TonyMac32 Posted May 2, 2019 Share Posted May 2, 2019 I've come into a problem, my build system refuses to build images. I haven't been able to debug it, so I'm curious if anyone else in North America is having this trouble? I have historically had odd name resolution bugs/etc that required some massaging of the scripts' use of URL's, but this seems impervious to my efforts. Reading package lists... W: The repository 'http://apt.armbian.com stretch Release' does not have a Release file. E: Failed to fetch http://apt.armbian.com/dists/stretch/stretch-desktop/binary-armhf/Packages 500 Connection failure: Network is unreachable [IP: ::1 3142] E: Some index files failed to download. They have been ignored, or old ones used instead. [ o.k. ] Upgrading base packages [ Armbian ] Link to comment Share on other sites More sharing options...
belfastraven Posted May 3, 2019 Share Posted May 3, 2019 Hi, I'm in Maine, (Spectrum ISP) and could reach http://apt.armbian.com/dists/stretch/stretch-desktop/binary-armhf/Packages through Chrome and also built (I don't have on of these, I was just doing this a a test...my current builds/patches are too messy) BOARD=nanopct3 BRANCH=next RELEASE=stretch BUILD_DESKTOP=yes KERNEL_ONLY=no KERNEL_CONFIGURE=no sucessfully with a Vagrant on Virtualbox build. That sure is a weird looking IP number on the " Network is unreachable message" ;-) Could this be a glitch from your ISP, or has it been happen consistently over hours or days? You'd think more poeple would run into it if it were on the apt.armbian.com end of things.. Link to comment Share on other sites More sharing options...
TonyMac32 Posted May 3, 2019 Author Share Posted May 3, 2019 1 hour ago, belfastraven said: Could this be a glitch from your ISP I am certain it is, however there are quite a few machines between mine and the server, so I'm not sure how far it goes. I had to massage the key server url's at one point because they would fail for me unless I very specifically named them. It's been consistent for a few weeks, I've built a few kernels for cleaning, but images are a no-go. I'm pulling up my secondary machine to determine if it's my install for some reason, I can reach the server via browser and ping. Link to comment Share on other sites More sharing options...
Igor Posted May 3, 2019 Share Posted May 3, 2019 What if you try bypassing apt cacher? Link to comment Share on other sites More sharing options...
TonyMac32 Posted May 5, 2019 Author Share Posted May 5, 2019 I just tried a build on my laptop and it's fine (it was buried), so now to figure out what happened to my main machine... Link to comment Share on other sites More sharing options...
TonyMac32 Posted May 6, 2019 Author Share Posted May 6, 2019 OK, something was wrong with ubuntu, I apt update/upgraded today and it's fine. my laptop likewise has updated today, so it may have not seen the issue Link to comment Share on other sites More sharing options...
Igor Posted May 6, 2019 Share Posted May 6, 2019 Upstream bugs I suppose. I saw some other, possible related, problem the other day: https://askubuntu.com/questions/1049411/release-file-is-not-valid-yet-and-other-errors-when-running-apt-get-update After second apt update, the problem was gone ... Link to comment Share on other sites More sharing options...
