pepeluis Posted May 12, 2019 Share Posted May 12, 2019 Armbianmonitor: http://ix.io/1ILX Hi! I'm trying to star the SNMP daemon, but i have : pcilib: Cannot open /proc/bus/pci pcilib: Cannot find any working access method. pcilib: pci_init failed Warning: no access control information configured. (Config search path: /etc/snmp:/usr/share/snmp:/usr/lib/arm-linux-gnueabihf/snmp:/home/pepeluis/.snmp) It's unlikely this agent can serve any useful purpose in this state. Run "snmpconf -g basic_setup" to help you configure the snmpd.conf file for this agent. Error opening specified endpoint "" Server Exiting with code 1 I write in snmpd.conf agentAddress udp:161 doesn't work,,,the same,,, Any idea I will appreciate it a lot Thanks!!!! Link to comment Share on other sites More sharing options...
lanefu Posted May 12, 2019 Share Posted May 12, 2019 How did you install snmpd? Are you running the config command with sudo? are you starting the service with sudo systemctl start snmpd Link to comment Share on other sites More sharing options...
pepeluis Posted May 12, 2019 Author Share Posted May 12, 2019 Hi Lanefu!!! install: sudo apt-get update && sudo apt-get install snmpd snmp-mibs-downloader I execute your comand,,,,and get : pepeluis@orangepizero:~$ service --status-all |grep snmp [ + ] snmpd it's running ok? There's a way to test? because : pepeluis@orangepizero:~$ snmpstatus localhost snmpstatus: No securityName specified and i don´t have any response Link to comment Share on other sites More sharing options...
pepeluis Posted May 12, 2019 Author Share Posted May 12, 2019 I get response finally!!!!! Thanks a lot Best regards Link to comment Share on other sites More sharing options...
sfx2000 Posted May 29, 2019 Share Posted May 29, 2019 FWIW - here's a write up I did a couple of years back - useful for getting full use of snmp/snmpd... ===== SNMP ===== SNMP is a server/agent architecture - the agent runs on the target machines, and the service is run on the server - so we do both. NOTE - this is optional - only needed if one wants to do cacti or other SNMP related apps - if you don't need this, you can skip it NOTE 2 - we're covering SNMP v1/v2 - SNMP v3 includes some auth options that are handy to have, but generally in a local area network, they're 'extra credit' as many clients do not support it, and we're keeping things simple in this series. Good overview here - https://en.wikipedia.org/wiki/Simple_Network_Management_Protocol The config files * **snmpd.conf** - configures the agent and servers * **snmp.conf** - configures the server only **Install SNMP** sudo apt install snmp go to /etc/snmp and comment out the following line like this - this allows you to import MIB's sudo nano /etc/snmp/snmp.conf # As the snmp packages come without MIB files due to license reasons, loading # of MIBs is disabled by default. If you added the MIBs you can reenable # loading them by commenting out the following line. mibs : comment out the mibs line like below #mibs : Now run the mibs-downloader sudo apt install snmp-mibs-downloader done for server-side - smpd is optional for the server, but if you want to collect stats on localhost you'll need a configured SNMP Agent **SNMP Agent** To install the agent on a debian/ubuntu based machine sudo apt install snmpd For other platforms, check their documentation - Windows does support SNMP, but it needs to be turned on, same with Macs, QNAP/Synology NAS boxes are good, HP OfficeJet tends to have it enabled with 'public' community (not all do), some consumer routers also have SNMP agents (AsusWRT-RMerlin, as least in the builds I checked in his github). Many managed switches (smart switches) also have SNMP agents On linux - The agent config as shipped is very thorough, however, we can make it really simple... sudo mv /etc/snmp/snmpd.conf /etc/snmp/snmpd.conf.orig Now create a new one sudo nano /etc/snmp/snmpd.conf Only one line needs to be there, but you can add a couple of informative ones as needed - what we're doing here on the agent side is create a read-only SNMP community, naming it "public" and limiting scope to the local area network (in CIDR notation) rocommunity public 192.168.1.0/24 # syslocation "testLab" # syscontact gmailuser@gmail.com One more file to change - comment out the export MIBS line and save sudo nano /etc/default/snmpd <code> # This file controls the activity of snmpd # Don't load any MIBs by default. # You might comment this lines once you have the MIBs downloaded. # export MIBS= # snmpd control (yes means start daemon). SNMPDRUN=yes # snmpd options (use syslog, close stdin/out/err). SNMPDOPTS='-Lsd -Lf /dev/null -u snmp -g snmp -I -smux,mteTrigger,mteTriggerConf -p /run/snmpd.pid' </code> save the file and start/restart snmpd sudo service snmpd restart to test, do an snmpwalk against the local ip sudo snmpwalk -c public -v1 192.168.1.6 You should get a lot of information back, or the connection will timeout (e.g. either wrong community, or the agent isn't running/answering up) Link to comment Share on other sites More sharing options...
