OrangePi Lite2 & 3 Bluetooth
data
In an effort to enable Bluetooth on the OrangePi (Lite2 | 3) I am stuck at enabling UART1 via overlay.
According to the schematics, the AP6255 is connected via UART1 (PG6-PG9) to the H6 SoC but not defined in the dtb.
Since there is a dtbo which looks promising at /boot/dtb/allwinner/overlay/sun50i-h6-uart1.dtbo I tried adding an
overlay to /boot/armbianEnv.txt - manually and via armbian-config. Both did not work out.
In addition,  I also tried adding uart1 to the dtb, without success.
What am I missing?
1 hour ago, data said:
What am I missing?
A quick look at DT sources reveal me that UART1 doesn't have the "pinctrl-0 = <&uart1_pins>;" parameter, while other UART have theirs.
I will fix that later today ...
EDIT : Here is the commit for both NEXT and DEV : https://github.com/armbian/build/commit/28e8b699adb2c7eca1702ea8c86ab2f650874166
On 4/28/2019 at 9:20 AM, Igor said:
I had to disable this patch since it breaks building. It will be operational when DEV is switched to 5.1.y.
Current as of today is 5.0.10
So is 5.10.y far out? Is there any short term solution to get BT up and running? I mean I ordered a BT USB Stick to flash to Zigbee, would that work in the mean time if I don't flash it as a normal BT stick?
I don't think so, at least not "short term" ...
You mean 5.1.0, not 5.10.y :P
I hope, only Linus Torvald could answer ... He had released RC6 recently ...
11 hours ago, data said:
What kind of stick is that?
ah I see, it is really only Zigbee from what I can see (Wireless Zigbee CC2531) with the alternative Firmware it just can do a lot more, but does not look like as if it would function like a normal BT stick. Well, so either I wait for a BT driver or as an alternative buy another BT stick. Is there a well known/well supported one out there?
So 5.1 is out now, does that mean there is hope for BT "soon"?
hmm, what about this page?
" New Devices Supported "
H6
Beelink GS1
"Xunlong Orange Pi 3"
Let's find out in the next weeks when 5.2-RC kernels will appear
No, sadly you will only get what is already present in Armbian. Less than that.
H6
Beelink GS1
Holy shit! Thanks! Nice! But shows how "slow" software comes and how maybe not clever it was to buy that thing that early. But I wanted something to thinker with and thinker it is :)
Still love it for the eMMC + 2GB RAM
With the boot-issue now resolved, the last nightly enables overlay-support for uart1.
This is one more step towards working bluetooth on the lite2 and Orange Pi 3.
Anyone interested is invited to do further testing.
So far, I can enable the uart1 overlay either in armbianEnv.txt or via armbian-config.
This gives us /dev/ttyS1 - at least it's there in dmesg and /dev/ttyS1 exists. Since the bluetooth module is connected via uart1, the
next steps are to attach it. From my understanding, this needs the hci_uart module, which can be loaded via
$ sudo modprobe hci_uart
In addition, the btbcm module is required but this should be already loaded. So 'sudo modprobe btbcm' should not be necessary.
You can verify if it is loaded via: $ lsmod | grep btbcm
This in place, we should be able to attach the uart-port using hciattach. Now this is the point, where I am stuck.
Typically, you do something along
$ sudo hciattach /dev/ttyS1 bcm43xx 921600 noflow -
However, I tried a couple of different baudrates as well as with and without flow-control without success.
According to a couple of related posts, on success, one should see that the firmware is being loaded at this point.
Any ideas or suggestions?
1 hour ago, megi said:
Bluetooth is supported in my kernel. All you need is have firmware in /lib/firmware and then run:
  btmgmt public-addr 00:03:19:9e:8b:00
or some other address. After boot.
How to get FW is described here:
https://megous.com/git/linux/commit/?h=opi3-5.2&id=9c296799c4d3dd90986833cfded392098c1979bd
(On orange pi 3 that is)
Is there a newbie friendly way to do that? Or can you link me to a simple guide or a search term?
Quote
Nope. The easiest way would be to wait until Linux 5.2 is released and the sunxi64 dev branch will be switched.
Or you get lucky and @martinayotte wants to spare some free time to play around with the pre-5.2 sources.
nah, I'll wait. I basically  "need" BT to use it to switch on some BT-light strips. And I can still do that with my phone, works. So for me, I'll wait.
1 hour ago, SchmuseTigger said:
true, would that then "just work"?
Probably, but I didn't tested it. I've only plug one showing "ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)" in "lsusb", and I've also see "btusb" module loaded ...
Install "bluez" and running "hciconfig" shows :
hci1:	Type: Primary  Bus: USB
	BD Address: 00:1A:7D:DA:71:13  ACL MTU: 310:10  SCO MTU: 64:8
	UP RUNNING
	RX bytes:1220 acl:0 sco:0 events:72 errors:0
	TX bytes:2788 acl:0 sco:0 commands:72 errors:0
This already works with 5.1 if armbian is still using my kernel patches. All that's needed is putting firmware in /lib/firmware.
Yes, sounds incredible easy. But for a windows user with no experience with linux that is harder then it looks like. Is there a guide somewhere? What would I need to google to find out how to do it?
Allright, I got the file downloaded and into the correct folder, but I'm stuck here:
The board contains AP6256 WiFi/BT module that has its bluetooth part connected to SoC's UART1 port. Enable this port, and add node for the bluetooth device.
The UART1 I got actived in the armbian-config. But how to I "add a node for the BT device"?
@megi
I noticed I already had the firmware for ap6255 at /lib/firmware on the lite2 but I am still not able to attach the device to uart1
How have you managed to configure uart1? Or are there some relevant differences in the kernel which haven't been ported to
the lite2 built yet?
