Updated htop
Igor
23 minutes ago, ftp-bin2fex said:
but the new htop shows temperatures now?
yes it does ;)
The following packages will be upgraded:
  htop
Need to get 75.8 kB of archives.
Get:1 https://apt.armbian.com stretch/main arm64 htop arm64 2.1.2-3 [75.8 kB]
Fetched 75.8 kB in 1s (56.4 kB/s)
Unpacking htop (2.1.2-3) over (2.1.1-3) ...
that's good, I setup up custom watercooling for poweredge 1950 harpertown cpu and I had setup an app to check lm-sensors from android, would always be 49 degrees, so the server never made noise again but sometimes it would get pretty hot and shutdown, even blew off the water on the mobo and the end. Specific core temperatures would be even better for htop.
That's really an open minded extension for htop. Fast and simple!
I've recognized an issue with temperature on my clearfog pro with Debian buster and stretch.
Clearfog Base (Debian Buster) works
htop version buster: 2.2.0-3~armbian5.92+1
bpi-m64 (Debian Buster) works
htop version buster: 2.2.0-3~armbian5.92+12.1.2-3
bpi-m2+ (Debian Stretch) works
htop version stretch: 2.1.2-3
Clearfog pro (Debian Buster and Stretch) doesn't work on a stretch and a buster installation
This probably related to the fact that temp values are not on the (standard) locations where htop searches for values. A workaround could be implemented or fix htop ... once :)
2 hours ago, guidol said:
maybe symbolic-links as workaround?
some time ago I had this on a NanoPi K1 Plus:
temperature for armbian-monitor and welcome-screen (NPi K1 Plus stable):
cd  /etc/armbianmonitor/datasources/
ln -s /sys/devices/virtual/thermal/thermal_zone0/temp soctemp
ln -s /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp
Missing temp in armbianmonitor:
find /sys/devices/ -name temp
/sys/devices/virtual/thermal/thermal_zone1/temp
Switch zone0 to zone1 for soctemp:
rm /etc/armbianmonitor/datasources/soctemp
ln -s /sys/devices/virtual/thermal/thermal_zone1/temp /etc/armbianmonitor/datasources/soctemp
ln -s /sys/devices/virtual/thermal/thermal_zone0/temp /etc/armbianmonitor/datasources/soctemp
/usr/lib/file
ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp
My
cat /sys/devices/virtual/thermal/thermal_zone0/temp
echo 'nameserver 192.168.6.3' >> /etc/resolv.conf
echo 200000 > /sys/devices/system/cpu/cpufreq/ondemand/sampling_rate
/usr/lib/armbian/armbian-hardware-monitor
# SoC temp: check sun7i legacy exception first, then standard path(s)
        if [[ -f /sys/class/hwmon/hwmon0/temp1_input ]]; then
                # usual convention with modern kernels
        fi
The path is hard coded in the HTOP for the cpu temp.
I think the problem is that some boards (kernel) use the hwmon driver and sometimes different kernel config.
I think the best approach would be to traverse /sys and try to find the label for the cputemp / gputemp / regulators, etc..
But what exactly look for to be Universal?
In my x64 for example, same Intel, different kernel configs (server vs desktop) points to different locations:
cat /sys/devices/platform/coretemp.0/hwmon/hwmon1/temp2_label
Core 0
cat /sys/devices/platform/coretemp.0/hwmon/hwmon1/temp3_label
Core 1
cat /sys/devices/platform/coretemp.0/hwmon/hwmon2/temp2_label
Core 0
Hey guys,
thanks for helping me out and sorry for the late response.
I checked the thermal_zone as @guidoldescriped
84164
I also checked the link inside _/etc/armbianmonitor/datasources_
ls -l
total 0
lrwxrwxrwx 1 root root 47 Aug 28 10:40 soctemp -> /sys/devices/virtual/thermal/thermal_zone0/temp
It's all the same on the Clearfog pro as it is on the Clearfog base
@lex I cannot find a value like *temp[0-9]_label* But maybe this output can help
find /sys/devices/ |grep temp[0-9]
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:0f/hwmon/hwmon7/temp1_max_alarm
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:0f/hwmon/hwmon7/temp1_crit
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:0f/hwmon/hwmon7/temp1_input
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:04/hwmon/hwmon6/temp1_max_alarm
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:04/hwmon/hwmon6/temp1_crit
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:04/hwmon/hwmon6/temp1_input
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:02/hwmon/hwmon4/temp1_max_alarm
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:02/hwmon/hwmon4/temp1_crit
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:02/hwmon/hwmon4/temp1_input
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:00/hwmon/hwmon2/temp1_max_alarm
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:00/hwmon/hwmon2/temp1_crit
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:00/hwmon/hwmon2/temp1_input
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:03/hwmon/hwmon5/temp1_max_alarm
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:03/hwmon/hwmon5/temp1_crit
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:03/hwmon/hwmon5/temp1_input
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:01/hwmon/hwmon3/temp1_max_alarm
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:01/hwmon/hwmon3/temp1_crit
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:01/hwmon/hwmon3/temp1_input
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:00/hwmon/hwmon0/temp1_max_alarm
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:00/hwmon/hwmon0/temp1_crit
/sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:00/hwmon/hwmon0/temp1_input
/sys/devices/virtual/thermal/thermal_zone0/hwmon1/temp1_input
@Igor I have also noticed that the *CpuFreq[1-9]: ... MHz* section is missing in the htop frontend too, on all of my _Clearfog Pro_ devices
When I open up the /usr/bin/htop it looks like that there you can see the hardcoded files
u: ^@^@^@show processes of a single user^@      H: ^@^@^@hide/show user process threads^@^@      K: ^@^@^@hide/show kernel threads^@^@^@^@      F: ^@^@^@cursor follows process^@^@ F6 + -: ^@^@^@expand/collapse tree^@^@^@^@  P M T: ^@^@^@sort by CPU%, MEM% or TIME^@^@      I: ^@^@^@invert sort order^@^@^@ F6 > .: ^@^@^@select sort column^@^@Environment of process %d - %s^@^@Could not read process environment.^@Refresh^@"^@^@^@/sys/class/thermal/thermal_zone0/temp^@^@^@/sys/devices/virtual/thermal/thermal_zone0/temp^@/sys/class/hwmon/hwmon0/temp1_input^@/sys/devices/system/cpu/cpu%d/cpufreq/cpuinfo_cur_freq^@^@/sys/devices/platform/soc/7081400.i2c/i2c-0/0-0036/regulator/regulator.1/microvolts^@/sys/devices/platform/soc/1f02400.i2c/i2c-4/4-0065/regulator/regulator.5/microvolts^@/sys/devices/platform/ff3c0000.i2c/i2c-0/0-001b/regulator/regulator.12/microvolts^@^@^@/sys/devices/platform/ff3c0000.i2c/i2c-0/0-0040/regulator/regulator.9/microvolts^@^@^@^@/sys/devices/system/cpu/cpu%d/cpufreq/cpuinfo_max_freq^@^@/proc/uptime^@^@^@^@%64lf^@^@^@/proc/loadavg^@^@^@%32lf %32lf %32lf %32d/%32d %32d^@^@^@^@/proc/sys/kernel/pid_max^@^@^@^@/proc/%d/environ^@^@^@^@ 0 Cancel^@^@^@ 1 SI
The following files are available
66548
cat /sys/class/hwmon/hwmon0/temp1_input
62000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: No such file or directory
cat /sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_cur_freq
cat: /sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_cur_freq: No such file or directory
This is all exactly the same on my Clearfog Base. But now I can see that on the Clearfog Base the CpuFreq is 0 Mhz. So the issue changed to
Clearfog Base:  Shows 0 MHz because the hardcoded files are missing
Clerafog Pro: Doesn't show that sections at all. It looks like this htop doesn't have this features at all
Aaaaaahhhhhh!!!! :D
Ok inside htop on the Clearfog Pro's I had to configure the Frequency and Temperature.
Solution
Enter htop
Press F2
759420985_Screenshotfrom2019-09-1315-36-29.thumb.png.98e976be2a9af1ed056cb257ec6c68e4.png
Another Update
On my Clearfog Pro does the file **/sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq** exist and its content switches between 800 and 1600 this is shown in htop
On the Clearfog Base is the whole directory **/sys/devices/system/cpu/cpufreq/** empty
Strange (for me) :(
I got one NanoPi Neo2 LTS (1GB) and 2 NanoPi Neo2 non-LTS (512MB) and alle three got the same dev-armbian:
non-LTS:
Debian Buster with Armbian Linux 5.3.7-sunxi64
package bsp-kernel[5.98.191027] u-boot[5.90] dtb[5.98.191027] firmware[5.98] config[5.98]
armbian branch    [dev]
LTS:
package bsp-kernel[5.98.191027] u-boot[5.98] dtb[5.98.191027] firmware[5.98] config[5.98]
but on the LTS Neo2 htop does show temperature and CPU-Speeds and on the 2 non-LTS it doesnt show it :(
The armbian on the LTS Neo2 was complied fresh yesterday and the armbian on the 2 non-LTS is updated via apt update/upgrade.
On all three armbianmonitor and the login does show the temperature.
Quote
@Igor where can I read about /check the (standard) locations? I want to see whats missing on the non-LTS Neo2.
htop version is on all three devices 2.2.0-3~armbian5.92+1 arm64
5 minutes ago, guidol said:
it doesnt show
It shows values 0 or nothing at all? If this is the case, then htop user configuration is either wrong, missing has wrong permissions ... htop config is inside your home directory, .system/htop/something ...
:) Many Thanks!
htop didnt show anything on the non-LTS Neo2 = upgraded armbian.
I copied the content of the ~/.config/htop/htoprc from the working to the non-working Neo2 and now htop does show temperature and cpu-speeds also on the other system ;)
non-working htoprc:
Spoiler
# Beware! This file is rewritten by htop when settings are changed in the interface.
# The parser is also very primitive, and not human-friendly.
fields=0 48 17 18 38 39 40 2 46 47 49 1
sort_key=40
sort_direction=1
hide_threads=0
hide_kernel_threads=1
hide_userland_threads=0
shadow_other_users=0
show_thread_names=0
show_program_path=1
highlight_base_name=0
highlight_megabytes=1
highlight_threads=1
tree_view=0
header_margin=1
detailed_cpu_time=0
cpu_count_from_zero=0
update_process_names=0
account_guest_in_cpu_meter=0
color_scheme=0
delay=15
left_meters=AllCPUs Memory Swap
left_meter_modes=1 1 1
right_meters=Tasks LoadAverage Uptime
right_meter_modes=2 2 2
working htoprc:
Spoiler
sort_key=46
sort_direction=1
hide_threads=0
show_thread_names=0
show_program_path=1
highlight_threads=1
tree_view=0
header_margin=1
detailed_cpu_time=0
color_scheme=0
delay=15
left_meters=AllCPUs Memory Swap CpuTemp
left_meter_modes=1 1 1 2
right_meters=Hostname Tasks LoadAverage Uptime CpuFreq(1) CpuFreq(2) CpuFreq(3) CpuFreq(4)
right_meter_modes=2 2 2 2 2 2 2 2
Thanks @Guidol,  I had the same issue with Orange Pi Zero Plus.
One showed Cpu Temp And Cpu Frequency.  Two did not show the options.
~/.config/htop/htoprc was blank on the two that did not work.
Changing settings on htop did not populate the file and settings were lost between sessions.
File permissions were the same for all three.
I copied the working htoprc to the other two and this solved the problem.
I also had on all 3 Neo2 the same file-permissions:
ls -l ~/.config/htop/htoprc
-rw-r--r-- 1 root root 738 Okt 28 10:29 /root/.config/htop/htoprc
and only on my non-root user guido there was a htop-directory, but no htoprc - maybe because I didnt started htop as guido in the past ;)
