Error! Bad return status for module build on kernel: 4.19.25-sunxi64 (aarch64) Consult /var/lib/dkms/v4l2loopback/0.10.0/build/make.log for more information. root@nanopineo2:/usr/src/linux-headers-4.19.25-sunxi64# Link to comment Share on other sites More sharing options...
