tomtor Posted May 9, 2019 Share Posted May 9, 2019 Armbianmonitor: http://ix.io/1Iul vmlinuz-4.20.7-sunxi64 works fine (the Armbianmonitor URL is from that) but 5.1.0 breaks eth: 1c30000.ethernet: Unsupported interface mode: rgmii-txid Link to comment Share on other sites More sharing options...
Igor Posted May 11, 2019 Share Posted May 11, 2019 On 5/9/2019 at 2:36 PM, tomtor said: but 5.1.0 breaks eth It is expected that something will fail since 5.1.y is under development and such kernels are not receiving expensive end-user support. If you want to use it (now), you have to fix the problem on your own. Check DT from 4.19.y - probably the problem is the same ... Link to comment Share on other sites More sharing options...
martinayotte Posted May 11, 2019 Share Posted May 11, 2019 On 5/9/2019 at 8:36 AM, tomtor said: but 5.1.0 breaks eth: 5.1.0 works fine on my Pine64 ... But, according to your log, it seems to work there too, why are you saying that it is broken ? [ 19.938228] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 19.938279] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Link to comment Share on other sites More sharing options...
windysea Posted June 5, 2019 Share Posted June 5, 2019 @martinayotte - I was researching this one since I experienced the same when updating from 5.0.y to 5.1.y. It looks like you had found similar and posted a query/comment to the upstream repo at https://github.com/megous/linux/commit/c797ad894874de33b2be4beeb1f5a1e6339a888d#comments I had found the same as you - the drivers/net/ethernet/stmicro/stmmac/dwmac-sun8i.c driver was missing a change made specifically in megous' branch for 5.0 but not carried to 5.1. Did you intend to include this as a local patch or should I submit a pull request for a new patch to do this in the armbian tree? It looks like 0003-net-stmmac-dwmac-sun8i-support-RGMII-modes-with-PHY-.patch from patch/kernel/sunxi-next should do it. . . Link to comment Share on other sites More sharing options...
martinayotte Posted June 5, 2019 Share Posted June 5, 2019 12 hours ago, windysea said: Did you intend to include this as a local patch or should I submit a pull request for a new patch to do this in the armbian tree? Ah ! Thanks to make me pay more attention to that : I had this patch restored sitting on my desktop, but never committed ... I've just committed it now ... Link to comment Share on other sites More sharing options...
windysea Posted June 5, 2019 Share Posted June 5, 2019 Thanks! I removed the patch from my local 'userpatches' and built a new -dev kernel using the default kernel config (no changes) and no local patches or changes. The kernel booted with expected network connectivity and all looks good. I'll verify tomorrow with the nightly builds as well. Link to comment Share on other sites More sharing options...
