Sean Posted May 4, 2019 Share Posted May 4, 2019 (edited) Hello, I would like to propose a change to the default kernel config for the Odroid XU4. This could *possibliy* done across all kernels: config-4.14.111-odroidxu4: CONFIG_USB_HID=m # CONFIG_HID_PID is not set CONFIG_USB_HIDDEV=y Basically it enables the USB_HID as a module instead of being compiled in and then enables the USB_HIDDEV which in my case the APCUPSD needs the option in order to communicate with the APC UPS device. From what I have read others have run into this problem and this would fix it. Does not seem there would be impact on anything else. Is it worth while making a pull request for this for the XU4 and/or others? Edited May 4, 2019 by Sean CONFIG_HID_PID not needed, joystick force feedback related. Link to comment Share on other sites More sharing options...
Sean Posted May 8, 2019 Author Share Posted May 8, 2019 ..change to the kernel config done. 1 Link to comment Share on other sites More sharing options...
